Results 1 to 7 of 7
Thread: which Spal to order when replacing stock aux fan?
    Hawaii to Las Vegas, NV
    '06 4Runner| 77 930| E36
    Im gonna be running the typical size IC 31x12x3 and will be ordering a Spal fan to replace my stock aux fan. I have searched and lots of guys are running ebay fans and want to know if this spal fan will be efficient and fit?
    http://store.bimmerworld.com/spal-el...ans-p1160.aspx
    spal # 30100400 16'' pusher/ 1300cfm/ 15.75''x 2.05''
    otherwise what are you guys running?
    thanks
    Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | LINK G4 standalone | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 525lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
    Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
    Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
    Sep 2003
    NYC
    E36 M3 stg2 S/C...& a MV
    I am curious too. With my S/C IC installed & CP there is limited room for a fan. The ebay fans look to good to be true. Hopefully someone has tried them and can give some feed back.
    Jan 2006
    Austin, TX
    E-many
    Aux fan
    That looks like the spal that I use on my tt kit. I will see if I can get a number off of the fan tomorrow.
    Quote Originally Posted by karlvs View Post
    thanks man
    and if anyone else can put their input id appreciate it.
    -Chase
    anyone?
    Jan 2006
    Austin, TX
    E-many
    spal fan
    Took me longer than I thought but this is the number on my car. Spal 30100401. This is the one that came with my tt kit and seems to work great.
    Nick built some custom brackets for these to work with the stock mounts but I am sure some sort of mount could be fabricated. The 30100400 is a puller fan where as the 30100401 is the pusher fan you need. gl
    thanks again man! just what I needed
    NY
    skateboard
    I use a spal 900cfm fan in place of my aux fan.
    ― George Orwell
