Results 1 to 13 of 13
Thread: E36 custom 188mm diff: 4.10 TORSEN LSD
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    nla-
    Wanganstyle Powertrain
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
    Dec 2007
    SF bay area
    Bump. Somebody must have a 6mt and want to go fast!
    Dec 2007
    SF bay area
    Bump for Tarmac rally
    Upton, MA
    e39 540i/a, e30 325i
    Correct me if I am wrong, but 188mm is the large case correct?
    If so that means with the right axel stubs and the original diff back, this could fit an e39 540i?
    Oklahoma
    996, 914, X5
    188 is medium case
    Dec 2007
    SF bay area
    Quote Originally Posted by jamesthebikeguy View Post
    for e39 V8, the swap is e39 v8 M5 rear LSD+axels+ driveshaft. That is the plug and play solution
    Dec 2007
    SF bay area
    also have 4.27 Torsen avail if somebody wants to hill climb!!!
    diffsonline's Avatar
    diffsonline is offline Supporting Vendor
    Diff Builder
    Supporting Vendor
    Sep 2003
    Wilmington MA
    Escalade, Harley, BRP
    40%? Really?
    That is interesting because I have never seen one of these with preload in them.
    Dec 2007
    SF bay area
    Quote Originally Posted by diffsonline View Post
    40%? Really?
    Stock bmw torsens are 40% lock. That's the factory specs
    There is no preload, it's a mechanical diff. If you have a really stiff motorsports car that lifts it's drive wheels of the ground often, then perhaps buy an aftermarket clutch diff?
    Diff Builder
    Supporting Vendor
    Sep 2003
    Wilmington MA
    Quote Originally Posted by wanganstyle View Post
    so you are saying 40% on accel then. I have never seen an exact spec on any of these carriers in any of their literature. Not talking the stuff from BMW either. I would question the 40% number also as ever z3 I have driven with one of these is horrendous to drive and it behaves like it has much less lock. I will give the torsen units credit as they outperform any non-torsen helical carrier.
    I have a pile of these on the shelf if you ever need more.
    Dec 2007
    SF bay area
    It's definitely an accel biased unit, it's Oem- not custom. it will lock on deccel, I have one in my hooligan runabout e30.
    locks up both rear tires with more grip than the stock 2 clutch unit, understeers slightly so Im happy to turn w throttle!!
    Apr 2017
    Tacoma, WA
    1989 325i, 2001 Z3
    I know this post is six years old, but do you still have any Z3 Torsens laying around?
    Diff Builder
    Supporting Vendor
    Sep 2003
    Wilmington MA
    Quote Originally Posted by drzhivago1965 View Post
    always have half a dozen or so.
