Page 1 of 17 1234567891011 ... LastLast
Results 1 to 25 of 403
Thread: e36 Drift truck s38 powered
    Aug 2009
    Arizona
    e36 m3 rip, e36 truck :D
    Welcome to my dream build. I don't have money to fund my dreams at the hands of a professional, so with a vision, willingness to learn to overcome whatever may stay in the way, and me little garage, I've been notchin away
    Here she is now a rollin
    a little sliding
    She started as a 100k 93 e36 shell for a couple hundred bucks. My plans are to give her a full track treatment and throw in all my m3 guts into her for an ultimate sliding maching.
    Poor ol salvaged contorted shell m3…..
    oh wait, really poor m3 shell
    her hitting the wall
    and the newby
    and the teardown began
    So all the while I”ve had the idea of truck plaguing my mind…..
    I’ve seen e30’s, e39, 240’s, and subies chopped to trucks. I’ve always liked the idea if the lines allowed, so after a little tinkering my mind was set……
    motivation……
    Having not seen any e36 trucks made before and knowing it could look sweet with ghetto photoshop renditions, Out came the angle grinder and badabing, truck is under way.
    sawzal and plasma cutters are over rated angle grider ftw …..
    initially my plans were to go crazy with my roll cage to make up for the noodle rear end I’ve created, as this is a full purpose built slider. She just happens to look like a truck….
    then after a bit more searching I found this and decided to go this route for the bed cage. Much easier to get the bodylines I wanted, and I figured I could get good support in the rear this way. Not to mention keeping the weight as even as possible as I would hate to mess up the way the e36 handles.
    This is where I mention at this point I hadn’t welded before other than learning on a couple pieces of tubing with a borrowed welder…..no better way to learn than by necessity eh?
    so got the bed frame and the rear body lines underway,
    VROOOOOOOM
    Aug 2009
    Arizona
    onto the cab makin. And idea came to make the rear of the roof flat, so why not mock it up.
    and flat roof
    b pillar and rear frame mockup…..
    just freestylin and kinda went with it all up til this point. Usually the mock ups have to be changed etc, it all looked good enough to go with it.
    Nearly done with the bed before fiberglass
    gutted the sunroof for the roof….
    then for the hitch…..The trunk’ll work nicely
    And why not, more teardown….
    wires of fun
    And a bit more ghetto photoshop fun
    VROOOOOOOM
    Aug 2009
    Arizona
    and incomes the roll cage tubing. Big thanks to Vitaly Spokan for bending it all for me
    After thinking of the fiberglass bed for so long, I decided to just sheet metal it all in and make it permanent.
    (after having welded a bunch starting with flux then finally getting a bottle n a bit of comfort, 26g sheet metal was another task)
    to tie the cage in fully
    And finally, we have a bed
    And a working tailgate…
    VROOOOOOOM
    Jul 2010
    NC
    e34 528i/5
    Hell yes! Sub'd.
    Aug 2009
    Arizona
    S38b35 w/ Metric Mechainc intake cam, Fresh head rebuild, Trans, Megasquirt II fully built but needing to be wired up
    got crazy with a wirewheel
    Also got a fuel cell with the motor, but I like the stock tank location
    And onto how this front sump’d motor is going into this car
    Of course a custom rear sump oil pan would be ideal, but I don’t have the $ or tools to do so, so maybe e34 pan, but no go.
    what if you moved the steering rack rearward to clear the sump?
    barely worked with the stock arms, but not with the e46 that I’ll be using
    a little added enforcement
    some more cage workin
    then found a way to get a bit more clearance out of the oil pan to move the rack farther forward
    Thanks to Evil Engineering for the alum moddin I have yet to undertake
    and since I’ve gone passed the point of no return into racecardom, some more gutting and wirewheeling
    VROOOOOOOM
    Aug 2009
    Arizona
    More with the cage
    the sunroof warped a bit when welded, so I replaced it with a piece of new sheetmetal which warped elsewhere, but is finally ok after some series massaging
    Fully stripped, seamwelded, and por15d…..nearly ready to be rolling again
    bed welding for days
    and nearing the finalization of all the monkey bars
    Time for suspension to go back on
    Bushings first
    car’s worth hardware n a bit more ready to go back on
    rear end on
    and she’s got wheels on again
    VROOOOOOOM
    Orlando, FL
    E36, E46, E53, GTV
    wow! You should have just tube framed it!
    Lots of work and I can see your welding skills getting better throughout the build!
    Post pics after paint! Should fill all of the cracks of the soul!
    www.ienjoydrifting.com
    2001 BMW 3 Series Sedan - 700hp/700tq M52 Drift car.
    Aug 2009
    Arizona
    after having done it and gaining the knowldge I have, boy would I go about it much differently. Live n Learn
    we'll see how she looks after paint, but her soul is gonna be shinin ....
    and out she rolls from the garage for the first time
    the steering works
    and on suspension over at the paint shop, sittin like she’s meant to
    in for the first time, she fits, uhhhhh, kinda
    n that’s it for now……more to come as time allows
    rat truck :d
    VROOOOOOOM
    Jan 2005
    Florida
    00' 328i
    subbed. Awesome build. Lots of work but looks great so far!
    Aug 2009
    Surfside beach sc
    E46sedan m50,12 ecoboost
    this is the coolest thing ive ever seen, i want one so bad now!
    Jul 2006
    Gainesville Fl
    2JZ FD3S, 2JZ M3, 95 M3
    this looks amazing.
    -Andrew Mensah
    Miami, fl
    1998 BMW 323is
    this is going to be amazing!
    Marietta, GA
    06 Impreza Wagon
    what s going on with the door bars? there are a bunch of load paths that just end making for a VERY weak design throughout.
    Portland, Or
    e36 325is, e30 318is
    crazy build! and loving the progress...
    Aug 2009
    Arizona
    thanks guys
    the door bars looked strong to me, just freestylin and threw in more bars, I couldn't stop
    VROOOOOOOM
    Nov 2007
    moreno valley ca
    84 318i
    awesome build! you should put a csl style spoiler on trunk/tailgate.
    btw what the hell happened to your m3?
    84 318i (drift car) 89 merkur xr4ti(daily) 82 733i (other daily)
    May 2010
    San diego.
    95 325is.
    Props men, thats awesome.
    Oct 2003
    Southern California
    E36 M3/4/5, F30 328i
    Very cool build. I like where this is going.
    LA chapter BMW CCA autocross CDI
    www.bmwclubla.org
    Aug 2008
    Lakeland Florida
    1992 325is
    Quote Originally Posted by Dominic49 View Post
    +1
    geometry is your friend
    Nov 2009
    myrtle beach, sc
    '95 318ti, '97 11JZ111
    crazy build. i really dig how the trunk is turned into a functional tailgate.
    the rest of the cage looks spot on, but i have to agree the door bars look pretty haphazard. great work from a first timer overall though
    new projekt 11JZ111...
    For sale???? say it aint so....
    Jul 2004
    NY
    LS3 e46 m3, '76 2002
    I'm sorry, but that cage is totally @#$%.
    -Mike
    Aug 2009
    Arizona
    k since the cage is @#$%, or moreso just door bars, constructive criticism rather than @#$% eh?
    would a simple x door bar be stronger?
    or persay if I were to remove the bar coming from the dash bar and replace it with a bar connecting it to the rearward union of the ending diagnal bar? thus making it a fully connnected x with a parallel bar running longitudinally?
    VROOOOOOOM
    Jun 2010
    PA
    95 325I
    WOW, amazing amount of work! I need to see this thing painted.
    ( originally posted by PROTOMOR )
    "It's like telling your child it's ok to snort coke off a cheap hooker's ass. It's ok if you do it, but you really shouldn't. And by doing it in front of your child, you are telling them it's ok to snort coke off a cheap hooker's ass. "
    Apr 2008
    Spokane, Wa
    '97 M3/2/6 '01 996tt
    would have been easier to start out with a convertible?
    http://www.hardmotorsport.com http://Facebook.com/HardMotorsport
    LA Sol CAL
    93 525i
    dam im inspired to make one my self or turn my e34 to a two door
    93BMW 525i -16"momo, KN filter ,Daily driver
