General description of washer pump circuit:
Power is supplied from F44 in accy, run, and start. Power is applied directly to the washer pump on the violet/white wire. Ground to the pump is on the brown/violet wire and grounds through the WWM.
1. Check for 12V on the violet/white wire in accy, run, and start. If no power, then you have a power supply problem. Check fuse and wiring for faults.
2. Jump the pump connector brown/violet wire side to chassis ground. If the pump does not activate you have a bad pump or connection at the pump.
3. Pull the x285 connector from the WWM and jump pin 10 (still brown/violet wire) to chassis ground. If the pump does not activate, you have a bad wire or connection between the pump and the WWM.
4. Reconnect x285 and jump pin 11 (a different brown/violet wire) to chassis ground. This simulates using the washer switch. If the pump now activates, you have a bad washer switch.
5. If the pump did not activate on step 4, verify all the grounds for the WWM. Disconnect x285 again. Do a continuity test between chassis ground and each of the x285 pins 7 & 15. Check for 12V on pins 2, 8, & 14. If all these check out, you have a bad WWM.
Connector x285 is a blue 15 pin connector and can be located with the WWM behind the glovebox. Looking at the connector face with the 8 pins on top, pins are numbered
Code:
8 7 6 5 4 3 2 1
15 14 13 12 11 10 9
