Hello. I am wondering if its possible to install an e30 headlight switch in an e21 and with how much modification? I recently acquired an 83 e21 and the left side running lights dont work (both front left turn signal running light and rear left tail running light). I was told that it was the headlight switch and was even given an e30 switch to install and it would fix the problem. how much is involved with doing this? Thanks.
Did you check the fuse?
Yeah...don't go right to the switch. Probably a fuse/ground/connector/bulb issue.
its the fuse... same thing happened to me... PULL THE FUSE OUT and examine it all the way around... even if it isnt blown it might be bad/dirty,burnt etc. I have yet to "blow" a fuse in my car but everytime something has been messed up its because a fuse is bad for some other reason
I replaced the bulbs incase that was it and it wasnt. I'll check the fuse. Which fuse is it? in the engine bay fuse box i'm guessing. thanks guys!
When I connected the fuse the left side running lights stay on even when the car is off and key out of ignition. What could this be?
it is the headlight switch.
see this other post #13. http://forums.bimmerforums.com/forum....php?t=1622947
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
