Results 1 to 6 of 6
Thread: Driver Side Parking Lamp Malfunction?
    SoCal
    2005 BMW 645 coupe
    I have a E63 2005 645, I am getting a notice of "driver side parking lamp malfunction". Does anyone know where to locate (preferably with pics) and change bulbs for these parking lamps aka (angle eyes)?
    I looked inside the wheel well and opened the access but cant locate the parking lamp...any assistance would be appreciated.
    Biloxi
    740IL
    I am having light trouble too. I have taken almost the entire front end off my car and cannot fix my problem (low bulb failure and adaptive lighting failure). The Angel Eye bulbs are located in about the center of the headlight assembly towards the bottom. One bulb for driver's side and one for passenger side of the car (2 bulbs total on car). Start with Passenger side as it is easier to see, remove and replace. It turns about 1/4 turn then you pull it straight out. Pay close attention to the three prongs that stick out (one is larger than the other two) to match holes when replacing. The bulbs can be bought off line, but do NOT include the assembly that BMW would sell you. You need a 5-10watt bulb. The bulb that is in the assembly is a Phillips 12082. You just have to match up the bottom and voltage/wattage. Driver side is a little harder to get to without removing hold latch. I was able to remove the bulb and replace in the old assembly. I will look for vendor who sold me the bulbs online. They were about 5$ each and I went ahead and bought three. Good Luck.
    Bulbtronics Inc. The bulb was OSRAM 64113.
    Dec 2005
    Atlanta, GA
    e65 B7
    FYI, the parking lamp is not necessarily the angel eye bulb nor is it the low/high beam bulb, nor is it the signal light bulb.
    For our cars, the "parking lamp" can be referred to as a couple things, and it is never really that clear, even in the manual. But in TSB's, it is most often referenced as the far corner bulb that is constantly on - the small amber bulb in the corner of the signal eyebrow of the headlight, accessed via the front wheel wells.
    Also, depending on how your car is programmed, it can refer to the low voltage beam + angel eyes that are more commonly referred to as DRL's (or daytime running lights). The problem is that the DRL function is programmable, and it is also inconsistently applied between the pre and post-LCI model years.
    http://www.bimmerfest.com/forums/sho...519&highlight=
    Maserati GT 4.2
    Range Rover 4.4
    Dodge Ram 1500
    PAST: ALPINA B7, e63, e39, e39, e36
    Feb 2015
    Atlanta, GA United States
    1994 740iL, 2004 645Ci,
    Hey HOSS... Any help with suggestions on where to start with a fix for the passenger-side dead headlight assembly would be great! Are you available for a quick chat?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Feb 2018
    Canada
    Just buy Carly for BMW and turn that notification off, and go get LED replacements.
