Results 1 to 6 of 6
Thread: Clardy A/C brackets
    Apr 2008
    Orlando, Fla
    04/330i 00/M5 72/02
    Clardy A/C brackets
    Just had a batch of brackets made. Does anyone need a new A/C bracket that fits the M10 engine. The bracket was modeled from an original clardy bracket and was mocked up on a straight 2002 & tii block. It's put together and welded in a steel jig for quality control. All of the rubber bushings have been deleted so no more worn out bushings to replace down the road. Also the bracket size has been reduced along with the weight so you don’t have to remove the bracket to replace a water pump like the older York bracket.
    If you are ready to start that A/C project You will need one of these brackets. I will include the size of washers nuts & bolts you will need to finish the install. I just wanted to let you know the price of the Bracket is now 92.00 + 10.00 shipping + 3.50 paypal total $105.50 in the lower 48.
    Had this bracket powder coated it turned out real nice
    Contact me at dave.hobiedave@gmail.com Take a look at my album for the install. http://s335.photobucket.com/albums/m...2/AC%20system/
    http://www.bmw2002registry.com/about.jsp
    If you are interested in Putting in A/C or modernized your A/C in your 2002. I have the perfect bracket modeled after the original Clardy Rotary bracket. It fits all models even tii. I have made some improvements on the original design by deleted the rubber bushings that needed replacing every other year also made it smaller and lighter. No pulley needed because the compressor acts as the tensioner for the v-belt. These are all new brackets and adjusting arms and spacers included along with all the bolt sizes you will need.
    Jan 2006
    kernersville, north carolina
    83 320 85 325e 91 325ix
    would like one of these brackets for my m10 e21 call me at 336 831 4432. thanks dave at carr industries greensboro nc
    Apr 2014
    Tulsa, OK
    76 2002, 82 e21, 83 e21
    Does anyone have any information on the availability of a Clardy Rotary bracket? Its getting hot and my York Brick died!
    Help!
    Thanks. :-)
    Jun 2014
    Valparaiso, FL
    1981 320i
    wondering here as well
    Oct 2007
    Salt Lake City, Utah
    1973 BMW 2002
    Hobie Dave, Are you still out there with A/C brackets for sale?
    Quote Originally Posted by SilverPuddle View Post
    Help!
    Thanks. :-)
    1973 2002
    Front & rear sway bars
    Engine bay strut bar
    Oil breather oil catch can
    Weber 38/38 carb conversion
    Polished aluminum valve cover
    Battery relocated to trunk with remote cut off switch
    Steel headers
    Enkie 16" mag wheels
    Installed oil pressure, voltmeter & vacuum gages in middle console
    Pertronic distributor ignition
    Custom aluminum vent and window door cranks
    Drier's seat RamSkin 1" custom fit sheepskin cover
    Modern Panasonic CD,Bluetooth radio.
    Nardi wood steering wheel
    Custom dash cover
    Added passenger side BMW flag mirror
    Mobile, AL
    '73 ///M2, '85 ///M635
    Y'all go over to bmw2002faq.com. That's where Dave, and everyone else is!
