I know it's here somewhere but I cannot seem to find the process...
Replaced front brakes after sensor wore thru. Warning light is still on - what's the process for resetting it? I was thinking you could just put the key in #2 for a time, but no joy. Tried driving it for awhile too...
You have to replace the sensor too, not just the pads BTW...
Here, it is #12.... http://www.realoem.com/bmw/showparts...57&hg=34&fg=05
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Pm Smilez, he'll hook you up if you need sensors.
lemme rePhrase that...
replaced pads AND sensor.
Reset process still unclear!
You have to unhook the battery for a few minutes.
93 e36 vert / 95 E36 M3 Alpine / 98 M3/4 Estoril / 00 '46 Frankenbimmer CI , 68s / shark tooth injected driver bolster with slimline low gloss duct tape / angled front pass kidney grill with custom eject hood release / EE LEDs moisture sealed/ Pep Boys silicone / Google sky point OEM HIDs with glovebox leveling arm after wishbone install / custom BMW round pin diagnostic to USB cabin routed laptop with INPA for constant CE light delete / sock modded / t-shirt mod / clicking sound.
Sure about that? I thought unhooking the battery discombobulate the radio or it's code, among other things?
If I remember correctly, the key is in the 2nd position and open the drivers door for 40 seconds. You should be able to confirm that in the DIY section.
You either have a bad new sensor or the rear brakes have hit the sensor. Light resets itself after a less than a minute with the key on engine not running. Check your work and make sure the connector is pushed together correctly.
Replace pads and sensors. The light will go away on its own after 30 seconds or so
Weird... I KNOW the rears are fine and the plug just plugs in. Shouldn't be rocket science here but the dang thing isn't turning off. Got the new sensor from BMW too... not a knock-off (unless they are selling them too! )
You may have to drive it to clear. I suspect 150-300 miles and the light will clear.
Send dabdibridgep a PM. I know he had this issue a couple of months ago. He drove and eventually it cleared. May be able to find out about how many miles until it cleared for him..
Turn key to accessory position (2), wait up to 60sec.
If light doesn't go out, something is wrong with your sensors.
Hi all,
Whilst driving home tonight I had the misfortune of going through a huge puddle which instantly lit the brake sensor light on the dash Only 3 weeks ago new discs and pads were fitted front and back and new sensors too , so I know all is well , however the bloody dashboard light wont go out
Any ideas anyone
Cheers
Daz
Bad sensor or an old worn sensor was used. Water get on a sensor that was not replaced and corroded it where it was worn down. Check the sensors.
Yep just replace sensor and turn key on and leave in the on position for a min. or so.
tmaxx445
2001 740i / S62 Swap / 6 Speed Swap / Titanium Silver Metallic / Grey Montana Leather / M Sport / Convenience Pkg / Heated Seats / PDC / MKIV Navigation / DSP / Bluetooth TCU / Dice Mediabridge / Vavona Trim / Illuminated ZHP Shift Knob / Short Shifter / Cat Delete / SAI Delete / Euro Tune / Koni Singles / H&R II Springs / Custom 3.15 25% Limited Slip Diff / Staggered OE M Parallels / 275 & 245 Firehawks / Euro City Lights / Celis Tail Lights / SunTek 70% CXP Tint
2005 M3 Coupe / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bluetooth / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / StreamLine Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / P0lar Tune / Koni Yellows / Eibach Springs / Staggered OE CSLs / 275 & 245 595 Evos / Angel Eyes / CF CSL Splitters / SunTek 38% Carbon Tint
2003 4.6is X5 / Stock /
Key in on position for about a minute did the trick, thanks guys.
Bump to say thanks for a helpful, if dated, thread. Put a new sensor on my wife's 330Ci tonight. PO had replaced pads but not the sensor and a light had been on recently. After changing the sensor out, light was still on. Found this thread. Key to position #2 and waited under a minute with the driver door open (no way for me to tell if that's required) and it went out. Thanks guys.
Same issue for me. Replaced with a Genuine OE sensor and light didn’t go out after many starts and hundreds of miles racked in one trip. Finally turned itself off after I replaced the washer fluid pump and jerry rigged a torn air intake boot. I didn’t have the key in so not sure why it went out on its own. Go figure.
