Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
Thread: Reversable armrest + USB
  1. #26
    Ellicott City, MD
    1994 e31, Porsche Macan
    Quote Originally Posted by Frankie View Post
    This is exactly how mine is secured too. But it still twists slightly when loaded on the driver's side. And it's the driver-side which bears the most frequent loads. Again, this is due to the geometry of the two off-axis tandem mounting screws, sandwiching the plastic console. Take a close look at my armrest installation:
    Loading the armrest directly over the console (passenger side, front to back) isn't much of a concern. But loading it over the unsupported driver's elbow portion creates off axis (left) twisting moments. This area - where the underside lock is located - will probably be used as a hand/elbow placement point when entering or exiting the car (this is how I use it). Creaking, squishing plastic sounds are the result.
    You no doubt noticed how stout the E46 mounting arm was before you cut it for your mod. You may have also noticed its third mounting screw location: off axis, to counter those loads.
    This would only brace on-axis loads. As discussed above, the concern is with off-axis loads, since the armrest's vertical mount does not span the full width of the armrest.
    I mention this not to be merely critical, but instead to offer constructive feedback based on my experience, and to address a potential weakness in gixxxer's bracket design due to its greater moment loading.
    Frankie....I love your setup. What is the plastic box with the cup holder from? It looks like it just replaces the existing ashtray/cubby box - yes?
    Thanks. Mike
    Life's too short to drive boring cars --
    • 1988 M6 (e24) - Zinnoberrot/Pearl Beige (sold )
    • 1994 850 Ci (e31) - Orient Blue Metallic/LtSilverGray
    • 2017 Porsche Macan - Night Blue Metallic
  2. #27
    Jan 2005
    Laurel, MD
    I miss my E31!!!!!!!!!!
  3. #28
    Ellicott City, MD
    Faisal....Thanks for the procedure link. I need to study that carefully before making a decision -- but an armrest is sure nice on long trips! Mike
  4. #29
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    Quote Originally Posted by e31gixxxer View Post
    Use the e46 cover trim part No. 51 16 8 218 307 (black), and remove the parts that don’t look like they belong in an e31. Use your best plastic welding skills and refit these parts you have cut off in to a different configuration until you have an e31 cover trim. Drill mounting holes and insert metal crush proof spacers.
    What is that cable running through the hinges seen in picture 4?
    Quote Originally Posted by rcrad6653 View Post
    I got these hinge end caps made by a well known member here..... I'll let him speak up if he'd like to produce more.
    Did he make more hinge end caps? How can I contact him to get some?
  5. #30
    Jan 2005
    Laurel, MD
  6. #31
    Dec 2012
    Palm Beach, FL
    Alpina B9 Trib, '91 850i
    Count me in as well please! Way out of my skill set (nee - none!)...
  7. #32
    Nottingham, UK
    E31, E36/7, E61
    That is for the USB sockets in the bit tray.
  8. #33
    Oct 2008
    liverpool uk
    koenig ks8 /e31 850c
    Quote Originally Posted by radlaw View Post
    I made them for him. PM if you need to.
  9. #34
    Nottingham, UK
    E31, E36/7, E61
    Here is a little update on this thread, evolution is inevitable.
    Firstly, the setup above worked fine for me with no issues.
    I did rework it a few years ago when I went for my double DIN setup and HVAC relocation. I think I documented it somewhere, but for the record I will put a couple of pics here before moving on to the MK3, which is essentially a MK2 with extra functionality. This won't be for everyone as the MK2 does require some one way mods. The structural integrity is as good as the MK1.
    MK1 bracket with modified mounting position.
    MK2 assembly ready to install.
    Mounting point for MK2.
    MK2 installed.
    At this stage we remember only 5 pictures per post. Lets see if we can double post.
  10. #35
    Nottingham, UK
    E31, E36/7, E61
    Yes we can.
  11. #36
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That's the best double-din conversion I've seen - and the armrest is a winner too!
    My BMW Repair YouTube Channel
  12. #37
    Nottingham, UK
    E31, E36/7, E61
    So on to the MK3, a MK2 with an extra USB for charging and a line in.
    Nothing ground breaking about a line in, but this allows me to connect an Astell Kern high resolution player directly to my external amps.
    The files are not compressed, lossy MP3s, MQS files in some cases. There is over 300GB stored on this AK70MKII.
    They are played with the AK DAC which is superior to the HU DAC.
    HU controls volume and track control is via the AK. The HU has track control functionality for Apple devices, but I am not an iperson.
    Navigation on the HU also runs with the line in AK operating.
    This works for me as this is my long journey road trip default option set to random. If I want to chop and change every 5 mins, switch to USB. The armrest lid does shut with the AK in it BTW.
    The sound quality is defiantly better on the AK via line in, when playing the same track simultaneously on the AK and USB and switching between inputs.
    Cheers Timm, you beat me to the punch line.
  13. #38
    Nottingham, UK
    E31, E36/7, E61
    Double DIN install from a while back, Kenwood DNX4210DAB, not a bad unit, but doesn't play FLAC etc. as most don't.
  14. #39
    Jan 2021
    Georgia
    95 e31, 11 f10
    Hello e31gixxer. By any chance could you repost the first set of pictures from page 1. I am currently in the process of doing the armrest mod. I already have the E46 armrest and will be doing a double din in the near future thank you in advance
  15. #40
    Nottingham, UK
    E31, E36/7, E61
    Hi Great8
    From what I can see the pics are still here in this thread.
    Gix
  16. #41
    Jan 2021
    Georgia
    95 e31, 11 f10
    Thanks for the response gixx, but on my end I’m unable to see any of the pictures on page 1
  17. #42
    Nottingham, UK
    E31, E36/7, E61
    The attachments are there and are visible once logged on. These are on the forum not on a host site like photobandit that removed over 10 years worth a while back?
  18. #43
    Jan 2021
    Georgia
    95 e31, 11 f10
    Ok thanks, Once I selected full site I was able to see the pictures.
