Results 1 to 25 of 44
Thread: General Module successful repair #2
    Dec 2010
    Tarzana, CA, USA
    1995 840Ci
    Talking General Module successful repair #2
    Special thanks to ah1cobra for spurring me to finally do this. Same electrical issues: door locks, trunk, windows, interior lights, etc. didn't work in the morning if it was cold. Took it to dealer with general module information from this forum and they DENIED it was the general module. Half a dozen shop guys there said it was the relay module, which they replaced for $450 parts and claimed they tested for 4 days. By chance I picked up the car on the coldest day of this year in S.Cal. (frost on the roof) and nothing worked just like before. Drove the car home and everything worked by the time I hit the driveway. Ordered the capacitors on line from www.Newark.com for about $6 and they arrived two days later. Pulled the general module (my 1995 840ci has the cartridge holder under the left side of the dash and removing two nuts on the bottom edge allows it to swing down enough to get the modules out), replaced the capacitors and everything is working great. Photos in ah1cobra thread were very helpful.
    The five capacitors from BMW have axial leads and are rated at -40C to +85C.
    10 microFarads at 63 V
    1 microFarad at 63 V
    47 microFarads at 25 V
    100 microFarads at 25 V
    470 microfarads at 40 V
    I replaced them with capacitors rated at -40C to +125C and with a higher voltage rating for the lower ones. These were a little larger than the stock versions, but fit fine. Probably last forever now.
    47 microFarads at 50 V
    100 microFarads at 50 V
    470 microfarads at 50 V
    Dec 2009
    MD
    91 850i
    Thanks for this post, what an easy fix. electrolytics typically have a 10 year operational life...and most probably less than that in an automobile application where summer temperatures and vibration can decrease their service life.
    1991 BMW 850i / V12 5.0L [M70] / ZF4HP24 E/H
    Oct 2008
    liverpool uk
    koenig ks8 /e31 850c
    Nov 2007
    Belgium
    Made in Germany
    koenig d: 140 for a general module that is probably not even refurbished? Besides, why pay for used or new if you can repair it almost for free...
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Great repair, well done!
    Castrovalley,CA
    420G SPEED 6
    Would the climate control fall into this catagory???
    san diego,ca, usa
    e36 m3,e30,e46,e32,e31
    please share part numbers of the caps
    mind sharing the part numbers from newark...don't want to order the wrong ones thanks!
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by german wannabe View Post
    What do you mean "part numbers"?
    Go to your local electronics supply house and ask for the following:
    • 10 microFarads at 63 V
    • 1 microFarad at 63 V
    • 47 microFarads at 50 V
    • 100 microFarads at 50 V
    • 470 microfarads at 50 V
    '93 850Ci - Mineralweiss Metallic
    ALPINA B7 -Alpinweiss III
    BMWCCA E31 Chapter President
    Dec 2010
    Las Vegas, NV USA
    1991 850i
    Make sure they give you axial capacitors.
    Dec 2010
    Tarzana, CA, USA
    1995 840Ci
    Glad to post the Newark Part numbers and some hints on the replacement procedure.
    www.newark.com
    Aluminum Electrolytic Capacitors, Axial
    Newark Part Numbers:
    #97C7972, 10 microFarads at 63 V, $1.14 each
    #14M8286, 1 microFarad at 63 V, $0.852 each
    #97M4027, 47 microFarads at 50 V, $0.163 each
    #75K6216, 100 microFarads at 50 V, $0.182 each
    #79R7674 470 microfarads at 50 V, $0.832 each
    Plus shipping. As I said before, they're a little larger than the stock ones, but fit in fine. There's lots of room away from the board and you just place the four that go together side by side.
    Remove the old capacitors by placing a hot, tinned soldering iron on one of the capacitor leads AND the pad below and use a pair of needlenose pliers close to the capacitor body to pull the lead out of the board. Pressure on the pad keeps you from ripping the solder pad off the board while you pull the capacitor lead out. If your iron is hot enough and you make good contact with the lead and pad, it doesn't take much force to pull out the lead. Repeat for the other lead to remove the capacitor. I then used a vacuum desoldering tool from Radio Shack to get the residual solder out of the hole (heat the pad with the soldering iron and then suck out the liquid solder). You can use solder wick too, which is copper braid that you just press against the hole with the iron on the back to melt the solder and wick it out. Then bend the axial leads sideways on the capacitor, slip them in the two holes (being careful to get the polarity right), resolder by heating each lead and the pad while you apply the solder, and then trim the excess lead off on the back side. Be sure to check that you made the solder flow down the lead so that it also wets the pad on the backside of the board. You can apply a little solder to the back side to fill it in if you need to. The board has some comformal coating on it that you can scrape off the pads if you want with an exactoblade, although the soldering iron does a good job removing it.
    Oct 2008
    KSA
    850i
    i had the same issue with my GM, fixed it and everything works perfect excluding the sunroof... rechecked all capacitors n solding but its fine.
    my GM is not the cars original one... n i heard i need to reset it so all functions work... can u guys tell me how to do that
    thanks
    Nov 2007
    Belgium
    Made in Germany
    Quote Originally Posted by zonixx View Post
    i had the same issue with my GM, fixed it and everything works perfect excluding the sunroof... rechecked all capacitors n solding but its fine. my GM is not the cars original one... n i heard i need to reset it so all functions work... can u guys tell me how to do that
    The A1 general module (GM) must be coded to your car's ZCS (central coding key). For this you will need a BMW diagnostic system (BMW NCS Expert or BMW Progman/SSS). Alternatively you can ask a BMW dealer to recode the module.
    PS: please stick to one topic instead of posting the same question in multiple topics
    Oct 2008
    KSA
    850i
    Quote Originally Posted by revtor View Post
    thanx for the help revtor n sorry for the multi posts.... my bad
    Apr 2008
    Seattle, Wa
    8'r
    Does anybody localy do this? MAX, Wuffer? I suck @ circuit board stuff.
    Mar 2011
    Damascus, Maryland USA
    E31/32/34 VWJetta A3TDI
    I've done a few of them, but I'm not local. If interested in mailing it out for a few days, PM me.
    Greater Seattle Area
    '93 850Ci,'01 X5
    Quote Originally Posted by dgoebel View Post
    www.newark.com
    Hi, So my Caps came in from Newark. Does anyone know which direction is postive on these caps? I have a feeling it's the shiny side besides the arrow point that way too, but before I solder these home I thought I'd ask.
    Redmond WA 98052
    1997 BMW 850Ci
    Arrows point to the negative (-) end
    Grooved end is positive (+)
    Apr 2006
    San Francisco Ca
    97 840c & 540I6 90 535im
    Revtor, I replaced mine from one I bought on ebay and everything works fine. What coding are you refering to?
    97 840ci-99 540i6-90 535i5 all black
    Nov 2007
    Belgium
    Made in Germany
    Bluesman: Sunroof, headlight washers, wiper pressure adjustment,...
    For example, if your car is equipped with sunroof and headlight washers, but you replace the A1 general module (GM) with one from a car without these options, yours will no longer work either. Simply recoding the GM to the car's central coding key (ZCS) fixes these issues. Of course, there isn't a problem if the car you took the GM from had the same coding as your car.
    This may be less of an issue in the USA where the coding diversity is much smaller than elsewhere in the world.
    Apr 2006
    San Francisco Ca
    Thankyou,that must be the case as everything works as it should.
    Mar 2011
    OT: The power supply in a Dell Vostro desktop quit powering on a few weeks ago. Fortunately, it was cyber monday, so new power supplies could be had pretty cheap.
    Today, after the power supply marginally passed the paperclip jumper test (LED went out briefly), I pulled the cover off the Hipro 300W power supply to find the 2200uF capacitors bulged and dried up..
    EDIT: Paperclip test is to grab the ATX connector, jumper the green (PWR-ON) wire to one of the black ground wires.. This fires up the power
    '94 525i, '89 735i, '91 850i, '81 MB 380SLC (For Sale), '00 323i -- Trying to collect them all, just need a 1 & 6
    Jan 2012
    Upstate South Carolina
    1996 840Ci / 2007 B7
    This is great information, as I'm looking to give this a try (stuff not working in the cold is driving me crazy) Does a more detailed writeup exist other than "get these capacitors and replace them where you see them on the board?" Do I need a more detailed writeup? (I haven't pulled the module yet) Many thanks for this info, guys.
    Mar 2011
    Quote Originally Posted by Spandrel View Post
    It's about that simple-
    However:
    1) Make sure the polarity matches the diagrams
    2) Use a hot/temperature controlled soldering iron; Not a $5-15 radio shack gadget. Invest in a $50/used $100 new soldering station; You'll use it for other BMW repairs.
    3) Be careful when removing the old caps, you don't want to pull too hard and damage pads/traces
    4) Be careful when reinstalling the new capacitors; I reworked one forum members GM that had a capacitor installed in the wrong place, and had a solder bridge a bad place.
    Jan 2012
    Quote Originally Posted by EEDegreeToDrive View Post
    However:
    Thanks! - Caps on order, we'll see how well I execute the repair soon.
    Colorado Springs, Co.
    1997 850Ci
    All I can advise is remove the knee bolster, it'll make removing the GM sooooo much easier. There are several write-ups about it, should find them fairly easily searching.
    I'm not saying you're stupid, I'm saying you have bad luck at thinking.
    '05 Saab 9-3 Aero; '80 Bradley GTE, 96V electric; '64 Falcon 'vert;
    '78 Glastron/Carlson CV23 '96 K2500 Suburban; '88 Suzuki Intruder 1400
