Results 1 to 11 of 11
Thread: No more creaking noise
    OKC, OK - Derby, KS
    740i, 330i, A6
    I was getting a creaking noise when I turn the steering wheel and brake at the same time. I thought the noise was gone after I replaced the traction strut bushings but the noise came back today.
    After researching this site and others I decided to grease the center link joints and tie rod end joints. The joints were much too dry and the grease was kinda sticky. ds
    I greased each of the four joints and took it for a test drive and the noise is gone plus it seems easier to steer.
    Kind of a pain to remove and install the ring around the rubber seal (large one).
    Arizona
    2000 BMW 540i Sport
    Really? Thats it? I just installed entire front suspension and I have a similar noise including center link. Ahhhh
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    ya thats the trade secret..Anti seize the tie rod ends of the center link and there is no chance of the creaky sounds
    2000 740i Sport
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    Ehh I think I mentioned this before guys and also posted it in the DIY section
    Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
    OKC, OK - Derby, KS
    740i, 330i, A6
    Quote Originally Posted by Edwin NL View Post
    That you did, and I appreciate it very much.
    Aug 2008
    Cary, NC
    2001 740i
    Can you post a link to the DIY for this? Can't find it.
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    Top of the page!
    Common problems and DIY fixes!
    Dec 2010
    L.A, CA
    2001 740iL
    yap, got it. Thanks Ed!!!
    Mar 2010
    alpharetta, GA
    83 244 Turbo
    my car has a creeking noise, but it is coming from the steering wheel where as it sounds like you guys are having problems with suspension components. Is my problem caused by a worn "O" ring, or does it have something to do with the steering column?
    any help is appreciated
    P.S. I haven't seen anything on e38.org, or in the DIY section about the steering wheel making this noise.
    meteck's Avatar
    meteck is offline Houston CCA Houston 7ers BMW CCA Member
    Alvin, TX
    1997 BMW 740iL, 2011 528
    It's the slip ring under the steering wheel.
    Totally stock 97 740iL except for SatRad
    Mar 2010
    alpharetta, GA
    83 244 Turbo
    Quote Originally Posted by meteck View Post
    So the slip ring is number 2 in this diagram right? I have a heated steering wheel too, so would I need a special slip ring, or are they all the same?
    sorry for the somewhat noob-y questions.
