Page 68 of 69 FirstFirst ... 1843585960616263646566676869 LastLast
Results 1,676 to 1,700 of 1720
Thread: The definitive E36 LTW Spoiler Replica Thread
  1. #1676
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    Quote Originally Posted by red911turbo View Post
    You would take the daro-sport wing over this one?
    I wouldn’t take any of them.
  2. #1677
    Sep 2002
    Vancouver
    98 M3
    Quote Originally Posted by busterhax View Post
    This. If the only option you can find is garbage, just go without.
    Driftshop is the only decent looking/fitting cheap rep.
    MAshaw is the bare minimum for quality I'd be willing to drill some holes and spend some money on paint for.
    - 98 m3, techno/anthrazit cloth, 124k and officially worthless - 89 m3, alpine/black 143k and officially old - 2000 323it, tiag/grey, 169k and officially boring
  3. #1678
    May 2021
    Sunshine Coast, Australia
    1997 BMW M3 TechnoViolet
    Pics as promised (well overdue), definately does the job for me due to limited options in AUS, except the riser hole spacing. Will update if any issues in the future.
    Posting for research and info purposes, but hey let me know what you think
    Cheers,
    Sent from my SM-G991B using Tapatalk
  4. #1679
    Dec 2003
    VALLEJO
    Boring E36
    I need the install kit. I can't find it anywhere lol. HELP!
    U MAD?
  5. #1680
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Quote Originally Posted by LWRNCE View Post
    I can order you one. Message me.
  6. #1681
    Nov 2003
    VA
    1997 M3/4/5
    Is there a kit for the sedan?
  7. #1682
    Connecticut
    '98 ti (M powered)
    The base is different but I don’t know if the install kit is. Probably not.
    I still have my templates and other bits that came with mine.
  8. #1683
    Aug 2003
    USA
    E36 M3, 11 X5d, 16 F31
    The sedan kit (which is different from the coupe kit) has been discontinued for quite a while. However you can piece it together with the exception of the clear adhesive protection strips of which I believe one is discontinued.
    You can buy your own double sided adhesive 3M tape.
    07 11 9 915 031 (x4) Hex bolt with washer M6x20-Z3
    07 11 9 900 678 (x2) Hex socket head screw with washer M6x20-Z1
    If you buy the protection strip that is available you can probably have someone just mirror that for the other side or make you a new set etc....
    BMW tightening specs is 9 Nm. So don't go "nuts" tightening those.
  9. #1684
    Nov 2003
    VA
    1997 M3/4/5
    Thumbs up
    Thank you
  10. #1685
    Connecticut
    '98 ti (M powered)
    "But this one goes to eleven."
    "Speed's just a question of money. How fast you 'wanna go?"
    PM me for E36 engine swap books and BMW ETMs! NOW SHIPPING!!!
  11. #1686
    Connecticut
    '98 ti (M powered)
    I wanted to mention that what I did for my upper SHCSs (attaching riser to underside of wing), I ordered a box of fasteners and washers from McMaster-Carr in stainless steel. 18-8 is sufficient, but 316 is more corrosion resistant for a bit more money.
    You could also go with an internal Torx fastener, for more theft resistance; however I've found a ball end hex driver socket to be the best way to deal with these, due to clearance issues.
    My originals got a bit rusty on me...
  12. #1687
    Oct 2022
    NorCal
    1995 Mugello Red M3
    I've read through a lot of this thread and I know it's a risk getting the ABS eBay wings (most likely mfg in China). Still was curious if anyone has had recent luck with the Gloss Black versions that have popped up on eBay. For $200-250 I'm considering taking the chance on one as I wouldn't need to paint it. Would be going on a car that would see track time and is not the cleanest cosmetically so I'm not too worried about very perfect fitment. Really just want the wing for cosmetic purposes to balance out some other mods I'm doing.
    Here's some examples:
    https://www.ebay.com/itm/225169105874
    https://www.ebay.com/itm/304608119699
    https://www.ebay.com/itm/325318359175
  13. #1688
    Connecticut
    '98 ti (M powered)
    For the track you really want a properly designed wing. It could hurt handling more than no wing if it’s not functioning properly.
    And when I last looked, only the base of the wing was not available- the top “wing” itself happened to be available. Might be worth checking with the dealer…
    And in all cases, (per BMW) the rear wing should not be installed without at least the front air dam extensions. Better to have the full splitter, but do not run the big wing without an air dam. Air can get under the car at speed.
  14. #1689
    Oct 2022
    NorCal
    1995 Mugello Red M3
    Understood. I am planning to run a splitter as well.
  15. #1690
    NY
    skateboard
    Quote Originally Posted by m3ugello View Post
    I’d strongly suggest getting the Rieger front splitter. Really strong.
    ― George Orwell
  16. #1691
    Connecticut
    '98 ti (M powered)
    The factory adjustable splitter is also available currently...
    photoupload
  17. #1692
    NY
    skateboard
    I ordered one of those, and arrived damaged. The Rieger has held up great over a year.
    Plus so much less involved for install.
    ― George Orwell
  18. #1693
    Oct 2022
    NorCal
    1995 Mugello Red M3
    New shoes installed, only thing missing is wing. I think black will look nice.
    https://i.imgur.com/dISbnIM.jpg
    Quote Originally Posted by GG///M3 View Post
    I was looking at these, where did you order? I saw the Racegerman one too, looks nice.
  19. #1694
    NY
    skateboard
    https://www.ebay.com/itm/13208527217...mis&media=COPY
    ― George Orwell
  20. #1695
    Dec 2002
    Broward, FL
    I take the bus to work.
    Quote Originally Posted by tiMASTER View Post
    photoupload
    info? I thought this was NLA
    -M3J0N
  21. #1696
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    Quote Originally Posted by m3j0n View Post
    Splitter has always been available.
  22. #1697
    Connecticut
    '98 ti (M powered)
    It goes in and out. I have seen it out of stock several times over the last 20 years.
    That’s why the people in Latvia are reproducing the mount brackets. The tray itself is *usually* available but not the brackets and hardware.
  23. #1698
    Texas
    E36s
    I still have a new unpainted/unprepped MAShaw wing for sale if anyone is interested. It's just taking up space in my closet at this point.
  24. #1699
    Apr 2022
    LA,Ca
    95 M3
    how much
  25. #1700
    Oct 2022
    NorCal
    1995 Mugello Red M3
    Quote Originally Posted by JamesL71 View Post
    I am interested but cannot send you a PM
