Page 1 of 4 1234 LastLast
Results 1 to 25 of 85
Thread: 320is Diff Rebuild (Pic heavy)
    Mar 2010
    Gilbert, AZ
    99 528i, 94 V-Max
    Rebuilding a differential is not as complex as one would think and with a little patience and the proper tools/techniques, it's something most can accomplish on their own. The diff I'm doing here belongs to Crusty320. It's an LSD unit from an 83 IS, but I won't be getting into the clutch packs or replacing the gears on this one, it'll be a bearing & seal rebuild only. The steps are essentially the same whether it's an open diff or LSD.
    The diff in question
    First order on business is to drain the old oil and remove the cover. If possible, before you pull the diff out drain & refill with ATF and drive it around the neighborhood for a couple of laps, keeping it under 25 MPH and then drain out the fluid. This will help flush out some of the crud that has built up over the years and make for a cleaner teardown. This one came from a donor vehicle, so the ATF wasn't an option.
    Next step is to pop the drive flanges out. Use one of the bearing cap bolts as the fulcrum for the prybar and give a little pressure. The flanges are held into place by circlips insinde the carrier assembly. If you find yourself struggling, get a second prybar for the opposite side.
    Next step is to remove the 6 bearing cap bolts on each side
    Now is where finesse comes into play. Using a hammer & chisel, coerse the bearing cap away from the housing buy working it a little on each side, just enough to get the tip of your prybar into. If you look closely, you'll see 2 chisel marks on the bearing cap and 2 on the case. The opposite side has 1 mark each, this way they go back to their respective sides.
    This is where you'll probably need 2 prybars. The best method I found is to hold even pressure with one prybar and then sort of bounce the other one to remove the cap.
    With the cap removed, you can see bearing shim.
    KEEP THE SHIM WITH THE MATCHING CAP!!!! I used mechanic's wire here because I didn't have any zip ties handy.
    Once both caps are off, the carrier assembly falls right out.
    Now remove the lock plate and pinion nut. A flat blade screwdriver or thin chisel works to remove the lock plate if it's not too rusted.
    This is where you need access to a press. It can also be done with an air hammer using a punch bit. DO NOT use a flat hammer bit, you WILL mushroom the threads and then you'll need to replace the ring & pinion as well $$$$$$. If you have a large brass hammer, you can use that without the risk of thread damage as brass is softer than hardened steel.
    Chuck the housing up into a vise and remove the input seal.
    If you don't already have one, you can rent a slide hammer from your local parts store to remove the inner races.
    After 30+ years, the races don't want to go easy. This one practically took an act of God to get out. I ended up have to cut slots into the races with a cut-off wheel, heating it in the parts washer and then hitting the races with ice to get them to free up enough to move with the slide hammer.
    Finally, the parts are ready for a good, long spin in the parts washer.
    The basket holds the hardware so they don't go all over when the jets hit them.
    Next update will be in a few days when I get the gaskets, seals & bearings. That's when the real fun begins. Stay tuned!
    Quote Originally Posted by Tom D View Post
    throttle lift oversteer is a way of life and should be celebrated. there are few things as much fun as steering a car through a corner with the throttle.
    He who dies with the most unfinished projects wins
    Minneapolis, MN
    1996 328is, 1970 510
    keep the pics coming, this is really rad!
    Feb 2009
    District Fifty
    78 BMW 320i
    Staying Tuned!
    Smoothe move on that race, I'da probably gone crazy trying to cut all the way through it and goof up the housing
    If you're trying to make me feel better about this scenario, give it up....
    May 2009
    costa del scotland
    e36 318iS
    thanks for the guide, i am about to embark on rebuilding an E36 M3 diff and couldnt find a guide anywhere
    SF Bay Area
    '78 320i M42
    how much do all the seals and bearings cost?
    May 2009
    costa del scotland
    e36 318iS
    Quote Originally Posted by bflan2001 View Post
    these are for the input shaft on an euro E36 M3
    http://bmwfans.info/parts/catalog/E3...n_gasket_ring/
    and this is for the output shaft on a euro E36 M3
    http://bmwfans.info/parts/catalog/E3...ension_gasket/
    prices may be a bit higher due to the M tax
    Boston
    1979 323i BMW. 2003 GTI 20 V Turbo
    Cool. I have a 3.91 diff that I was thinking about sending out to Quaife for a rebuild.....but this is inspiring...
    "..Horsepower is a measure of work done over time, or the rate at which work is done."
    http://www.cardomain.com/ride/579694/1
    Northern Michigan
    83 320 98 318ti MSport
    I can put together a list once completed. I've looked at: Pelican Parts, BavAuto, AutoHausAZ, and the dealer.
    The inner pinion bearing (33121206739) is 'dealer only' and looks like it's about $50. I'm also going to order the crush sleeve $3(33121200259), and gasket/seal kit $80(33101203002) through the dealer.
    The other 3 bearings can be sourced through the sites above at about $13 each for the output bearings and $19 for the outer pinion bearing.
    Mar 2010
    Gilbert, AZ
    99 528i, 94 V-Max
    Quote Originally Posted by epmedia View Post
    Staying Tuned!
    Thanks! If you're handy with a mig or stick welder, you could run a bead on the wear surface of the race and when it cools, it should coume out without too much fight.
    Nov 2005
    Mills River, NC
    '82 E21 320i
    Quote Originally Posted by Toyotech View Post
    I busted the tips off two flatheads.
    I bought the complete seal kits from bavauto for $81.
    Includes input/output seals, carrier O-rings, rear cover gasket and fill/drain crush washers.
    Eric P.
    SF Bay Area
    '78 320i M42
    yikes, that's a pretty penny for seals and bearings! cheaper than a new diff though i suppose
    Manila, Philippines
    Duke - '82 320i
    '00 528iT
    ^ +1. You might clarify pic 11 though, I'm not sure what the lock plate is. I'm sure I could figure it out if I had it in front of me, but it's not obvious from the pic.
    Mar 2010
    Gilbert, AZ
    99 528i, 94 V-Max
    Quote Originally Posted by fullswing View Post
    FAQ-worthy
    Thanks, that's kinda the goal.
    Quote Originally Posted by RedLantern View Post
    Yeah, I actually had to take that one with my phone as I didn't have my camera with me when I started the teardown on Thursday. I partially reassembled to unit the next morning so I could get some better pictures with my camera and I already had the pinion out. When I do the final re-assembly, I'll change the picture and add a couple others for the teardown part.
    Nov 2005
    Mills River, NC
    '82 E21 320i
    Lock plate: This PITA. I busted two flat-tips trying to pry it out.
    So I went this route ...
    Eric P.
    CT USA
    1982 323i Baur & 6 more
    Toyotech, this is a great thread. Thank you. I am not nearly ready to do this, but, if I do, this will be invaluable. I am with jimbo.... I do think it is FAQ-worthy.
    Tom
    SE Connecticut
    1982 323i Baur, 1977 320i (carbed),
    1978 320i (parts)
    1991 325ix 5 speed, 1989 325ix (winter),
    1989 325ic (summer)
    1973 2002 Malaga (with frosting)
    1975 Mercedes W115 300D (The Departed)
    the late 1979 323i Euro (project, Now Departed)
    Visit my blog: Baurspotting
    http://baurspotting.blogspot.com/
    BWR PWR!
    Ohio
    E21 320i, e39 540i/6
    wow, great thread. Thanks Toyotech! I'm gearing up for a refresh on my 3.45 open to LSD conversion this spring. I have a seal kit (from bavauto), and new friction plates, clutch disks, and belleville washers for the LSD unit (from Maximillion). This thread will come in handy.
    The LSD rebuild parts cost about $250 from Maximillion Importing. I went with the thickest of the 3 friction plate options hoping for a little more lockup. If it were me and I was going to do full rebuild (new bearings, etc) I'd buy the bearings, crush sleeve, and any shims, if needed, from them.
    Pinion Components
    Output Bearings/shims
    LSD Components
    I'll add this to the faq.
    '81 320i turbo | t25, 931 CIS, 250hp, 13.92@100mph | 2.2L m10 Turbo Build | My E21 Videos |
    Finger Lakes Region
    '79 320/6
    JR,
    Let me know how that goes! I have the '80 with the original 3.45 open and I'd LOVE to rebuild her with an LSD. I have that diff and the one off the '82 to mess with.
    I still drive daily with no commute...
    The Hazard is All, Praise the Hazard!
    Feb 2009
    District Fifty
    78 BMW 320i
    Hey, that lockplate is similar to the one on the tranny output flange.
    I removed one by holding the flange, and then just unscrewed the nut.
    Mar 2010
    Gilbert, AZ
    99 528i, 94 V-Max
    Reassembly!!!!!
    The reassembly stage. This is where all the prepwork and orginization comes into play for a smooth process.
    I guess I didn't remove the pinion or diff side bearings in the first part
    Basically chuck it up in a bearing plate and press the pinion out of the bearing.
    You want to remove the cage and the rollers from the bearing for the next step
    Slide the new bearing onto the pinion and then invert the old bearing race and slide it onto the pinion as such. DO NOT apply any pressure on the bearing cage or rollers, you will damage them and will render the bearing usless. To ensure I don't have any issues, I always spin the cage & rollers with my fingers while I'm pressing the bearing on to make sure I'm doing it right.
    While you have the cut off wheel fired up, remove the cage and rollers from the carrier side bearings
    Set the bearing plate tool onto the ridge and press the races off of the carrier. The other option is to cut a slot into the race and use a chisel to split it.
    Press the new bearings onto the carrier just like the pinion by inverting the old race and using it. Once again DO NOT apply pressure to the race.
    All painted and ready to put back together
    Drive the new races into the housing. If you put them in the freezer for about 30-40 minutes, they'll shrink up just enough to ease the install.
    Set the new bearing in and then the new seal
    Drive the new races into the side covers
    Using one of the old diff side bearing races, install the new seal
    New crush sleeve
    Now is when you get really crafty and build yourself a flange holding tool. Mine is an actual Toyota SST, but you can build your own using some flat bar stock (at least 1/4 in thick) with a couple of holes drilled into it and some bolts.
    I hope you ate your Wheaties for the next step! The new crush sleeve is a MAJOR PITA to compress. Get your biggest breaker bar and possibly even a cheater pipe to tighten the nut to compress the sleeve. After the first 3/4 of a turn, it gets easier but you'll definately work for it!
    You'll know when you have it compressed and the bearings seated when it goes from sorta easy to very tight all of a sudden. That's when you want to stop and check turning torque.
    You'll need a 1/4 drive beam torque wrench for this. BMW spec is 21 in/lbs of "turning friction"
    After you do that, install a new lockplate and the pinion side is all set.
    A little grease on the housing to help slide the side covers into place
    New o-rings on the covers
    The observant ones are wondering where the shim I had tied onto the covers went to. Remember to always keep things marked somehow.
    2 metal wires..
    Remember the 2 marks I put in the case?
    Ready for the final check
    You can go spend $5 on a tube of gear marking compound or reach across your workbench and grab the tub of lithium grease. Paint a section of the ring gear with it, at least 4-6 teeth, getting down into the crevasses. Now, while applying pressure on the ring gear, spin the pinion gear through 1 rotation of the ring gear and then back the other way. Do this a couple of times and check the wear pattern If you've done it right, it should look like this:
    Even wear pattern on the drive side as well as the coast side of the gears
    Install the output flanges and your nicely painted (or bead blasted in this case) diff cover using a little permatex spray-tack to hold the new gasket into place. Once it's back in, fill it and drive it for 300-500 miles and check for leaks.
    Here's a list of parts and prices.
    Mosjoen, NORWAY
    1979 Karneolrot 323i
    Great write-up! Thank you very much!
    Boston
    Excellent pics, thanks.
    Question: Do you want to rebuild my LSD? Let me know....
    MI
    1981 E21
    great thread, very detailed!
    Mar 2010
    Gilbert, AZ
    99 528i, 94 V-Max
    Quote Originally Posted by jjgbmw323 View Post
    PM sent
    Nov 2008
    New York
    '82 528 '83 633
    Thanks for posting this. It looks fairly straightforward, but what happens if the turning torque or gear contact pattern aren`t right? If a diff feels like it has excessive slop in the gears, can that be improved by replacing bearings or shims? Or does it mean that the gears are junk?
