Results 1 to 11 of 11
Thread: how to fix sagging sunroof handle
    warwick RI
    E30/E32/F25
    so i own 2 bmws with crank sunroofs and my e30 had this same problem...so i figured i do a little easy how to on fixing the very common sagging sunroof crank handle ....basically what happens over time is the metal eventually gets pushed away and wont hold the handle in place anymore very easy to fix:
    if you can see in this pic there is a small round divot in the side of this metal this is what holds the handle up
    there is a round ball that slides into each divot and holds the handle up snug
    all you need to do is take the 2 ends of the metal and either take a pair of pliers or put it in a vice and push it back together and your handle will hold nice and snug again!!
    push ---> <--- push
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
    Feb 2009
    District Nine
    sold 78 BMW 320i
    That's fantastic!
    I wish i would have done that before using loc-tite "red" on the handle screw
    Tbd
    Jun 2010
    Denver, Colorado USA
    1983 BMW 320i
    Sigh... Thanks, can't wait to fix that.
    Sep 2012
    Pacific Northwest
    Thanks for this easy fix.
    And you just saved me from trying to hunt down a good handle unit in the junkyard.
    PA
    Alpine x 2
    good info man thanks!
    I hang my sunglasses from the crank so I bet it will start to sag eventually. I just purchased a new one not 2 years ago.
    E21 LEGION INT'L | NORTHEAST CHAPTER
    Bleed Green
    Jan 2012
    Woodfin, NC
    (2) '83 320iS, '97 528i
    Great how-to and thanks for crossing the border into e21 Legion country to share!
    "The water was not fit to drink. To make it palatable, we had to add whisky. By dilligent effort, I learnt to like it." Sir Winston Churchill
    Mar 2010
    New Orleans, Louisiana, USA
    1-1982 BMW 320i
    So I just bought a new crank handle from AutohausAZ and have had a hell of a time putting it in. It just will not go all the way through. Is there any trick (position of the sunroof and crank) I do not know of? I've inspected carefully and it's the same exact part. I have a feeling this is one of those things that only experience tells. Thanx.
    Apr 2012
    Gresham, Oregon, USA
    '10 X5 35d
    What is the issue? Is the not seating?
    I think the basic instructions are: Line up the flat sides of the shaft with the handle, then line up the plastic "flange" parts and press it home, install screws.
    Current: '10 E70 X5 35d | All my e21 parts are for sale!
    Prior: '82 E21 320i | '80 E21 320i | '72 E3 Bavaria | '98 E36/5 318ti | '06 E46/2 325Ci | '83 E21 320iS
    Mar 2010
    1-1982 BMW 320i
    It's just not going through. I really don't want to break it by forcing it too hard. I guess my old part came out easily and is going back in easily because you can tell it's really worn. I'll continue trying today. I also thought that maybe both parts had to be in certain position for them to fit just right.
    Quote Originally Posted by edennelson View Post
    Jun 2001
    NJ
    '01 M5 '82 320i
    I had the same problem. There are aftermarket crank handles made in India IIRC that don't work, period. I spent the extra few bucks and bought an OE handle that fit perfectly.
    Mar 2010
    1-1982 BMW 320i
    Got it! Did a little bit of filing and tapped it in until it went through. Works and looks great! Gettin there - slowly but surely.
