Hello,
I have an unknown number from my manual gearboxwhich is 1221936.9, and its mounted on M50 engine, I need its part number cause I want to order an overhauling kit for my shifter. I bought my 525i 92 last year and it was converted to manual transmission so my VIN # is useless. Can anyone help ??
I found this... http://forums.bimmerforums.com/forum...d.php?t=499660
Can you post a pic or two? It's either a ZF or a Getrag and they are easy to ID just on looks alone.
Edit: It's a ZF... those are the numbers on my trans.
Actually I should clarify... This is a ZF310z which is rated at a slightly less torque rating than the m3 trans which is the ZF320z. Virtually identical. The m3 variant has a reputation for sticking in 5th. For the the m50 e34 application the 310 is fine. The ZF has traditionally been a stronger trans than the Getrag, but both are fine.
Thanks for more clarification, I appreciate your help mate,,
The 310 also came on s50b30us equipped 95 M3s.
1983 636csi
1988 M5
1991 850i
