Results 1 to 11 of 11
Thread: Best way to test a motor that has been sitting for about a year?
    Chicopee, MA usa
    1998 M3 TURBO
    So I did a compression test on this motor I picked up. It was kind of all over the place. I wasn't sure that cranking the motor over like that would properly lube the rings and obviously the motor is cold. My numbers as started from front to back originally were:
    1- 205
    2-205
    3-180
    4-195
    5-190
    6-150
    I then took a little oil and squirted it down # 6 and it jumped right up to 210. I then put a little oil down all the cylinders to try and keep them lubed while the motor sits. Copression tested then again and they were all 210 except #5 was still 190. So I was thinking about selling this complete motor but I want to make sure 100% that it's perfect before I do. If not I'm just going to build this motor for boost and part out my partially blown motor. What do you think? Should I do a leak down test too? Will that give good enough results on a cold motor??? And no I don't feel like putting it in my car and running it =). I would just build it for my turbo motor. As a side note a member on here sold this motor to someone else about a year ago and said it was a strong motor but gave compression test results of 180 across the board. The person I bought it from never even touched it or started it since he bought it.
    ICS Stage 1 NickG tune, 60lb Injectors, Blow through MAF, Synapse BOV, Boostlogic Manifold, BW-S366, Full 4" exhaust, Built Block w/ Wiseco's and K1 Rods = Good Times
    NY
    skateboard
    I was watching a show on some guy who goes around buying up classics, and what I seen him do was spray wd-40 down thru the spark plug holes. Then turn the crank to lube the cylinder walls. Then start the car. Is the motor in the car? Edit: he turned the crank by putting the car in 4th gear then pushed the car abit.
    ― George Orwell
    Chicopee, MA usa
    1998 M3 TURBO
    No the motor is not in the car. It's sitting in my garage next to my car, that currently has a half of motor in it. I'm not so worried about keeping it lubed now because I will be making a decision shortly to either sell it or build it. I guess what I'm asking is how to test a cold motor and be sure it's good , or be sure it's not good.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by e36ALPINE View Post
    1- 205
    2-205
    3-180
    4-195
    5-190
    6-150
    Compression #s will vary according to throttle opening, cranking speed and cylinder lubrication.
    Your engine sat a while so little lube on the cylinders. The #s came up with oil and all the #s are acceptable.
    A leakdown will tell you more but it sounds healthy to me.
    EDIT; Whhops, saw # 6, it deserves investigation. Maybe a ring is a little sticky
    Chicopee, MA usa
    1998 M3 TURBO
    Quote Originally Posted by ross1 View Post
    Yeah, maybe it was stuck but ever since I put a little oil down it's compression numbers are 205-210. I was a little more concerned about #5 that stayed at 190psi?
    Joliet, IL
    Out of Service
    Can you explain how exactly you did this test with the motor out of the car?
    Chicopee, MA usa
    1998 M3 TURBO
    I ran jumper wires from another car that was running , to the starter on the motor.
    Dec 2010
    Ottawa, Canada
    1995 BMW 325ic
    Your compression in #6 is very suspicious. If you wanted to use this motor, you could use our ceramic treatment and raise its compression back up probably above 190, the rest of your cylinders I would expect to go at or above 200. It will last you tens of thousands of miles before you need to reapply it.
    We've done numerous compression tests using our treatments with good results. Look at the stats on this page: http://rvsmaster.com/research.html
    In particular, scroll down and look at the tests done by Instyle Auto and Precision Auto Tech.
    RVS Master
    ceramic nano-coatings
    service@rvsmaster.com
    Toll Free - 1-800-440-7970
    Create a layer of protection in your:
    engine | trans | diff | turbo | SC | firearms
    <a href="http://forums.bimmerforums.com/phpads/adclick.php?bannerID=219&amp;dest=http://www.rvsmaster.com/"><img height="60" alt="RVS Master" src="http://images.bimmerforums.com/banners/rvsmaster.gif" width="468" border="0" /></a></p>
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by RVS Master View Post
    Intersting info here;
    however,
    ALL of his numbers are suspect seeing that he did not do his compression testing with a warm/hot engine.
    His #6 rings may have had "shrinkage".
    Chicopee, MA usa
    1998 M3 TURBO
    If there is no way to tell 100% that the motor is perfect testing it cold then I'm not going to sell it to anyone. I'll just use it myself and part my other motor out. I may try a leakdown test and another compression test , or I may just start taking it apart to go to the machine shop.
    Dec 2003
    Elwood, Illinois
    5 Series Sport Wagon
    Being I had zero (yes zero) compression on all cylinders ,and it leaked 100% on all cylinders. I squirted some oil in the cylinders on my 525, started it and now it has 170 on all cylinders hot or cold. I would say you have not a problem with that motor as far as compression goes. Oh yeah the 525 has 150,000 miles on it. I accidentally washed the cylinders on a cold start flood situation. ///J.T.///
    Lot's of new stuff hope it stays together a little longer. LOL
