Results 1 to 25 of 25
Thread: Full Auto PDF's
    Belfast,Maine
    1998 328iC
    Exclamation Full Auto PDF's
    Here are 4 TIS documents that I converted to PDF format for my fellow vert brothers to use.These all relate to '97 and up fully electric tops.This stuff is not in the "Bentley".This has to do with front top locks and motor,plus complete microswitch troubleshooting.Hope they are useful to you all!
    Attached Files Attached Files
    Florida Panhandle/ Ohio
    14 JGC/13 E88 128i
    Palamino should think about sticking this in the top section to aide those that need this help.
    What do you guys think?
    USA
    one
    I second the motion.
    UK
    1998 328 convertible
    Jul 2004
    Around
    E36, F10, W205
    Quote Originally Posted by fun2drive View Post
    Palomino thinks you should take her spot as a mod.
    I'll sticky this now.
    Apr 2008
    Solomon's Island, MD
    M3, M5, M6, 850i 6MT
    Quote Originally Posted by Joylove View Post
    Here's a full overview of how the system works. Although the filename is the same as the one in the first link, it is not the same document.
    Nice. This is helpful information. I've had my 1995 325iC since 2004 and have never seen this PDF before. Thank you!
    1988 BMW M6 coupe -------Cinnabar Red
    1995 BMW M3 coupe -------Cosmos Black
    Feb 2008
    SoCal
    '95 M60B40
    This is great PDF's and thanks.
    I posted in the vert section and no reply. I tried to re-set my A & B motors. "A" motor re-engaged completely. "B" motor unable to re-engage. I did not proceed to the Top-close switch yet until my "B" motor re-engages.
    Please help. This is my daily driver and I can't afford the stealer or indy at this point.
    1995 M60B40
    The Netherlands
    DE-spec E36 328i/M3 cab
    I found this document I never found before. It's by far the best and most comprehensive roof doc I have found so far.
    There is one drawback however, although not for me personally. It's in German.
    CLICK HERE
    IG:
    Feb 2008
    SoCal
    '95 M60B40
    Quote Originally Posted by MParallel View Post
    CLICK HERE
    Thanks.
    I need to close my top (full automatic) manually. I know it involves a lot of cranking so if you can tell me which way to crank it so I won't waist my time I would appreciate it. Also, there is an opening in the middle of the front end of the top that is covered, is that where I do the cranking?
    1995 M60B40
    The Netherlands
    Leftly loosy, righty tighty.
    So when you sit in the car, you turn the crank counter clockwise to open the top.
    This is all explained in your owners manual as well, which I'm sure you don't have
    There is a small cover that can't be missed, behind which is the socket for the allen key.
    And yes, you have to do LOTS of turns, as the electric motor spins very fast and even then it takes quite some time for the front to come up from the windshield. So having to do this by hand, takes long to do. So don't think too soon that you are doing it wrong.
    Luckely I've never had to use it *knock on wood*.
    IG:
    Feb 2008
    SoCal
    '95 M60B40
    Thanks Mparallel!
    My senses tells me that I will need to close the top all the way to help the re-engage the "B" motor once I put the top entirely down.
    Top is closed, finally!
    Will I be able to snap in both A & B motors in this position?
    1995 M60B40
    The Netherlands
    Should be possible now. You may have to slightly turn the gears in case they don't mesh right away.
    IG:
    Feb 2008
    SoCal
    '95 M60B40
    Sorry I wasn't very clear.
    Now my top is up and locked and both A & B motors are dis-engaged. Will I be able to re-engage both motors while the top is in this position?
    1995 M60B40
    The Netherlands
    You were perfectly clear and is exactly to shag I answered.
    IG:
    Feb 2008
    SoCal
    '95 M60B40
    My top is working again.
    MParallel, you are an asset in this forum... thank you sir.
    1995 M60B40
    The Netherlands
    Quote Originally Posted by astigracing View Post
    Ha no problem.
    I see I screwed up my previous reply a little with the "shag" (!?) which should be "what".
    But I just got an iPhone and I'm not used to type on a small touchscreen keyboard.
    IG:
    SF Bay Area
    98 M3 vert, 05 X5
    CLICK HERE
    Oh, to find an English translation! Any ideas? That looks like an amazing document....
    Shizzam!
    Phoenix,Az
    98 M3 vert
    Quote Originally Posted by M3rocket View Post
    Yo use Google Translate!! I used it to get what I needed and it is one hell of a read. Like talking to a 2 yr. old
    Croydon Park Australia
    BMW 328 conv
    Go to www.moskopp.com (1) Click on "downloads" (2) Click on "tutorials und howtos" (3) The very first one is the download you want (4). After downloading and saving it (5) get it translated by Bing, Google or what ever translating progam you want to use (6).
    cheers,
    jopham
    Mar 2012
    Trumbull, CT
    1999 BMW M3
    Thanks for the detailed info on front motor adjust and replace. I have this scheduled as this weekend project and now feel a lot more confident I will replace the motor correctly.. Kudos!
    Jul 2017
    germany
    bmw
    i have the same problem and i kannot re synk the motors while the Top is Down...
    Apr 2023
    Raleigh, NC
    1998 BMW 328i Cnvrtble
    That great German doc translated
    But I can't seem to attach the file.
    Just use Google docs and hit the translate button. It worked really well.
    Apr 2023
    Los Angeles
    BMW e46
    What model phone does he use? I think Google translate would work
    Sent from my TECNO CD7 using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    deepl translate also translates files pdf, docx, pptx into 31 languages https://www.deepl.com/en/translator
    Jan 2024
    LA
    E36 322ic M3 converted
    Where can i download the pdfs
