Well, I have been having certain issues with my 3 series.
On heavy acceleration or driving normal the car sputters, jerks and picks up power right after. I was thinking it could be a bad fuel pump, or faulty injector.
I have tried a few over the counter remedies like fuel injector cleaner and switching up to higher octane.
Also another issue that i am having is on cold starts. The engine wants to turn over but it won't or it will start and die off immediately. Its starting to concern me because i work far and i would hate to be stranded.
Any recommendations? I would appreciate any input reguarding the issue.
More Specs on the car,
Manual
2.7 Engine
230xxx miles
Thanks,
Ashar
Cheers!
First things first. Check for vacuum leaks. The sputtering off idle changing to power as the RPMs increase is a typical symptom.
"Howdy, Folks!"
No vacuum leaks.
The only way you can say that with any credibility is if you've just had a smoke test run on the intake. Otherwise you don't know if there are any intake leaks.
Intake leaks are the most common cause of hard cold starts. But they probably aren't the cause of the driveability issues. For those I'd look to the fuel system (run the tests in the Bentley), the AFM, the timing reference sensors, or the ignition wires/plugs/rotor/distributor cap.
Jim Levie, Huntsville, AL
do a tune up on your car
I have/had the same issue at idle and same starting conditions. I did the fuel filter, coil, plugs, dist cap, rotor, wires, and it's better. Not perfect, but much better. I actually think some of it might be my (bad)cat.
Could it be my fuel pump?
the car starts cold, goes to 500rpm and dies out. The car starts to smell like fuel.
Still having problems.
could be a leaking injector. does your car have a cold strat valve? have you checked for fuel leaks? check for leaks at the fuel pump too.
[__] RUNNING: [__] NOT RUNNING: 86 PORSCHE 930
[__] RUNNING: [__] NOT RUNNING: 88 BMW 325is 200K+
[__] RUNNING: [__] NOT RUNNING: 2000 MERCEDES E320 WAGON
[__] RUNNING: [__] NOT RUNNING:99 GRAND CHEROKEE 160K::
[_:_] RUNNING: [__] NOT RUNNING: mazda B2200
I replaced my pump and my fuel filter and i put in a new battery. The car starts on the day i get it fixed. The next day it hesitates a little and starts to sputter again. Today I go to start it, it wouldnt start (about 28 degress F) I go to start it after school, and its starts up right away. What could the problem be?
I really need help ASAP!!! Please!!!
I would check your charging system. Similar thing was happening to me, idling funny then quitting. Lights went dim on the interstate last week and car quit running. Replaced alternator but that wasn't it. Turned out to be the stupid battery cluster bulb was burned out so interrupted the circuit. It's a shot in the dark, but...
My battery cluster bulb still works.
I'm sure that you hoping for an answer that says "Replace this part and all will be well'. But on a 25 year old car it seldom works out that way. There can be a single cause, but more often the problem will be the result of several lesser causes. You can throw parts at it and hope for a favorable outcome, but the desired result will be achieved faster and cheaper by a systematic approach.
Idle or hard starting problems are most commonly caused by intake leaks and/or
a sticky or defective Idle Control Valve (ICV). The only reliable method of
locating intake leaks is to have a smoke test run on the intake and crank case
and to test the brake booster with a gage and vacuum pump. The complete list
of possible causes of an intake leak is:
Intake boot
Throttle body gasket
ICV hoses & connections
Brake booster, hoses, and connections
Crank case breather hose
Evaporative control hoses, valve, and expansion tank
Fuel pressure regulator & hose
Injector seals
Valve cover gaskets & bungs
Oil filler cap
Dip stick o-rings
Oil return tube o-rings
While leaks in some of those can be found by inspection or by spraying carb
cleaner on suspect areas, not finding leaks that way doesn't eliminate the
possibility. Only a smoke test will really work.
Once the possibility of intake leaks is eliminated, the ICV needs to be
removed and cleaned with carb cleaner until the vane inside moves freely. When
the ignition is switched on you should be able to feel vibration from the
ICV. If no vibration the ICV is bad, there's a problem with its wiring or
connector, there's a problem with the TPS, or the DME (or Idle Control Module
(ICM) on an ETA car) is faulty.
For the DME (or ICM) to control idle, the idle switch in the TPS must work
correctly. The switch should close when the throttle stop is 0.030-0.060" off
the idle stop screw.
The fuel system should be tested via the suite of tests in the Bentley manual
as invalid rail pressure can be a contributor to idle and starting problems. A
simple injector check is to pull the injectors, jumper the fuel relay to run
the pump, and see if the injectors are leaking. You can also point the
injectors into a towel, remove the coil wire, and crank the engine to see if
all of the injectors appear to be spraying in a similar fashion. The best
approach to possible injector problems is to have the injectors cleaned and
flow tested. Since raw fuel can or will be released in these tests, have a
fire extinguisher handy.
On an ETA engine, the time-temperature switch should be tested or replace with
an new unit and the cold start valve check for operation and leaks.
The O2 sensor can be a contributor to idle problems. The O2 sensor is a
scheduled maintenance item with a useful life of no more than 100k. If the
sensor has that mileage or more (or is of unknown age), replace it.
The AFM can be a contributor. If the vane doesn't move freely or the
resistance track is worn the DME may be receiving invalid data from the
AFM. And if someone has fiddled with the bypass air adjustment the DME may be
unable to stabilize idle. The bypass air adjustment should only be adjusted
per the procedure in the Bentley and with an exhaust gas analyzer. And even
then everything else associated with engine management has to first be
operating properly. If the AFM becomes a suspect, replacement with a good used
unit is the best approach.
Improperly adjusted or malfunctioning valves will affect idle and starting. As
can compression issues from ring or cylinder wear. A valve adjustment is
called for every 15k. A useful diagnostic is to run compression and leak down
tests on the engine. And aged ignition wires, plugs, distributor cap, or
rotor can cause problems. Insulation does break down with time and heat. And
since the youngest E30 is going on 19 years old, if the ignition system is
original or the plugs are old replacement is indicated.
Although not usually a problem, a bad DME temp sensor is a possibility. That
generally won't cause an unstable idle, but can cause hard cold or hard hot
starts and/or a rough idle. As can problems with the timing reference sensors.
When all other possibilities have been eliminated and idle or starting
problems persist, replacement of the DME, or if applicable the ICM, is
indicated.
When I start the car it smells like fuel outside.
86 325e Part out!!
http://forums.bimmerforums.com/forum....php?t=1641880
so i figured it was a cold start injector, but would it cause the sputtering and jerking?
86 325e Part out!!
Did you replace/ disconnect the cold start valve? Did this fix your issue?
I am working with a similar situation on a car that has been sitting for a LOOOONG time. It is currently missing the VC breather hose, so I am hoping that my cold start issues will be fixed when that is in place. If not, I am suspecting the CS valve. My car runs fine when warm, but dies when going into gear (load) while cold- seems to be running too rich when the engine is cold.
I have checked most of the basic things and done a tune-up so far.
i had a bad idle problem too not too long ago and even though the primary problem i was trying to fix turned out to not be a problem, eta car just are ment to idle lower. anywhoo i found alot of things that needed replacement in the mean time. check your air flow meter make sure the resistance is consistent and even as the door is open and closed. check fuel pressure. where is it idling at? on the eta cars there is a switch/sensor in the tstat that has 2 spade connectors if its out then your car will idle high around 900-950 rpms all the time and it will run really rich. its meant top close when the coolant gets to a certain temp. check your o2 sensor make sure its good. it will cause the problems your describing. i didnt believe these cars needed the o2 sensor so much, ive never owned a car that has a working one and they all ran and drove fine but not these cars. if your fuel pump is going it will probably make a high pitched whining sound. but remember these fuel pumps are noisy to begin with. exactly how noisy is normal seems to vary from car to car almost. i hope some of this helps if you havent checked these things already.
Well, I believe my issues are a combination problem as well. It seems to be running better than it ever has now that I shorted the coolant temp. sensor and also disconnected the O2 sensor and cold start valve. I think I will replace all 3 of these sensors and I should be back in business.
I also took apart the AFM and made sure the wiper arm and everything was working correctly then cleaned it with some contact spray. I may try to check out the TPS as well if these 3 sensors don't clear everything up. These cars are getting OLD. every connector I have removed has looked very cruddy and required cleaning so it is hard telling what exactly will fix it completely.
For some reason my car doesnt sputter at all anymore. The only problem is a rough start. Once the car has went through a warm up during the day the car starts up quickly every other time that day
86 325e Part out!!
I've had the exact problem for the past 3 years with my 86 325. I mean you have done the best describing my problem. I'll tell you what I have replaced to save you the trouble and tell you what to eliminate. Ive replaced feul pump, fuel filter, fuel pressure regulator, cold start injector, coolant temp sensor, distributor cap and button, TPS, Mass air flow.. or is that the map sensor... thing that connects to the intake boot lol $200 alone, oxygens sensor, and i think thats it. I bought every part new and unless i bought a defected part somewhere these parts can be eliminated for sure. Keep in mind i only payed $500 for this care and it has 400,000+ miles original motor.
Oh yes and even if it quit... it will be back I promise. Had this problem long enough to know. Summer runs and idles GREAT above 80 degrees f. Come winter its my POS lol.
My 1986 325 with the 2.7, as your driving it down the road it will feel like it cuts out but then out of nowhere it takes off and it continuously does it. Any ideas what it could be, replaced the fuel filter.
