So, a year ago I bought a 1979 528i as a project/light restoration/fun car. It wouldn't start when I went to pick it up, but it was almost rust free and the only local(ish) E12 I could find at the time.
I trailered it home, rented a garage for the winter and stuck it in. By the end of May, I had got it to fire but not run, so I trailered it to the local BMW restoration shop. With their help I finally got it going in August and it was very obvious that the engine wasn't in good shape. Rather than spend thousands on rebuilding the 2.8, I decided to swap in one of the M30b34s they had sitting there. So I've been preparing the new engine. I'm not going to pull the head, but everything else is coming off and being cleaned / resealed.
On the trailer coming home
Sitting in my yard
Behind the shop
The engine:
Manifolds removed
Intake manifold after cleaning, sandblasting and powder coating silver
Valve cover after the same treatment
Engine block after some rust removal and cleaning.
After painting with POR-15
New timing chain and guides
Oil pan and bell housing
Timing chain cover back on.
Short term plan: swap the engine, with a new clutch, overhaul the brakes, new tires.
Long term plan: Inka orange, red leather interior, Euro bumpers, supercharger.
'93 E34 525i
'79 E12 528i
E12 Restoration Thread
Nice to see another E12 saved from the crusher. Good call on not rebuilding the B28. Not that there is anything wrong with the motor, it just makes sense to upgrade while you have the chance. Are you upgrading the fuel management from L-jet to Motronic too? Will make for a much flatter powerband and better gas mileage.
One piece of advice, if you plan to paint make sure you strip off what's there. Appears the car has been painted once already.
Thanks for the pictures and keep us posted on your progress!
Mine: 1988 635CSi Euro in Diamantschwarz Metallic, 1989 ALPINA B10 3.5 in Alpineweiss II, 1981 528i in Kastanienrot-Metallic, 1958 Isetta 300 currently in rust repair
In the family: 1958 Isetta 300 in Federweiss/Pastellblau, 1987 635CSi, 2000 M5
My YouTube Channel
I love E12's with a proper M30 in there and a 5spd that thing should boogie!...keep up the good work
Got a few more pictures, and some more progress.
Oil pan on.
I really like the red oil filter canister
'93 E34 525i
'79 E12 528i
Nice job
It's really coming together.
'93 E34 525i
'79 E12 528i
Double post deleted
'93 E34 525i
'79 E12 528i
That thing is coming together well!
Exhaust side
Intake Manifold on
Fuel injectors in.
'93 E34 525i
'79 E12 528i
Wow, looking good. Keep it up.
I should take my engine out and do the same, what a difference it makes.
'93 E34 525i
'79 E12 528i
Wiring harness installed
Ignition wires, cap & rotor on
Rear main seal. It's been done for a while, but I didn't take a picture of it before
Exhaust Manifold
A front subframe from AVA's parts room
After sandblasting
'93 E34 525i
'79 E12 528i
Looking good, still a couple rusty parts showing through but 100000 times better, I love these threads, keep it up!
The powder coated subframe
Ceramic coated exhaust manifold
Hub parts after powder coating
Wheel bearings and front disks
'93 E34 525i
'79 E12 528i
How much does an E12 weigh?
'93 E34 525i
'79 E12 528i
I've got mine trimmed down to 3100 with a full tank of gas.
My YouTube Channel
I got the strut housings powder coated as well:
"New" wheels, the gold and blue should look good together:
Beginning to disassemble the engine to aide removal:
Transmission out:
A Volvo race car came by the shop:
The transmission minus the bellhousing with new seals:
The car, out front in the rain without the exhaust, driveshaft and transmission:
More progress soon (I hope).
'93 E34 525i
'79 E12 528i
What are your plans for the exhaust? I have a 77 530 and want to make some changed. I'm looking to see whats out there, so far nada
sweet ride!
I posted this here as i havent seen this many E12 owners post anywhere and there's no E12 listing, please don't be offended. New in the box Colgan front custom Bra, $100 # pr 24 Fits BMW E12 75-78I 530 & 79-81 528I Sorry i checked Colhan site today and the info for this has been removed, it was there a few months ago .................................................. .................................................. ...............
(click to see more) Colgan Full Bra - With Licence plate cut out - Discontinued
Quantities are limited.
Part # : PR24 Clearance
$ 135.00
(reg. $ 194.95)
Bavarian Autosport site Any of you guys with E12 want mine???? I wrecked my E12
any updates on the build??? Kind of curious as I just picked up a 1975 530i the same color.
Got the engine out.
New engine is ready to go in.
Transmission is ready as well.
Shift lever from a Z4 3.0. Combined with the rest of the stock shift mechanism this is a cheaper short shifter.
Assembling the subframe. It's upside down in this picture.
With the Hardy & Beck adjustable sway bar installed
Got a pair of stock front springs, need to be cleaned up.
'93 E34 525i
'79 E12 528i
old car.
[img]http://www.**************.com/track/images/20.creation.jpg[/img]
So yesterday, I installed Bilstien HD shocks in the strut mounts. I was all set to assemble the shock assemblies today. I compressed the spring and then noticed that the washers I had didn't fit over the end of the shock. I looked around for the proper ones, but all I found were 2002 washers which have a slightly smaller ID.
I decided to use the washers in the car, and as the front suspension all has to come out at some point anyway, I took it out.
Old subframe with the steering box.
New subframe ready to go in.
'93 E34 525i
'79 E12 528i
Great Rebuild mate!
Congratz!!!
Cant wait to see the finish! :P
