Hi Guys,
I have had little time to work on car this year.
Put an a/f gauge and to my surprise at 5psi the
leanest I'm at is 12.9...
My total ign timing feels retarded big time which
can only be from the heat..
I bought a jay - car hand controller & digi-pulse adjuster
to run two injectors for intake pipe like the yella terra setup.
After visiting (and surprising the yella terra guy),
he finally convinced me to intercool via water to air..
So I have ordered the biggest core and will make my own end tanks.
I will cut a 25mm plate to further lift the blower..
This will in turn require me to cut my bonnet(been looking for an excuse, damn...)
But for now(until jan)I will run 50/50 meth water for cooling and a fatter a/f
as a quick fix until I can set up intercooler.
Then I will use the injector set up for fuel only
and go to 12psi( i'd like 14 but have to be real)
And just to confuse my self publishing brain, I have a guy
who can build me an bored vanos eng from an x5.. who also
has info on american comp for tough zf hp24...
There goes my $$$
Will send pics of water/meth set up 3-4 weeks.
Incidentally I have run a few ls1 and wrx...
ls1 no probs, only one modded wrx got me on top end...
One of the coolest project that i have seen for a long time
Sveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
ULTIMA Evolution
Contacts
http://alpina.123.is/pictures/
Hi Guys, i wrote an update but it went into another page.
if you click on my last posts, it's there.
Has anyone seen or heard how m62 cars respond to extractors??
I've seen a set for $2,000.00 aus not sure if they're
worth it seeing as cars are designed for the autobahn...
Romeoralpf, do you have project of manifold to your car?
What do you mean by project?? Plans maybe?
There is a fair amount of time and work required
to fit roots type chargers on our cars..
If I were to do it again i would use a side mount set up..
Easier to inter cool and a fraction of the wiring mods..
Don't get me wrong I love the set up and it's only the beginning,
it's a lot of work...
Just taking the intake manifold off, you need to release the
wiring harness from the trans..then extend injector / coil wires
to clear the charger.. faaarrrkkk
Hi, i'm new too on forum. Can you send me some images or some info of your work with eaton, please?
my e-mail is voldemarssilins@inbox.lv
Last edited by voldemarssilins; 11-22-2011 at 04:13 AM. Reason: Automerged Doublepost
Looks like a bunch of people want your adapter plate!
can you tell me the diameter of pulleys and the psi?
thanks
hi im john am from greece and i want to do something like this kai you send me some photos and some information adout the pulleys the boost
johnbmwm3@msn.com
thanks very much
Good work and design!
With 10.1 CR ratio and 11+ psi I would really consider running some type of air to water IC set up. These eatons are not the most efficent superchargers to begin with and produce some pretty high intake temps even with the IC.
12.9 A/F ratio is pretty lean for a forced induction setup with 10.1 CR ratio. Watch the meth injection before the blower. Not for sure about your's but some of the Eaton SC's have a coating on the SC blades that will start coming off and going into your engine.
oh dear god i love this thread
im doing something similar with my 530i
I was toying with the idea of using the supercharger off a Cadillac STS-V. its a M122 with the intercooler on top like the Op original idea.
the intercooler is already in place on top of the s/c and that would take car of a few opsticles. they run for around 750 on ebay.
1998 BMW 540i
Hey guy's, a brief update...
changed auto for 4.4 version w/xtra clutches and so far
no more trans slip..
Big news (for me anyway) is i have a fire damaged
2005 x5 with all running gear intact...
So out with the 3.4 and in with the twin vanos & valvetronic
N62 + '6pd' auto and four wheel drive...
Whilst many I'm sure will say no way...
The X5 and E39 share the same platform (and X3 same as E46)
so we have drive line laid out and I'm planning to
use X5 suspension with my shock's so I can legally fit
X5 size wheels...(albeit with a wider track.time for some AMG
style wheel arches)
For this eng, I have chosen a Harrop HTV2300 charger..
I won't say too much more cos' i'd rather let some pics
do the talking...
Once I have first pics, I will introduce who I believe one of the
most experienced and talented BMW technicians I have ever come across..
So far, he has proven most people wrong when they say it can't be done..
His Business is in Heidelberg, VIC AUSTRALIA..
My e-mail. ralphdavies@iprimus.com.au
p.s not sure yet, but my current m122 eaton set up might be for sale..
anything new
Hi Guy's,
Have realised the reality of someone here in aus tuning
my 5.2.1 DME...
I have tried both water and meth injection in intake to
see if car will release some ign timing..
Seem's that if I introduce more fuel/meth the car rearlises that it
is foreign and not of it's own accord guess what???
The fucker leans itself to danger-zone..
I also tried disconnecting vacuum line to fuel pressure reg but that
also triggered a lean out..
I have the Harrop HTV 2300, what a nice piece..
Tossing up wether to buy a Haltech Platinum 2000 ECU and have the
car tuned..
My last guess is the knock sensors aren't happy with the Eaton's noise
and BMW have programmed the DME to retard in 3 degree increments
hence killing my top end..
Any idea's anyone??
Had a vague reply from Dinnan-us and that was it..
Fitted a Hong-Kong spec 3.6 lsd..
Guy's let me tell you, get one-no looking back..
Tired to send pics of Harrop and N62 but know luck.
Make sure you are injecting water/meth upstream of the air intake temp sensor, also try just water without meth so it doesn't affect your afrs and see if it still leans out.
BRENDAN - Put a SOHC in it!
Hello! New to this forum. I building a eaton m 112on my bmw 540. Does somebody here have any cad drawings of a intakemanifold they want to sher? Martin
A blower from a Ford, built by Eaton, on a BMW. I approve!
Hi all!
Have you seen this video? - youtube: watch?v=C7eQUxC-kNk (can't post urls yet)
This setup looks pretty cool and clean))
I found out that all these parts came from jaguar xjr x308:
- AJ85326 (supercharger Eaton M112, jaguar part-number)
- AJ85393 (that air outlet with V8 sign)
- AJ81445, AJ81444 (left and right intake manifolds with intercoolers)
Going to put this "kit" on my m62b35 as soon as I'll get all these parts (currently searching for the used ones - in Russia we have troubles with ebay..((().
hi guys, am selling my supercharger set up.. will fit m60 also..
my email. ralphdavies@iprimus.com.au
Hi
any news on this project?
i just purchased a full jaguar kit and plan on modifying. I am looking at different set ups to complete mine
thanks
e30 344is (318is M62B44), e30 318i touring (m42 swap)
Bumping this thread, whether it be the inlet in the CAD drawings and using a Lighting supercharger (I've got an extra one since I uploaded to a Kenne Bell in my truck) or tell feedback from an owner if the M112 M60/M62 kits I see on eBay.
650hp 10 X5///M5
PERFORMANCE:JB4 w/ meth, stage 2 tune, wrapped downpipes, custom intake
INTERIOR:AVIN 10.25" screen, Blackvue 550 dashcam, 7" tablet for JB4 logging
EXTERIOR:Niche staggered 20's or AC Forged staggered 22's, H&R 2" suspension, LED AE, CF front splitter
325hp 98 BMW 740iL6
PERFORMANCE:///M5 6spd swap, iron sleeves, L/W Teflon coated & silicone impregnated pistons, Sealed Power rings, 3 angle valvejob, P&P head, perf cams, electric fan, CF intake tube w/aluminium heatshield/wrapped MAF tubing, Magnaflow 14816'd, Eaton M112 in-work
INTERIOR:Android Dynavin, hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D monoblock, CF silver trim, 5% tint
EXTERIOR:///MPar staggered 19's, H&R Stage 2/Bilstein HD, custom notched bumper, Shadowline trim, 750iL brakes w/ Axxis pads
190hp 97 328ci
PERFORMANCE:Single mass flywheel, ///M3 clutch
EXTERIOR:Z4///M staggered 18's, rolled fenders, tinted markers
Hello,
can you please upload the sketch that you have done in solidworks.
Also if it's possible to provide any sizes about the "intake".
For all ,
is it possible to use Eaton M90 ?
Thank you
Hey FastrTHNu
how much will cost if i want you to produce for me the same compressor plate?
write to me: mgaraget@gmail.com
