Okey Dokey....Here's my article in case anyone wants to look at itOriginally Posted by David
http://forums.bimmerforums.com/forum...d.php?t=163177
That's cool. Sorry, I didn't mean to come off as not wanting your article. Good stuff!Originally Posted by myavus318ti
David.
No problem More information is always good, I thinkOriginally Posted by David
My wheels have a chrome lip.
I've noticed several times when just wiping the dust from them scratches will appear even with MF towels.
I haven't been diligent in my approach since I haven't even washed the car in the 2 weeks I've had them on.
What do I use to remove the scratches?. I have a PC, but I'm looking for a method where I don't have to break out the polisher every time I want to wipe them down.
Balthazarr,
If the chrome is soft enough you may be able to use a polish by hand to remove the scratches. Grab something out of your arsenal and give it a shot. Other than that, I don't know what else to recommend.
David.
Hi David,Originally Posted by David
Interested in seeing the interior article, your tips so far have been super.
Cheers.
Thanks for the kind words. I have yet to write the article. I haven't had much time lately. Hopefully I can put something together soon.Originally Posted by BMW316i
David.
David,
I just got a new 04 M3 from the dealer. Its Jet Black and there arent any swirl marks BUT the hood and trunk have a haze in direct sunlight.. WHY!? Did the dealership use an orbital on it or something? I read in your post to use a mild polish to take these out. Should I follow your process minus the harsh polish to protect my new car and remove the haze?
Tom
Tom, does the haze look like 3D holgraphic lines? If so, you will need to use FI2 to remove them. Klasse AIO will not be enough. Try FI2 with a PC and polihing pad. If that doesn't not do the trick try FI2 and a cutting pad.
Those lines came about when the dealer prepped your car. They most likely used a rotary buffer to remove the wax when they waxed it for you. Lazy bastards. They just did more harm than good. It's easy to screw up paint with a rotary if not very careful.
David.
Unfortunately yes, they look like one of those Xmen cards I collected as a kid. Kind of makes you dizzy to look at them. FI2 can remove this or will it just make it better? Id be really mad to have hosed paint on such a new car.
Thanks for your time.
Tom
David,
Thanks for taking the time to write this all up. I haven't done it yet as I've only owned my car for 2 days, but I intend to try it this weeked! Cheers!
FI2 will remove them. You'll need a PC. See the PC polishing article.Originally Posted by theorem
Your welcome.Originally Posted by Trepan
Thanks David. This thread helped out a bunch.
David, I like to offer my thanks for the great info, too. And ask another question.
Do you recommend Klasse AIO&SG for light colored cars like my Titanium Silver 530? Is there something else that would look better?
I currently have a couple of coats of Meguiars Gold Class wax on the car, but I would like a little more shine. And I would like to use the sealant for winter protection.
It doesn't appear to have any swirls, so I would apply the AIO by hand.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
BMWCCA Member #337964
Steve,Originally Posted by Steve530
AIO + SG will look great on your silver car. I use the combo on my Dad's silver Olds and it looks very reflective. I think you'll be very happy with it.
David.
Thanks for the reply David, I'll give it a try this Fall.
Steve
In your section on washing the car you indicate:
Gently glide the mitt over the paint. Try not to apply pressure. The weight of your arm should be enough. Go in a front to back motion, NOT circular.
What do you do for things like caked on dirt or bugs on the front bumper?
If you have the means to play, then play.
Those will definitely require some elbow grease. Just use your best judgement. If pressure is needed, then do apply some. If there is no caked on dirt to remove, then just use the weight of your arm.Originally Posted by tliu69
If you have rally bad tar and bug stains, you may want to try a dedicated tar and bug remover. 3M makes one that is quite strong. You will need to re-wax/seal the area after using it.
David.
One more HUGE thanks!
When applying the wax do you do it by hand or with the polisher? The wax I use is Meguiars Cleaner wax, should I not be using a cleaner wax? And I also use Meguiars quick detailer spray, is that okay?
I wax by hand. I find it easier/faster than by machine, and I also use less of it. YMMV though. Give both a shot and see which you like best.Originally Posted by mbanks21
Cleaner waxes are not *bad*. But if you are detailing enthusiast who goes through multiple steps then there is no need for a cleaner wax. Most enthusiasts will use a seperate dedicated cleaner. Cleaner waxes were made more for people who could care less about detailing. People who just want something quick and convenient. If you don;t use a dedicated cleaner (ex. AIO) then I would suggest using a cleaner wax. Reasoning for this is because if you use a pure carnuba wax on an unclean surface, you will just be 'locking' in the dirt. If you use the cleaner wax, at least the surface will get some cleaning along with the waxing.
Does that make sense? I hope so. If not let me know.
David.
Absolutely. I just bought some AIO so Ill use separate cleaning and waxing products. Thanks again!
This will be my first big detail, but after every wash, my car always has a massive amount of water remaining on it. What I'm trying to ask is, should I still use the blotting technique? I recently bought a 75/25 MF WW towel if that makes a difference.
Thanks in advance.
Once you actually do the detail and use good protective product like klasse or zaino, you will notice much less water on your car. Try blotting first. If you are not happy, then go ahead and wipe gently. The WW's are pretty soft, so it shouldn't be a huge issue. The technique outlined above is the best way to avoid drying swirls.Originally Posted by asdfbunk
David.
David,
I purchased the PC7424 along with the Meguiar's 5" backing plate (MG-W64DA),but as I polish, the PC vibrates quite a lot (up to the point where my arms/hands get very itchy). Is this what it's supposed to do? Or did I purchase the wrong backing plate?
I apologize for asking so many questions.
Thanks in advance.
