***SOLD to David***
I have an adjustable rear spring perch set I no longer need to store. Buy these to corner weight and/or adjust ride height in the rear of your car. These are for 2.5" diameter springs and fit the e36 and e46 rear trailing arms (probably others too?). Price does not include shipping.
Thanks for looking!
Cheers,
Chet Dawes
I'll take these, you've got pm.
Edit: Can't use these! Back on the market! Damn good price.
Will these work with the H&R/Bilstein rear barrel springs?
I'm not sure because there were a few options in barrel springs which had a larger diameter bottom perch, but if they are a factory-type barrel spring then I doubt the lower diameter is correct to work with the adjusters.
However......I happen to have a set of 350lb/in or 400lb/in linear springs that would work in place of those springs and allow you to adjust ride height. They are a little bit stiffer than the H&R sport springs. The last e36 H&R rear sport springs I measured were ~325lb/in. EDIT: Sorry, both pairs of springs I had are sold.
Check out the springs here:EDIT: Sorry, both pairs of springs I had are sold.
http://forums.bimmerforums.com/forum....php?t=1582474
Obviously I will combine shipping if they go to the same place! I'd sell both pairs of springs with the adjusters here for $150 including shipping. EDIT: Sorry, both pairs of springs I had are sold so I can't combine.
Cheers,
Chet
Last edited by BMWParkingOnly; 01-05-2011 at 11:28 PM. Reason: Springs are sold, adjusters are too.
Pm sent,
I'll take them.
D
