Now I have simular problem, but with Combox,
I have retrofited combox to my e91, and works perfect till I import 9C.
BT and USB function was OK, but connected drive not works, so I decide to flash combox with winKFP.
before I updated car with ISTAP to daten 58, but I cant update combox, because my car is 2009, so I chose winKFP.
I used ZB 9257165 acording INPA, flashing start and goes smooth till 100%
Than i got error:
switching programming mode failed 00CBX36_10, DIAGNOSE_MODE (ECUPM): ERROR_ECU_SECURITY_ACCESS_DENIED
as well as
Flash download failed 00CBX36_10, FLASH_SCHREIBEN (...): ERROR_DLL_SEND_SEGMENT
Im using ICOM ABC clone, which works perfect with ISTAP and other tools.
Power supply 50A on 14.3V.
tried 3 times - same results.
I hope is just some wrong setup of WinKFP communication.
what am I doing wrong?
OK, i got it. Problem was that I forgot to change to REMOTE:MOST_ASYNC_ab625.
now is OK
Hi,
Yesterday I started with updates to my e90 335i 2007.
I update the JBBF to a new update, I see incremental number and date (from 2007 to 2016) on ZUSB module.
Then I updated the MSD80 module (DME), and instead of see incremental in ZUSB number and date, they decrease, I mean, I downgrade the module to a old one. (from 2010 to 2007).
Now the car start, but fails iintermittently in revs. I don't have alarms in dash, ISTA or DIS, everything OK.
I have the SP Daten E89 V41 installed in winkfp, maybe I need SP Daten mor new like V51 or V53?
TIA.
Hello dear si i have one bmw e61 523i and i flash the msv70 with the 525i zusb number is any one to help me for 523i 2006-2007 zusb number for original data becouse i have problem with vvt
Sent from my GRACE using Tapatalk
hello i am having problem flashing my ecu,its e82 n55 dct,
i cannot find mev17 or my zusub number in the winkfp ecu list,how to fix that ?
if i looked into the directory of the data file for winkfp i see mevd17 but i dont see my ecu in winkfp!
i tried few sp daten above v53 and updated them through bmw coding tool but still cant solve it.
i should be running 8647154 according to the chart,anyone can help me please ?
Thanks.
The old number is 8647154, the new zusb is 8684956
guys, help.
I've tried to update my MS43 ECU (E46 330i 2002) but I keep getting error 2020.
I already tried changing my COM settings but that didn't help (and I don't remember the correct original settings).
when i turn the key and directly try, it takes longer to get the 202 error ... the car doesn't start anymore since.
winkfp 5.3.1 and updated it with bmw tools spdaten updater.
all files are from => bimmergeeks.net/downloads (16-02-2019)
