Page 3 of 3 FirstFirst 123
Results 51 to 67 of 67
Thread: LED Error Free on the cheap DIY
  1. #51
    Oct 2008
    SoCal
    '97 328i
    Because you're connecting the resistor in parallel with the bulb, will the OBC know if the bulb fails or burns out?? Has anyone tested this??
  2. #52
    North Alabama
    1998 BMW 323IS
    I can answer that...No
    As far as the OBC knows the resister is the bulb, this is the reason for using a "power resistor"
    However the LED panel should have a MTBF Life of about 12 to 18 years being run nonstop 24-7 ....so essentially forever . I still have a calculator my dad bought me for Electronics school in 1972 and it is still as good as new.
  3. #53
    Oct 2008
    SoCal
    '97 328i
    Yea i understand that LED panels have a very long MTBF. I just don't like the idea of disabling the OBC check on a component that's not in plain sight. Otherwise i could just clip a couple of wires to bypass the check and not have to use a resistor at all similar to what people do for the HIDs. It's a no-brainer for HIDs cuz you don't have to rely on the OBC to tell you of a failure. If it goes out... you'll know it instantly.
  4. #54
    Jul 2010
    Central / So Cal
    05 325i_99 323IS_94 325i
    Yeah but on this they last sooo long that it doesnt matter.
    What if you wired the resistor between the terminal and one side of the LED? that way when the led blew the circuit would be cut and you would get the warning? might take an extra hour of inventive work, but if your that worried about it........
    Actually if you used one of those led panels with the lead coming off it for + and - it would be pretty easy to do......
    For Sale: (E36) Trans ECU, OEM amber corners, Stock Mirrors, stock amp,E46 Amp, Need to Use an SRS Reset / E36Code puller? E46 Programming Module PM me
    Wanted: E46 Post facelift Carbon Fiber Hood. Have and E36/46 problem..MSG ME. I would be glad to help you out!
    Want error free LED License plate lights for less? Go here:
    http://forums.bimmerforums.com/forum...4#post21079814
  5. #55
    Aug 2011
    city
  6. #56
    North Alabama
    1998 BMW 323IS
    No Workie
    The circuit is looking for a certain or a given amount of current at a certain voltage to make the circuit (probably a comparitor) appear on to the OBC. If you put the resistor in series with the resistor a part of Ohm's law called current finds the path of least resistance...the led will light but far to little current will be drawn to make the OBC think the bulb is there and working. Until you get the device to draw about .4 amps at 12V it is not going to register as functional to the OBC.
  7. #57
    Jul 2010
    Central / So Cal
    Believe me, it works........
    And I was using some 12" panels like that just under the lip of the center console in my old car to light the footwells at night, and I have a few leftover that match the red from the electronics that I was thinking of using on the interior of my new car but I cant decide. (hidden behind the center console shining down of course...
  8. #58
    North Alabama
    1998 BMW 323IS
    No
    I meant putting the resistor in series with the led to fool the OBC.....it shouldn't work
  9. #59
    Dec 2011
    USA.USA
    Car
    Hate to dig up an old thread *ducks for cover*... so no OBC = no "error" per se. Does this mean I can skip the resistors part & there is no damage to my e36? Btw - she's almost legal here... just turned 17, and is an Aussie model [which I believe is imported from Euro, correct?]
  10. #60
    Nov 2007
    Central IL
    E36
    Just bought everything I need for this finally...
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
  11. #61
    Jul 2006
    Portland, OR
    A couple of hooptys
    Quote Originally Posted by Moron95M3 View Post
    You know, I'm considering it now. This last weekend, I just installed COMPLETE interior LED's, and they look really nice, especially on my dove interior. The only hiccup I had was the 4 map lights (I have the 97+ with switchable rear map lights). The polarity on those bulbs is reversed, and there is a huge writeup on how to soldier in extra wires, and bypass this and that, and a bunch of other crap. Simpler solution? Reverse the polarity on the map light bulbs. I yanked them apart, resoldiered the 4 bulbs for the maplights (takes about 3 minutes per bulb), and installed. Done and done. Now that I've done those, I'm thinking about making all the bulbs LED. Just need to bite the bullet and get a bunch of resistors, and I should be good. BTW, these days, LED bulbs (either festoons or bayonets) can be had on Amazon for about $2 each. No need to buy on eBay from Taiwan then wait 3 months for shipping anymore! I did the complete interior with several bulbs left over for $22 shipped to my house, including 2 "special" 42mm festoons with 16 LED's each for my dome/trunk lights. The "kits" that are sold cost $100.
    1997 328i/4/5 - Cosmosschwarz Metallic on Dove Grey - Auto/Manual Swap - M3 Bilstein Sport/H&R Sports (95 M3 mounts) - Offset M3 LCAB - 20mm M3 rear sway bar - X-Brace - AA Tuning Strut Tower Bar - Rogue Engineering RSM - Dinan Cat-Back - 3.38 LSD - E46 330 front/328 rear brakes - SS Brake Lines - E36 fitment Style 42's (staggered) - M3 Front Bumper - M3 side moldings - M3 Rear Diffuser - DJ Auto Headlights (6k HIDS) - Frenched Fogs - OEM Clear Tails - E65 Rearview Mirror (Homelink controls + Autodim) - Alpine Type S Cabin Speakers (6x9 Retrofit) - 8" JVC woofer - Black Kidneys - Red Needles/Chrome Gauge Rings - OEM Alarm - Full Interior/Trunk LED Lighting - Mishimoto Full-Aluminum Radiator - More to Come!
  12. #62
    Nov 2007
    Central IL
    E36
    UGH! Amazon shipped me the wrong resistors (.68 instead of 68 ohm) so off to radio shack then I'll install tonight I hope
    *********************Edit************************* ************ later 'tonight'....
    Installed and with great success.
    parts:
    10W 50ohm resistors from RadioShack ($2.99)
    39mm 9LED 5050 dome lights. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    $7.99
    And install:
    remove old:
    install new resistor, use some needle noise pliers to curl the ends on, then pop in the LED board.
    Test run.
    And even more importantly.
    Then I soldered it just to be safe (just the resistors).
    And then just reinstall...yea the car is rusty
    Before:
    After:
    (mirrored so it's the same angle)
    Pretty happy for $11
    1995 M3
  13. #63
    Nov 2007
    Central IL
    E36
    how they look out at night
    1995 M3
  14. #64
    Nov 2007
    Central IL
    E36
    btw, looks like you can buy these predone in brackets for $25 shipped. Not a bad option either?
    http://www.bmwled.net/xenon-white-18-smd-leds
    1995 M3
  15. #65
    Jul 2006
    Portland, OR
    A couple of hooptys
    Pre-done is nice, but the forum is for people looking to save money. Your resistors + regular LED festoons on Amazon are $5.50. I think I'd just spend the extra 5 minutes soldiering in the resistors like you did and save $20.
  16. #66
    Long Beach, CA
    '97 BMW 332ti
    I'm kinda glad I have a 318ti ... Don't have to worry about the resistance for the LED install. No OBC. Just install and drive
  17. #67
    La La Bing Land
    03 540i/6,LexusRX350
    Too much trouble. I just used the German modular ones by Weisslicht (sp) no error at all. They are super bright as a matter of fact almost too much. May tone it down by painting 1/3 of each lens black.
    2003 540i/6 Sport Alpine White III-Front and rear OEM M5 bumpers with single cut out, M5 # 65 staggered wheels w/10 mm frt spacers, Hankook Ventus V12 EVO, M5 Ft / Rear brakes, SS lines with front Ft / Rear Euro rotors w/aluminum hats, CDV delete, M5 3:15 LSD, Ground Control Coilovers w/remote adjust for rears, M5 rear sway bar w/Beastpower mounts, white gages with stainless rings, M5 pedal covers, Dinan exhaust w/ 18 in Magnaflow resinator, Dinan CAI/High flow intake runners/Throttle Body/Mass Air Meter, Dinan Stage 5 software. Zionsville aluminum radiator w/fan delete, 2 speed electric fan, 545i shifter w/ZHP knob, Alcantara interior, Technical Graphite interior trim, LED lighting ///M
    "One day the two great masters will be friends"
