Newbie here - so please dont laugh
I have a recently purchased 2001 740il and can not figure out how to turn on the fog lamps.
The rotary light switch to the left of the steering column only has 3 positions, non of which turn on the fog lamps
There is no separate button or switch I can find anywhere.
And, no - the high beams are not on; I am aware that when they are on, the fog lamps are off.
The car did not have an owners manual - so I downloaed a pdf - it just mentions rotating the light switch clockwise, but that does me no good.
This has got to be simple, I am embarressed
Help anyone thanks
Its the switch on the right side of the instrument cluster. Look at your headlight switch, turn your head about 10" to the right- same position as the Headlight switch, just on the RH side.
What about the dial opposite the headlight switch? Same position, just other side.
http://s434.photobucket.com/albums/qq67/mcallister95/
production date: 01/95, DUDMD engine chip, Dinan transmission chip, Dinan CAI, Beyern Multis, Magnaflow cats, mufflers, 3" down turn tips. Bilstein shocks, struts, H & R stage II springs, strong strut brace, pornlights, wood ashtrays, leather/wood seatbacks, euro lighted headrests, 750 kidney grills, wood handles, wood maplight, b-pillars out of a 750, Ford Mustang injectors, "E's" AE and LED 3rd brake light special, cats delete, Magnaflow X-pipe, 199K miles
um. try the switch to the right of the steering wheel? just to the right of the instrument cluster?
'98 BMW 740iL. Oxford Green Metallic/Tan leather, Bilstein B6s', Eibach Springs, 130,000 miles
Totally stock 97 740iL except for SatRad
I'm sure only his dog respects him right now.
Yeah, looks pretty much the same, near the HVAC
750IL SOLD....I'll miss you!
You can see the fog lamp switch in the pic below. The switch (as others have stated) is on the right side of the instrument cluster & steering wheel (and to the left of the air vent on the center dash) and looks identical to the round dial for the headlamps which is on the left side of the instrument cluster & steering wheel:
Driving with fog lights on only makes you look hardcore.
Had some moron driving towards me last night at 2am with fog lights only on and no headlights, so I simple switched on my highbeam on, as i do with all cars that drive towards me at night with no headlights on.
To OP, did you find your fog light switch?
Even with HID's, the fogs only look bright as hell but actual light output sucks...should never risk driving at night with just those. But I do that when its evening, which is acceptable.
