Page 5 of 7 FirstFirst 1234567 LastLast
Results 101 to 125 of 171
Thread: An Example of Truly Impressive Turbo Engineering
  1. #101
    Dec 2008
    Earth
    none
    Quote Originally Posted by DrivenInnov View Post
    They are in Greece Colby.
    That's where my use of "some day" comes into play... manny moons, many moons away
    Soo when that some day get here, should I book another first class ticket?
  2. #102
    roc
    95 m3, 3L S4
    Quote Originally Posted by nuvola rossa View Post
    question is, how they've got all that money to start such an expensive thing?
    what's their background?
    Nice to see some real expensive work, finally.
    there are people that spend 250K dollars on a single wrist watch. So this evo build is chump change for some people out there. Some of my buddies parents rebuild and have spare boat motors that cost $100K a piece and each boat has 3 of them X the three speed boats they own.... Its all in what your passionate about and how deep your pockets are!
    "Lamborghini, the tractor maker, wanted to figure out why his Ferrari's clutch kept crapping out (PITA, cost a lot of money). He complained to Ferrari, and Enzo didn't do anything. Lamborghini discovered it was the same, much cheaper clutch used in his tractors. The rest is history..."
  3. #103
    Jun 2005
    Western NY
    a few
    My mind = blown.
    Quote Originally Posted by Brent_Strong View Post
    I thought this thread was gay when I saw pink wheels. Little did I know the "stancers" would come in and make pink wheels look as manly as BBQ sauce and steaks.
  4. #104
    Oct 2007
    Canada
    93 318is Turbo @12lbs
    I am impressed by things most impressive...
    and especially enjoy the fact that its on 4bangers
    M42!!
  5. #105
    Jul 2010
    Chattanooa, TN
    2008 BMW 528i
    Holy crap!!
  6. #106
    NY
    skateboard
    Quote Originally Posted by milKt View Post
    Someone pass me the poor person
    to wipe my face.
    ― George Orwell
  7. #107
    Dec 2010
    san clemente
    1991 Galant VR-4
    Quote Originally Posted by rt turbo View Post
    I remember a drag turbo-integra motor build that was similar to this extent. It was a cnc machined 4.6L I-4 block based off a B18 engine. Everything was cnc'd from a single piece of billet and the car was RWD. Had 2 massive turbos and was supposedly capable of 3000hp and was subsequently banned from all import racing or something. Anyone remember that one?
    I believe you are referring to Norwood Racing's Integra funny car. Definitely a beast and one hell of a one off engine.
    http://www.turbomagazine.com/tech/02...gra/index.html
  8. #108
    Dec 2010
    Small Town, Ontario, Cana
    2002 Ford Focus SE Wagon
    Quote Originally Posted by Ted B View Post
    Every now and then I come across something truly impressive. This represents some of the work of Extreme Tuners in Athens, Greece, and the name is no joke. Pushing limits requires funds and skill, and these guys have both. All they do is build and tune engines. The entire lengthy discussion can be found here (http://forums.evolutionm.net/evo-dyn...ne-2007-a.html), but unless you feel like reading quite a few pages of posts, I'll post the highlights here.
    FWIW, this is some of what they've done:
    2006 - N/A ford cosworth 4cylinder 16v engine 119cui: 416hp -11,900rpms
    2007 - Ford cosworth 4cylinder 16v Turbo engine 120cui: 1280hp 47psi (custom triple ball bearing 80mm turbo 119lbs/min)
    2007 – Mitsubishi Evo 8 4g63 4cylinder 16v Turbo engine: 1416hp – 57psi (custom quad ball bearing 82mm turbo 132lbs/min)
    So, getting 700whp/L from 2.0L @ 8500rpm is no small feat, but what do you need if you get bored and want to shoot for 2000whp?
    Cast Garrett compressor wheels (right) tend to come apart above 50 psi. CNC billet aluminum wheels (middle) are stronger, but why not be different and use your own CNC billet titanium (left) compressor?
    You'll need a turbo big enough for the job, which in this case is a 108mm twinscroll T4 turbo, with custom quad ball bearing CHRA and 100psi capability.
    To get enough airflow at 12,000rpm(!) to get the job done, you'll need a skillfully ported head, complete with titanium valves and copper-beryllium valve seats:
    And you're going to need a set of camshafts to handle the rpm and withstand tremendous ramp pressures, so why not a set of hollow titanium billets with DLC at only 234 grams each?
    And since there is no aftermarket rod up to the task, just ask for a set of billet mmcs-titanium connecting rods at 286g each. Rod/Stroke ratio is 2.07:
    For pistons, a set of custom beryllium pistons with DLC fits the bill, and since methanol is the fuel, 13:1 SCR is fine:
    A strong piston pin is needed as well:
    Toss in a custom titanium billet crank:
    A set of 9000cc/min injectors:
    And since a factory 4G63 block probably wouldn't hold up, just CNC machine your own from billet aluminum:
    No head gasket is used:
    And to put all that power to the gearbox, one needs a suitable multiplate clutch:
    Yes, it is smaller than a cam gear:
    An example of very efficient turbo manifold design from one of their recent projects:
    And last but not least, a dynosheet from this car, running 'only' 48psi and hydraulic cams:
    a) *mocks* oooh...I like big turbos...ooooh...
    b) What? No Inconel? tsk tsk...
    c) Must be a drag racer since they CUT into the frame rail of an otherwise unibody chassis, which means it has NOOOO torsional ridigity. Not without a shitload of strut tower bracing, and even then, the chassis will flex like it's sheet aluminium.
    d) That is NOTTTT efficient turbo manifold design. If they want to see efficient turbo manifold design, go look on the BMW N63(B44) engine. THAT is efficient turbo manifold design.
    e) I wonder if they're using a Haldex or Torsen center diff/transfer case.
    f) I'm also betting, no polymer electronics.
    g) Awww....no carbon nanotubes for the drive/prop shafts?
    h) Nothing like the leading edge blade design of the GE90?
    i) No tandem, e-clutch packs for the DCT?
    j) I'd love to see this thing try and take the Variante di Rettifilo. LOL.
  9. #109
    Z3speed4me's Avatar
    Z3speed4me is offline Coupe Cartel Forever! BMW CCA Member
    Apr 2002
    Westfield, NJ
    MCoupe, Q3, Tiguan
    first post huh... someone looks like a hater to me
    ~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
  10. #110
    Charlotte
    '97 Estoril M3 Turbo
    Quote Originally Posted by alpha754293 View Post
    Just about all of what you said is retard.
    | 1997 Estoril M3 - TURBO - |
    | GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning |
    | 46mm Precision gate| 62# injectors | Dual Walbro's |
    Goal: 600+ whp pump gas reliable 10 second car.
    -2007 335i Sport Package
  11. #111
    Apr 2009
    NYC
    2002 325xi, 5MT Swap
    was in necessary to quote every single pic?
    I hope you're trolling
  12. #112
    Nov 2005
    Linden, NJ
    F80, E36, X3"M"
    Just smile and nod
    97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
    02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
    16 M3 - 9.3@151 - Built motor/twins
    15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
    BMW SOB's turbo E30 - 8.72@158.39
    follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
  13. #113
    Apr 2009
    TX
    Need an E30 PM Me
    wow whats the price tag on that?
  14. #114
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Quote Originally Posted by jo3y View Post
    It's one of those, if you have to ask, you can't afford deals.
  15. #115
    Apr 2009
    TX
    Need an E30 PM Me
    yeah i figured as much, just was curious if it was worth all that cost. I mean JZ motors do those numbers too. hmmm just curious.
  16. #116
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Just look at it.
  17. #117
    Phoenix, AZ
    E30 S50 Turbo
    Where's the inconel tubing? I'm confused.
  18. #118
    Sep 2008
    Tampa, FL
    1998 Honda Accord, 2009 Mazda RX-8
    True, but sometimes it's not always about the numbers. The quality and engineering in that 4g63 is beyond comparison. If I had to guess on the cost of this build, I'd say somewhere between $150k-300k...without having any clue about the labor charges. Extreme Tuners does top-notch builds, so I wouldn't expect them to have competitive prices with your local tuner shops...you get what you pay for, and with those guys you're getting a masterpiece.
  19. #119
    Feb 2008
    DETROIT
    E36 GOODNESSSS
    this is some sikk stuff!!!!
    i got these parts for sale
    front corner light for a 4 door E36 $20plus shipping
    headlight eyebrows $20 plud shpping
    M3 OEM radiator $100 plus shipping
    M52 cams with trays high miles $150 shipped
    M3 front calipers $150 plus shipping
    18x8 offsed 35, front 18x10 offset 40 rear bsa motorsports wheels $400 plus shipping
    obd2 valve covers $50 plus shipping
    intake manifolds $50 plus shipping
    estoril blue doors of a 96 M3 2door $200 plus shipping each
    rear glass $50 plus shipping
    rear trunk lid $150 plus shipping
    new 1/4 is 800 ft away ))
  20. #120
    Dec 2007
    germany
    e30
    reminds me of the Norwood nitro motor, also a unique piece... unfortunatly
  21. #121
    Jul 2003
    SouthEast
    c6 w/ flux capaciter
    Quote Originally Posted by MrBlonde View Post
    Serious engineering!
    Fakk yeah...... wow
    Nelson Mandela borrowed this from Marianne Wilson in his 1994 inaugural speech - "Our deepest fear is not that we are inadequate. Our deepest fear is that we are powerful beyond measure. It is our light, not our darkness that most frightens us. We ask ourselves, "Who am i to be brilliant, gorgeous, talented, fabulous?" Actually, who are you not to be? You are a child of God. Your playing small doesn't serve the world. There's nothing enlightened about shrinking so that other people won't feel insecure around you. You were born to make manifest the glory of God that is within you. It's not just in some of us, it's in everyone. And as we let our own light shine we unconsciously give other people permission to do the same. As we're liberated from our own fear, our presence automatically liberates others.
  22. #122
    n. miami fl
    98 m3 coupe
    any one else notice the kind of car the "hater" drives, lol
  23. #123
    Dec 2009
    Hoboken, NJ
    jetta
    we all just chose to ignore him. He could drive a Zonda R, if you're gonna hate on this car you're still an idiot.
  24. #124
    Sep 2003
    plastination station
    a) *mocks*
    ok simple jack
    "If you can leave black marks from the time you exit a corner till the time you brake for the next turn, then you have enough horsepower." --Mark Donohue
  25. #125
    A house
    '86 325e, '14 VW EPA
    Sorry to bump an old thread but I don't think I've seen the video of the finished product here, came across it on vortex:
    http://www.youtube.com/watch?v=IYaqskg3Wh0
    CAR WEIGHT (no fuel)
    1477kg
    Roll (2nd gear)
    60-100 1,4s
    60-120 2,19s
    60-160 4,03s
    60-200 5,99s
    100-200 4,59s
    Acceleration (3rd gear)
    100-120 0,75s
    120-160 1,86s
    -forged titanium cranks
    -hollow billet forged titanium cams
    -titanium valves
    -cobalt valve guides
    -Mitsubishi Evo 8 4g63 4cylinder 16v Turbo engine: 1416hp – 57psi (custom quad ball bearing 82mm turbo 132lbs/min)
