[ 1995 Alpine White Coupe M3 Track Build | 1997 Techno Violet M3/4/5 | 2000 Imola Red M5 DINAN S1 | 2001 Phoenix Yellow M3 | 2009 Blue Water 335d ]
|-| I run the largest active group of BMWs in the area, join me at Central Florida BMW Owners |-|
INSTAGRAM/Millakins | FACEBOOK/milla.bimmer
___ NURPLE ___ M3PO ___ M CINQUE ___
Washedit1 by thedude60526, on Flickr11/10's Racing
94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
Earlier in this thread I believe someone said there's a noticeable difference in how the car drives with an LTW wing.
Can anyone elaborate on these differences? Would they be noticeable if you were upgrading from a standard M3 wing?
In Germany the Wing might only be mounted, when GT-corners(LTW) are mounted on the front.
The LTW (GT) Front lip (the ine under these corners) might only be mounted when the wing is mounted. (german TÜV regulation, got the papers 4 it here.)
I have the impression that after mountig it the car can go faster in curves. It is more fun to drive on the Autobahn ,now.
Here is mine: not an LTW/ GT wing cuz it ain´t a coupé. it is an 318is class2 (the only E36 is that is a sedan)wing, probably the same than the ltw, but fits sedan trunk only.
got the part number for the sedan version?
-M3J0N
yes Sir: sedan: 51 71 2 268 552
part number 1:
http://bmwfans.info/parts/catalog/E3...oiler_class_2/
( I know that picture doesn´t show a sedan, but the part number is for sedan, as you can read in the link)
coupé number : 51 71 2 489 685
also part no. 1 .
the upper wing is the same part number, just the "ground plate" is differnt to fit the differnt trunk wides.
here a link to a german installation manual for both, sedan and coupé:http://www.m3-gt-racing.de/downloads...lermontage.pdf
see on page 3 (Lieferumfang des Einbausatzes für E36/2 (coupe) 1.line Heckflügelunterteil ( wing- under part) =part no 51 71 2 267 444.9
and compare it to the 1.line under Limousine (sedan): Heckflügelunterteil = part no 51 71 2 264 508.9
Greetings from Germany ^^
its not black , its carbon
See ya
I've been trying to get to the bottom of this...are the coupe and sedan versions the same? or is the trunk different?
Anyone have any idea how to get my hands on a set of just the spacers?
size info on car with RPf1's
www.danlandoni.com 333 E. Carson St. Suite 437. Pittsburgh PA, 15219
bumping this... MOAR
