I have put together some phenolic spacer kits for M42's and M44's which isolate the intake manifold from the cylinder head. I developed and installed this product on my Supercharged M44 as the intake manifold and blower were getting really heat soaked from all of the extra compression and power and thus heat coming off the motor. It reduced my intake air temps almost 20 degrees F and the actual manifold surface temp over 40 degrees!
This is perfect for boosted applications and I have not tested it on an NA set up yet, but should also help keep NA intake manifold temps down a few degrees as well. We all know that the NA 4 bangers need all the help they can get.
The Spacer is Water Jet cut out of high grade phenolic fiber board which is rated at nearly 600 degrees! It is 10mm thick and for $50 the kit comes with extended studs, phenolic washers, and for an extra $10 you get 2 new manifold gaskets.
Let me know if you have any questions.
Neat! Too bad I can't justify the purchase at the moment.
Hope you're trying to sell these on r3v too!
bump
wondering if you still have any spacers left?
Do you still offer these spacers for sale?
Any kits left?
Doing another run of these! Only a few left to sell. Get one while they last!
Only 2 left!
Still happen to somehow have one of these around?
