Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 25 of 27
Thread: Finally 3-piece Style 5s with RS mesh dish
    Duesseldorf, NRW, Germany
    '90 850iM70B54, '91 850i
    Since quite some time I'm already modifying the Styling 5s to 3-piece with stepped outer lips in various sizes. What always bothered me was the plastic center cap of those rims. I already found a way to change the centers in a way that they can take a real full alloy BBS RS style hex nut with BBS logo badge. But still a plastic cover
    Now I finally found a solution to this as well and beginning of next year I'll modify the rims of my 850 (currently on winter wheels) and get rid of the plastic I might even convert a set of 18" Style 5s and will have the only REAL 18" BBS RS wheel world wide . The only set BBS ever built (RS285/286) was kind of a fake since they used the same center as on the 17" RS and no stepped lip either.
    Some pictures below.
    The 1st set I made - now running in Norway:
    full alloy hex nut conversion, but still with the (modified) original plastic center cover.
    The set I'm running on my 850 (still with the polished hex nut which I changed later)
    10.5"x17", offset 17mm
    YES, those are Styling 5s
    and now my 1st prototype of a true RS modification (just glass pearl blasted and not mounted)
    Nov 2003
    LIMA-PERU/South America
    BMW 325is Turbocharged - Jeep Cherokee 4.6L Stroke
    Stunning!
    I'm debating my self what wheel buy for my euro e30 m3 which is under restoration still. I just sold my DS 90' M3 which had 17x8 all arround style 5 an dloved the way it look, except I wante something sttagered and wider.
    This time I'm looking to buy a 3 piece BBS race wheel in e87 model or sort of, but I'm having hard time to reach BBS so they can make ma set.
    Alternative, I'm looking some other models and I'm not sure what to pick up. I don't want another e30 m3 with RS's, isn't that unique grom long time ago, ratehr I would pick up a style 5 sttagred.
    I'm also thinking to get BBS CH 17x8.5 all arround, totally opposite for the lip story, but I really like them.
    Now these custom syle 5 are the shit! IS possible to make me a 17x8.5 and 17x10 for my e30 m3? I think that should be fit in the stock fenders with rolled fender work only? What ET are we looking at with these widths?
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
    In principle all offset are possible. But I of course try to use the original inner barrels of the RCs which saves quite some money and that means limitations.
    Starting with an RC in 8x17, offset 20mm and using the original inner barrel the following is possible:
    8.5x17, offset 28mm with 2.25" stepped lip
    10x17, offset 11mm with 3.75" stepped lip
    Sep 2010
    Vancouver, BC
    1991 330iS
    Huge fan of this. What's truely great is that you can tailor the offset for a particular car/look!
    I want to see a set of these on an E36!
    Avusblau 1994 Euro M3 --> Journal Here
    Lagunagrün 1991 331iS-->Journal Here
    Partout Thread --> Here
    me too but no one has such a set on an E36
    West Chester, PA
    98 M3
    Those look amazing
    Nov 2010
    GUAM (671)
    1992-325is
    Good shit
    Sep 2010
    Vancouver, BC
    1991 330iS
    Quote Originally Posted by wokke View Post
    Maybe I'll have to be the first then...
    Quote Originally Posted by 3MPowered View Post
    any time
    I already did the measurements for a potential customer in Norway who wanted to have a set of 18" Style 5s modified. But after I had the 18" set and had done all the pre work he backed off. I guess he realized a little late that he can't afford them.
    UT
    98 M3/4/5
    so where did you get the center nut from? i would like to do that to my style 5's
    98 Estoril ///M3 4/5
    S54 swap
    Quote Originally Posted by TH3 Shifty View Post
    I distribute them (www.wokke.de)
    But getting the hex nut is only part of the job. The Style 5 centers need to be machined and an adapter is required as well. The adapter screws into the center and then the hex nut with original BBS RS measurements screws into it. The original plastic center cover needs to be modified as well of course.
    All in all not really cheap and certainly not a 10 minute job either.
    Mar 2003
    Akron, Ohio
    M3 Saloon, Z3 3.0 Coupe
    Do you sell these as a complete kit? Or the adapters separate?
    DIY Anyone?
    May 2010
    Hotalanta
    '01 S4 Avant, '88 325Is
    holly mother
    Quote Originally Posted by Saloon View Post
    DIY Anyone?
    I sell the hex nuts separately or together with the adapters. More info via PM.
    Sep 2010
    Vancouver, BC
    1991 330iS
    Here's a question: Does splitting the Style 5's and making the 3 piece make them any lighter? I know the centers aren't forged like true RS centers are, but surely the lips and barrels must be of a high quality?
    No.
    Sep 2010
    Vancouver, BC
    1991 330iS
    Well in any case, they look 3 times better the way you've built them!
    May 2005
    Portland, Oregon
    1980 Volvo 242
    I know this thread is super old, but I'm looking for more info on this subject. Do the RS waffle plate/lug covers fit the Style 5 centers without modifying the diameter?
    Quote Originally Posted by crandandall View Post
    No, they don't. Centers as well as waffle plates need modification. Which ones are my secret though ;-)
    Miami
    1998 318i
    Rc 090 getting thr rs waffles to fit ,IS this top secrete & why
    if so than how much
    would u sell the waffles ready to install
    or u
    can tell me how i can diy
    Quote Originally Posted by Rasjgo1 View Post
    if so than how much
    or u
    modified waffle plates won't help you. You need some serious center modification plus a set of hex aluminium nuts.
    I offer the full RS look to my modified 3-piece Style5s for €600,- extra whereas only the hardware (waffle plates, hex nuts and BBS logo badges) is almost €450,-
    Miami
    1998 318i
    bump
    bump
    nuff respect
    Dec 2005
    North Carolina
    540i/6 M-sport GA65474
    Old thread, but Nice work!
    Silver centers with red BBS center cap and gold hardware would be awesome!
    Gone but not forgotten:
    '95 540i/6 M-Sport. GA65474. Alpineweiss/Parchment.
    Supercharger project
    Fl
    1989 325i: 00 M Roadster
    He does great work and very fast with email response.
    So. CA
    are fun!
    That is a great idea. I like the look.
    Cheers,
    Jim
    1990 M3
    1995 E34 540/6
    1992 525it
