Results 1 to 18 of 18
Thread: AA OBDII turbo tune for sale
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    For sale is an OBD2 AA Stage 2 tune for an e36 m3. Comes with 42lb injectors, Porsche 803 MAF & Harness.
    Tune Details:
    EWS delete
    Post cat o2 sensors delete
    m50 manifold
    gt35r
    Low compression (8.5 CR)
    Tune is good for 14psi
    Never dyno/tracked so I can't tell you how much power it made
    I spoke to AA and they offer remote retunes for $500.
    Asking $1050 + shipping OBO.
    AEM truboost 30-4350 $175
    AEM uego 30-4100 $165
    Or both for $300 and I'll throw in a a-pillar 2 gauge pod
    May 2010
    bronx, NY
    96' 328is
    hey whats the lowest u will take PM me
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    I can't PM you, I think you need more posts. Give me your email and I will contact you.
    Thank you
    May 2010
    bronx, NY
    96' 328is
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    still for sale
    canada
    1996 328is
    low compression as in pistons or .140mls head gasket???
    Hawaii
    TT Stg2 M3, 17 S1000R
    Quote Originally Posted by jacob328 View Post
    Either way you would think, you are still lowering the compression.
    I think if the OP states what the CR has to be then it will help. Also, state how much boost you can/intended to run on this tune. About how much power did you make with this tune? Seems the info you have is kind of vague, add the above to your first post and it might help you some. GLWS.
    '97 M3- GC Track/School|Spraco strut bar|X-brace|UUC Swaybarbarians|w/ VMC adj End links| UUC systemU|SouthBend stg5 clutch|Powerflex RTAB/LCAB|UUC Red Tranny mounts|M50mani|Greddy EBC|Innovate LC-1
    M52 Crank, Cams, Pistons, Rods:
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    Never been to the dyno or track so I don't know how much power it made. Tune is good for 14psi, and AA does offer remote retunes for $500.
    Thank you for your help and I updated my first post.
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    bump....I will part out the injectors and maf
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Blow-thru or draw-thru?
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    It is a draw-thru set up.
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    bump
    santaclara ca
    953whp m3 & 507hp m5
    the tune should be good for 11.7 at 127mph at 1/4 mile . that was my old tune on my car . it made 446whp on dynapack .i took the car a few time run consistent low 12 & high 11 with DR
    9.05@157mph
    9.14@159mph
    9.15@158mph
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    You heard the man, reasonable offers welcome.
    Added an AEM truboost and AEM uego wideband to first post.
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    bump
    Hawaii to Las Vegas, NV
    E36| 4runner| 08 tsx 6sp
    is the AEM tru-boost NIB or used?
    Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | Miller Tune Package | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 255lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
    Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
    Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
    Oct 2005
    Miami/New Orleans
    2000 BMW M Coupe
    Both gauges are used, I'll post pictures soon
    Mar 2008
    Potomac, MD
    04 M3 vert, 07 A4Q 2.0
    Which is it tuned for Spa Manifold or tubular?
