Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Thread: Difference between '95 and '96+ E36 M3 spindle?
  1. #26
    Colorado
    are a waste of money
    Both Mike S and bluptgm3, this is in line to what i was thinking. Not worried about classes, mostly a street car.
    Nov 2003
    Orange County, CA
    '00 M coupe / '95 M3 S54
    I can't see the value in it for a street car.
    Mike
  3. #28
    Nov 2003
    Orange County, CA
    I'll assume you're using a camber plate that allows you to adjust camber and caster. And I'll also assume you're not facing a problem fitting your tires beneath the fenders.
    In that case, you may need to buy a different wheel spacer to avoid interference due to the kingpin angle changes, but I'm confident they can fit and likely get the alignment you want. If you're tracking your car you probably replace the front control arms regularly, so if you *do* find that they're needed to get your setup the way you like it, it's not like you're wasting a bunch of money.
    Mike
  4. #29
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    Are the strut towers in the chassis the same between 95s and 96+s? Ie, if i one with a 95 wanted to, they could swap LCAs, spindles, and strut mounts and be exactly 96+ spec? I ask because i'm shopping and am debating if i should consider 95s or not. I don't want to get stuck with the oddball out when it comes to finding junkyard parts, etc.
  5. #30
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by odortiz View Post
    i have a 95 with aluminum front arms. same geometry as 95 m3 i'm told.
    Those aluminum FLCA are from the E30 M3.
    I have not confirmed this, however I understand that the E30 FLCA has the same geometry as E36, except E36 has a larger inner ball joint to accommodate the heavier weight.
    The geometry of these arms - the 318/325/323/328 and 1995M3 - is the same, M3 has solid outer ball joint where as the non-Ms contain an rubber isolated outer ball joint.
    Meyle HD FLCAs for E36 replicate the 318/323/325/328 and 1995 M3 geometry and offer solid Ball Joints.
    If you have to have 'factory' parts the E30M3 FLCAs also offer solid Ball Joints.
  6. #31
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by TXBDan View Post
    E36 chassis are all the same.
    Yes the 1996+ front suspension components work on a 1995 and earlier chassis. Not all of the early 1995 chassis got the factory reinforcement plates however.
  7. #32
    Nov 2003
    Orange County, CA
    Whoa - flash from the past! This thread is so old it even looks like some of the discussion is missing.
  8. #33
    Oct 2003
    Seattle
    99 M3
    With 1996+ E36M3 FLCA NLA, linking threads.
    https://www.bimmerforums.com/forum/s...al-dimensions)
    https://www.bimmerforums.com/forum/s...9#post30219499
    LOL!! Got mine from Tischer couple of months ago. One came bare steel and the other came partially primed.
