Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 72
Thread: e36 lsd internals fit into e21 case
  1. #26
    Canada
    e84, e36, e21
    Quote Originally Posted by charbel View Post
    i got about 8 e36 LSD for sale $250 plus shipping..
    i will try and do one myself and see how it turn out. very good idea by the way. awsome job.
    edit : my question to you now, is the half shaft. are they going to need any modifications ? and is the e21 half shaft gonna fit the e36 internal diff?
    i will assume the half shaft will need to be cut and shorten like an inch or 2. or no ?
    Are your e36 diffs small case (318i or 320i)? The medium case internals won't work.
    Regarding the half shafts. I don't see why they'd have to be shortened, since I'm using the e21 output flanges. The portion of the output flange that fits inside the diff is identical to the e36's, diameter, splines, snap ring groove.
  2. #27
    Herriman UT
    81 323i 86 535i 08 335i
    May I ask what is the point? The advantage of doing this.
    80 B6, 81 & 82 323, 85 745i, 86 535i-all euro. 01 750iL Blk/Blk 08 335i
  3. #28
    Apr 2006
    Greenpoint
    e21/325, w124
    Seems like its a great way to change your ratio fer cheap, and beef up your diff at the same time.
    Motronic M20B25 E21 Legion Page
  4. #29
    Canada
    e84, e36, e21
    Quote Originally Posted by BIMMERBOYZ View Post
    My 323i currently has a whiney 3.91 open diff. After this, it will hopefully have a non-whining 3.45 lsd, for the price of $75(what I paid for the e36 diff).
  5. #30
    Ohio
    E21 320i, e39 540i/6
    This is a great thread, it should be added to the faq.
    To answer the question of why,
    Pros:
    -commonly available 3.45 ratio, easier to find than an e21 3.45 LSD (super rare as it was only available as an option on 323i's), or 3.45 open
    -cheaper than an e21 3.45 LSD
    -might even be cheaper than an e21 3.91 LSD, which is "common" compared to the 3.91 but still getting harder to find
    -other benefits might be an improved LSD design with more clutches (for longevity) or different ramp angles, etc. this is unknown to me, just a guess.
    nuetral:
    -The gear sets shouldn't be any stronger than the e21 diff as they're still the same 168mm
    -The LSD probably isn't any stronger and it likely uses the same size clutch as the e21 diff
    -The e36 offers the same 25% lockup as the e21 LSD
    Cons:
    -individual replacement components for the e36 318i LSD are not available, the LSD unit is sold as a whole so unless you work some majic and find parts from the BMW parts bin that fit, the LSD is not rebuildable. The e21 LSD is still rebuildable.
    -added work to swap pinion and ring gear into a new case which involves completely rebuilding the diff, setting torque to turn & gear lash. Not a problem, but outside the scope of most home mechanics. It would take less work to swap an LSD carrier into a 3.45 open.
    '81 320i turbo | t25, 931 CIS, 240hp, 13.92@100mph | 2.2L m10 Turbo Build | My E21 Videos |
  6. #31
    UK
    M52/2.8 & Nitrous 300bhp
    Nice work. Hope you don't mind but I pasted your post on the UK forum as I know a couple of guys looking to do this conversion.
  7. #32
    Michigan, USA
    E21, 04 STI, LS6 Sonoma
    Definitely a sweet thread. Before investing in a donor E36 diff I'd like to see if any development is needed on the pinion side. What are the lash/gear mesh specs for the E36 diff? And to be certain, this is only off an E36 318i non-hatchback?
  8. #33
    Cincinnati, OH
    323i, 530i, '13 Cooper S
    Quote Originally Posted by sonomaGTLN2 View Post
    The 318ti used an e30 small case diff. The e36 diff is different, at least externally. That said, after this I wonder how similar the internals are between the e30 and e36. I've heard that small case e30 internals can be made to fit into the e21 diff. Since the 318ti also uses a 3.45:1 final drive ratio (4.45:1 for auto), you could hypothetically fit a 3.45:1 out of a ti to fit an e21 with the same effect as the e36 318i diff. A 318ti LSD goes for about as much as an e21 LSD though (they're pretty rare).
  9. #34
    Canada
    e84, e36, e21
    Pinions are interchangeable. First post updated with pictures.
  10. #35
    Nov 2005
    Mills River, NC
    '82 E21 320i
    Quote Originally Posted by joey79 View Post
    Cool!
    Next question.
    What's involved in removing the carrier bearings?
    Can they be removed allowing placement of the LSD unit without shaving the case and then refitted through the sides?
    Thanks!
    Answer: "Don't you think I thought of that before taking a die grinder to my case!?"
    Response: No, seriously. What part of getting those bearings off makes for such an obstacle?
    Eric P.
  11. #36
    Canada
    e84, e36, e21
    The case has to be shaved. The lsd unit and ring gear are the binding points, not the bearings.
  12. #37
    Dec 2009
    SLC Utah
    1980 320i
    sorry to resurrect an old thread but can you just swap the e36 3.45 gears on a e21 3.91LSD carrier? you've already stated the pinion is the same, what about the ring gear?
    "Most men die at 25, we just don't bury them until 70."
  13. #38
    Apr 2009
    Los Angeles
    1982 320i
    They should be the same I think, but aren't e21 3.45 opens easy to find?
  14. #39
    Central Jersey
    1979 335i
    yeh the point was to use the other ratios since the e21 limits you to 3.45 and 3.91
  15. #40
    Dec 2009
    SLC Utah
    1980 320i
    i've only found 3.91s
  16. #41
    Canada
    e84, e36, e21
    Finally got the diff assembled, after waiting for parts/tools/etc. It all went together smoothly and feels good while turning it. Gear contact pattern looks good. I don't have a way of precisely measuring backlash, but it feels like every other good BMW diff I've felt. A tiny bit of play when rotating the output flanges back and forth. The moment of truth will come this weekend when I get it installed and beat it like it stole something.
  17. #42
    May 2010
    Hobart, Tasmania Australia
    1982 BMW e21 320i
    Quote Originally Posted by jrcook320 View Post
    Cons:
    Same design pretty well all the way through from what they tell me, you can use e21 parts to rebuild a e36 small case lsd and the the same number of clutches.
    reramping and adding extra clutches doesnt seem hard in theory, ive gota get round to pulling my e24 side loader apart and see where we can take some metal away to achieve this. plus i need to see if the mid case e30/36 gear sets fit. Then its time to cut up an unsuspecting rear subframe.
    B Road Blaster
  18. #43
    Canada
    e84, e36, e21
    e24 diffs aren't side loaders, and e30/36 188mm gear sets are interchangeable with e24.
    Changing lockup isn't accomplished by adding extra clutches, but by using different thickness spacers. "Outer disc" (#8).
    http://realoem.com/bmw/showparts.do?...30&hg=33&fg=15
  19. #44
    Ohio
    I think both will increase lockup. More clutches improves clutch life, as well as offers more friction surface which will increase lockup for a given clamp force.
    My wife got me the parts to rebuild my lsd for christmas with the help of a friend, who discretely consulted with me. lol We made sure to get the 2.1mm outter discs and new belleville washers.
  20. #45
    May 2010
    1982 BMW e21 320i
    im sorry i find it quite confronting and almost insulting to be told im wrong when i know otherwise.
    pre 1982 e24 were based on the e12 and had the side loader diffs (as i mentioned, i have one of these setting in my shed) post 82 were based on the e28 and had the 188mm e28/e30/e36 ect ect ect diffs. The side loader crown wheel is the same diameter, has the same size and number of bolts, but the jury is still out on if they are interchangeable.
    in an posi LSD's like ours you have two types of lock up, static (preload) and dynamic (ramp angle), adding one will effect the other. adding extra preload (by adding thicker clutches and or dogs (ions, floaters, spacers as you call them)) makes them lock more but means there is more drag between the wheels, as if the lsd as partially locked all the time and can have negative effects on rear end stability and tends to heat the diff up. while changing (reducing) the ramp angle will add lock on acceleration and deccel, you can even have more lock under acceleration than deccel if you have less angle on the corresponding side of the thrust plate. the idea behind adding extra clutches means the clutches wont have to as much work to create the some amount of friction so they last longer and dont get as hot.
    so the ultimate is to add extra clutches, reduce the ramp angle and preload. this means better turn in, increased lock under acceleration and mid corner stability, longer clutch life and a cooler running diff. i know metric mechanic do this with their diffs and like i said in theory it should be pretty easy to achieve with a mill, different thickness dogs and clutches.
    B Road Blaster
  21. #46
    Canada
    e84, e36, e21
    Sorry man, I wasn't trying to insult or confront. I had no idea the old e24 diffs were side loaders. Ignorance on my part i suppose. I've only seen the late type.
  22. #47
    May 2010
    1982 BMW e21 320i
    thanks for the apology, its ok we are all still learning. i hope what i said about the ramp angles and extra clutches made sense.
    B Road Blaster
  23. #48
    monterey, ca.
    e21, e30 m3. e46 330ci
    "Can't we all just get along?" Rodney King 1992 durning the height of the L.A. riots.
    no harm, no foul. we drive E21s making us part of the "he man womun haters club". did i just date myself?
    for you youngsters, here's a link.
    [ame]http://www.youtube.com/watch?v=wBIC8JTQMMQ[/ame]
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
  24. #49
    Finger Lakes Region
    '79 320/6
    I liked the one where they built that go kart with all the crazy stuff on it. That inspired me and the entire gang back in '77.... no one's lawnmower wheels were safe that summer!
    I still drive daily with no commute...
    The Hazard is All, Praise the Hazard!
  25. #50
    Ohio
    Quote Originally Posted by Beemer Tech View Post
    makes perfect sense. Thanks for the info. At only .1mm increments, I wouldn't think the difference in static lockup would be that significant from 1.9mm to 2.1mm. I wonder what the stock disc thickness was (like anyone could get an accurate measurement at this point)?
    I've heard actually adding a clutch disc requires machine work on the e21 diff. I'll know more once I actually get around to tearing mine apart.
