Results 1 to 5 of 5
Thread: Please verify meaning of instrument cluster light
    Oct 2003
    Cincinnati, OH
    1992 325i
    Today a light came on in my instrument cluster and I am not quite certain what it means. I think it may be telling me that the brake pads need to be replaced, but I am not sure. The light is a red circle with 3 red blocks on both the outside right and outside left of the circle. The actual light is slightly to the left of the ABS light in the cluster. If someone could please verify that this is the brake pad sensor light (or something else) I would appreciate it.
    Thank you
    :O: ---> this is an attempt to illustrate the light, but imagine a colon with 3 dots instead of 2.
    1992 325i
    Apr 2003
    Ft Worth
    97 M3 Coupe
    You're correct, brake pad sensor has been set off...Roon
    Sep 2003
    Birmingham, UK
    BMW 850 and E55 AMG
    spot on - the technical name is " brake linings worn" in other words, the pads are worn to the stage they need replacing.
    Giftschrank Projekt
    Vancouver Island, Canada
    1991 320i
    My pad sensor has also gone off, however I was just in the brakes and they seemed to have a great deal of life left. What's the deal?
    Estonia
    1999 328i & 2006 Mazda 6
    Your pad sensor wire is broken.
