Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 74
Thread: rack spacers
  1. #26
    Jul 2006
    Gainesville Fl
    2JZ FD3S, 2JZ M3, 95 M3
    They work guys.
    -Andrew Mensah
  2. #27
    western,MA
    87 swapp e30,boosted e36
    m3nsah you should post some pics of the angle on your car, that'd be much appreciated.
    Jacques Cousteau could never get this low
  3. #28
    Orlando, FL
    2004 M3 Coupe
    I just bought an e36 325, pretty well setup for drifting. I'm getting 41 degrees of angle on the outside tire (so the left tire, with the rack turned all the way to the left).
    I thought spec was about 38 degrees. Does this mean the car already has rack spacers in it? What's the next step for more angle?
  4. #29
    Jul 2006
    Gainesville Fl
    e46 control arms and modded knuckles.
    -Andrew Mensah
  5. #30
    May 2010
    San diego.
    95 325is.
    Your saying that 3 degrees is the most you get with rack spacers? what size?, when i installed mine wich i dont have on right now, it seems more than only 3 degrees.
  6. #31
    Aug 2008
    Lakeland Florida
    1999 328ic , 2002 325xi
    it might have the stock limiter washers removed.
  7. #32
    May 2009
    Santa Cruz, CA
    e36 325is/350z
    Just curious if anyone runs any toe out on the front end WITH limiters - i used to run 1.5 degrees toe out in my old car for better turn in @ autox, but it would help with a little bit more angle on the outter tire. I'm planning on running 1.5 degrees toe out on the e36 with some 4mm spacers.
    tc
  8. #33
    Mar 2008
    Bunker Hill, WV
    95 M3, 07 Titan, 96 XJ
    i run toe out.. big time.
    idk if you can see it in this photo.. kinda
    E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
    Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
    *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
    Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
  9. #34
    Orlando, FL
    2004 M3 Coupe
    Quote Originally Posted by Piner View Post
    Did my car come with limiters/spacers? I thought it was 328s only, but I'm still learning this stuff. Mine is a '94 325i sedan.
  10. #35
    Jun 2010
    PA
    95 325I
    Quote Originally Posted by alanbmoore View Post
    Pull back the rubber boot and take a look.
    ( originally posted by PROTOMOR )
    "It's like telling your child it's ok to snort coke off a cheap hooker's ass. It's ok if you do it, but you really shouldn't. And by doing it in front of your child, you are telling them it's ok to snort coke off a cheap hooker's ass. "
  11. #36
    Dicktone Limo
    i dont think any E36s came with limiters? just stock lock washers which act as a limiter. so yes. you probably do have limiters lol.
  12. #37
    coatesville,pa
    OBD1 s52 Jank-Wagen
    I'll take 4 of those spacers if you still have them
  13. #38
    Marietta, GA
    06 Impreza Wagon
    Quote Originally Posted by slitz View Post
    you can order a pack of 25 of them for less then 10 bucks
    98055A232
    Packs of 25
    In stock for $7.52 per pack
    Inside Diameter
    18 mm
    Inside Diameter Tolerance
    +.23 mm to +.05 mm
    Outside Diameter
    25 mm
    Outside Diameter Tolerance
    -.065 mm to -.275 mm
    Thickness
    1.0 mm
  14. #39
    Marietta, GA
    06 Impreza Wagon
    98055A232
    Packs of 25
    Inside Diameter
    18 mm
    +.23 mm to +.05 mm
    Outside Diameter
    25 mm
    Thickness
    1.0 mm
  15. #40
    coatesville,pa
    OBD1 s52 Jank-Wagen
    You already have this thread started so feel free to steal the pics and info below to make your post a DIY guide for others.
    I picked up the spacers from McMaster and all you need to do is ensure that the ID and OD are the same as your rack.
    1. Jack the car up. You dont need to remove the front wheels but it can make things easier.
    2. Slide the boot back and unscrew the inner tie rod
    3. Remove the limiter washer and throw in the new spacer(s). Dont think that 20mm worth of spacers is ideal because you will just smash your tire into the frame and run the teeth off of your rack.
    I went with 5mm because it clears the frame no problem but still adds a lot of angle.
    4. Add loctite... sh!t is cheap and its a lot easier to drive with your tie rod connected..
    5. Reconnect the inner tie rod and replace the dust cover.
    6. ALIGN THE CAR! You will have major toe out at this point and it will feel like you are driving a water bed.
    You can do this by eye if you simply adjust the outter tie rod to compensate for the spacers. if you add 5mm, then pull the outer tie rod IN 5mm...
    7. Wheels on, jack down, b.out
    BEFORE:
    E36 M3 Full lock (et12 8.5" wheels)
    AFTER:
  16. #41
    new zealand
    1992 e36 bmw
    mint thread guys , any one running a coil over rear end in a e36??
  17. #42
    Nov 2009
    Spain
    1995 M3 e36 286 Euro
    That washer may let on or off of the rack
    with only two spacer that is the new full lock?
    looks awsome..
    95' Euro Bmw M3 e36 286 Hp
    83' 318i E30 K-jetronic
  18. #43
    coatesville,pa
    OBD1 s52 Jank-Wagen
    That is 5mm worth of spacers, and in my case involved 5 1mm spacers
  19. #44
    Oct 2007
    3-R, Qc, Canada
    97 328is, 86 944 turbo
    Can it be dangerous to stack 5 1mm spacers ?
  20. #45
    fairfax,va, usa
    2 E30s and a maxima
    Yes
  21. #46
    Oct 2007
    3-R, Qc, Canada
    What is the right dimension for an e36 rack ? 18in 25out 5mm thick ?
  22. #47
    Jul 2010
    NC
    e34 528i/5
    I haven't had any problems with my stacked 1mm spacers. I daily my car and they've been on there for almost a year now.
  23. #48
    May 2010
    San diego.
    95 325is.
    Quote Originally Posted by philip77o View Post
    naaaaaaa BS.
  24. #49
    Dicktone Limo
    I'd check them once in a while, but with loctite applied to nice dry clean threads you should be all good.
  25. #50
    Oct 2007
    3-R, Qc, Canada
    what is the good washer size for an e36 ?
