Results 1 to 25 of 74
Thread: rack spacers
    western,MA
    87 swapp e30,boosted e36
    rack spacers
    i just got some washers i plan to use as spacers 1"oD .75iD"
    i was wondering if there is any other options for spacers out there? im going to try to install them on my spare rack tomarrow.
    any one have pics of them being installed? possibly a walk through i have a decent idea of what im doing just want to see some tried and true methods.
    Jacques Cousteau could never get this low
    Mar 2008
    Bunker Hill, WV
    95 M3, 07 Titan, 96 XJ
    just make sure there nto any larger then the part of the tie rod that goes into the rack.
    E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
    Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
    *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
    Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
    Jul 2010
    NC
    e34 528i/5
    ^+1.
    Steps:
    1. Secure car then jack up the front.
    2. Remove wheels.
    3. Loosen the outer tie rod ends from the knuckle.
    4. Loosen the inner tie rods from the rack.
    5. Mark the inner tie rod where the outer was at on them and mark them closer to the rack the same distance as the spacers.
    6. Adjust the outer tie to the previously made marks.
    7. Insert spacers and reassemble.
    Pretty much a quick rundown of the process. Also tools needed will be a 14mm, pipe wrench (or proper size for inner tierod), and a sharpie marker. I think that the most of it. It's a pretty simple task and shouldn't take more than an hour or so.
    Jul 2006
    Gainesville Fl
    2JZ FD3S, 2JZ M3, 95 M3
    anyone got a pic of where it goes?
    -Andrew Mensah
    Feb 2008
    San Diego, CA
    95 bmw 325is
    its super basic, just pull back the dust cover, unscrew your inner tie rod from the steering rack, remove the limiter washer, slip the spacer over the threads and screw it back into the rack and re align. Done.
    Jul 2010
    NC
    e34 528i/5
    Quote Originally Posted by dirty30 View Post
    This, and I forgot to mention the limiting washer.
    western,MA
    and loctite. i should be doing this today. mensah ill take a few pics for you if you'd like
    Florida
    1990 325iC, 1987 325iS
    pics please
    Jul 2010
    NC
    e34 528i/5
    Taken from BreakDancer's build thread.
    Quote Originally Posted by BreakDancer View Post
    Jul 2006
    Gainesville Fl
    thanks, thats horribly out of focus lol, but that works. i guess ill have to take it apart and see for myself.
    -Andrew Mensah
    May 2010
    San diego.
    95 325is.
    Heres 2 pics to get better view.
    This is a 4mm spacer.
    western,MA
    These are actuly pretty much what I ended up doing. Ended up a little better than the washers( Wich I still have grade 8 washers 1 x .75 I have 3 for each side)
    I might put those on my other steering rack from the 328
    I hear 1.8 z3 racks are really good is this true?
    Aug 2008
    Lakeland Florida
    1999 328ic , 2002 325xi
    ^ they will yeild you less steering angle though, the rack is internally shorter.
    Dec 2008
    Orange County, CA
    94 325is
    What is the biggest spacer that we should put on our steering racks? Most people use a 4 to 5mm spacer correct? Anyone have any insight on this?
    Aug 2008
    Lakeland Florida
    ^ most people I have seen do 5mm since aparently the rack runs out of teeth and you don't get any benefit out of larger than 5mm. But thats based off other people since i personally have not done rack spacers.
    fairfax,va, usa
    2 E30s and a maxima
    I talked to a guy in europe and he claimed 7mm was the limit. But he also claimed it was too much angle (started majorly hitting stuff).
    I have 5mm spacers and had to add 1" spacers onto my et25 17x8 front rims AND add E46 control arms to clear. Now I slightly rub on the control arm. Ackerman boo.
    May 2010
    San diego.
    95 325is.
    I also think 5mm will be the apropiate max size, in my personal experience the first time i installed 4mm they where rubbing pretty bad and i took them off, but that was mostly because o my stupid front wide tires (245/35/18).
    Then the second time i installed the same 4mm but with 225/40/18 with a 5mm tire spacer it does rub but only under load but its minimal,
    thats with stock e36 control arms and a 5mm tire spacer, depends also on the rim offset two the outer the better.
    im guessing that with the second setup (4mm, 225/40/18) and 1" spacer will stop the rubbing but i think i need to modified fender to accept the 1" spacer and i dont want to get in to that now.
    Aug 2008
    Lakeland Florida
    ^ yeah the biggest reason I don't run rack spacers was with my previous wheels I was rubbing the frame even with just the rack limiters removed. I have much lower offset wheels now so i should be able to run the spacers. Now the problem is that I am like 5K miles away from my car.
    Jul 2006
    Gainesville Fl
    spacers vs limiters? can i see a pic of the limiter? i would go and look but its 30degrees out this morning in florida.
    -Andrew Mensah
    Jul 2010
    NC
    e34 528i/5
    The limiter is just a larger OD washer.
    western,MA
    i got a crap load of spacers pm me if anyone wants some there about 2.25mm thick so you can stack them 2 on each side for 4.5 spacers
    May 2010
    San diego.
    95 325is.
    i need to put back my spacers but need 1" tires spacers, you guys think i can get away with mi 4mm rack spacers a 5mm tire spacer and 225 or 215/35/18 tires in front?, i think maybe but dont know.
    fairfax,va, usa
    2 E30s and a maxima
    I've got E46 control arms and 1" wheel spacers. I'm at like 2.5 inches out from stock lol.
    Aug 2008
    Lakeland Florida
    well with 17X7.5 +38's I rub just taking my steering limiters off.
    western,MA
    so i still have a crap load of spacers left if anyone wants a set i've sold them to a few people a couple on BF.c i haven't heard any negitive feed back on them,
    pm me for info
