i got 19's and the other night i was making aright hander. i was gong dowm hill an there was a big dip where the two streets met,well when i hit that dip at abou 5-10mph my right front wheel grabbed the corner of the fender and pulied it out a bit
my car is not even lowered!
is there away i can pull the front fenders out so something like this cant happen
thanks
You can get ur fenders rolled on the inside and cut away the inner wheel well. But you can only roll so much and cut so much.. if ur rims are too wide.. (Which they rear kinda are) u maybe stuck with it. Or major fender work can be done.
06' BMW 530xi
02' Porsche 911 Carrera
11' BMW X3
Yeah if that doesn't work, then talk to Dado about it Ryan.
Not much you can do, but creep through the streets. The tire is just too tall. When you hit that dip, it was the equivalent of having you car lowered an inch or so (for that split second of compression). If you turned the wheel just as you hit the dip, you created a unique scenario where the tire will pull the fender - just as it would on a lowered car w/ 19's.
