I'm glad you got it working, WayneC. Just wondering, does it work with just <supportedRuntime version="v4.0"/> (thus no build version number). If that works as well, it may be safer to use with future .NET updates in mind...
Will give it a try with that tomorrow & let you know
My line in my last post came from M$ & I did not like having to specify the version precisely but for now it means I can test it under v4 & see if I can find any errors
Doing battle with adding my specific series into NCS at the moment my daten series folder is there & every other series shows up but not mine. Data import problem it seems
I will work it out tomorrow, it is late here
EDIT
Yes the statement works with just v4.0 <supportedRuntime version="v4.0"/>
Tried using an SKU statement as M$ seemed to indicate that would also work but failed, probably syntax error on my part
M$ Info came from http://msdn.microsoft.com/en-us/library/w4atty68.aspx
Thanks for the update, WayneC!
In case others want to use NCS Dummy on a system with only the Microsoft .NET Framework 4.0 installed, get the updated the config file - download link (278 bytes). For installation instructions see message 111 of this thread.
Just wanted to post and say thanks! I've been on the steep end of the learning curve for all this BMW OBDII software stuff for a couple weeks.. With the aid NCS dummy, NCSExpert was the first peice I've used sucessfully! I was able to modify the E46 M3 cluster I bought to put into an E30 (turning off stuff like DSC, SMG, tire pressure warning, etc). Unfortunately the cluster I have doesn't support nettodat coding, so I'll have to use the alternative method for custom settings, but it doesn't seem impossible.
edit: question - I'm pretty far into modifying a disassembled KMBE46M3 file. Can I add new keywords to SWTPSW06.DAT? It looks like the car I'm using goes up to 0412, is FFFF the limit? Then I wouldn't have to use "0007 wert_01" for all my custom settings..
edit2: nevermind. the answer is yes.
Hi, thanks for this great app...I would like to know how to do this VIM, I also have an E65 and there is no coding procedure available to enable the video in motion but I'm sure it is controled by codes, so it should be possible. how can I change order options? and how to creat +VIM that the MMI knows what it is?
Thanks alot in advanced.
Just noticed the new version, I like the trace editor. Is there any chance you make it so the window can be resized? Thanks revtor.
May I kindly ask to have this thread sticky? Thank you.
can anybody hep with this message:
following features is invalid fa: +kmp3
I could show my german car but I prefer to show an italian product ...my wife's boobs
BLooD30: I have been thinking about a redesigned user interface where the trace editor plays a more central role, but I'm currently engaged in another (completely unrelated) project so I can't tell when I'll have time to work on that.
vince59: That doesn't look like an NCS Dummy error message. This topic is for NCS Dummy and related discussions only. I suggest you start a new topic and I strongly recommend to provide more information if you want helpful replies.
Thanks revtor...I agrre, it was a straight question but wrong place. It is an issue form a friend of mine. Thx
Revtor,
First, let me say THANK YOU for this awesome tool! It makes modification very easy!
Quick question regarding these comments:
I ran into this when coding. After reading I had cas2.c05. After execute job it read cas3.c09. I used NCS Dummy to modify selecting cas3.c09 using trace function. Finally, I coded new .man to car and ended with it reading cas3.c09. I should have asked before hitting the execute job button but am I OK with how I proceeded?
I haven't tested the car yet. Late at night...
http://forums.bimmerforums.com/forum...8&postcount=31
revtor
Thank you for having clarified the situation with COAPI-1063 error
I encountered the same problem and wondered what was wrong.
the e-sysdoes not e-sysDummy?
E46in the body,when a file TV2.C02 changes, everythingcomes back....why?
SIGNATURE : 00010001010163 02
0000 - DATEINAME - S - NAME
0001 - SGID_CODIERINDEX - B(B) - WERT,WERT2
0002 - SGID_HARDWARENUMMER - S(S) - WERT,WERT2
0003 - SGID_SWNUMMER - S(S) - WERT,WERT2
0004 - SPEICHERORG - SS - STRUKTUR,TYP
0005 - ANLIEFERZUSTAND - (B) - WERT
0006 - CODIERDATENBLOCK - {L}LWS - BLOCKNR,WORTADR,BYTEADR,BEZEICHNUNG
0007 - HERSTELLERDATENBLOCK - {L}LWS - BLOCKNR,WORTADR,BYTEADR,BEZEICHNUNG
0008 - RESERVIERTDATENBLOCK - {L}LWS - BLOCKNR,WORTADR,BYTEADR,BEZEICHNUNG
0009 - UNBELEGT1 - {L}LW{B}(B) - BLOCKNR,WORTADR,BYTEADR,INDEX,MASKE
000A - UNBELEGT2 - (B) - WERT
000B - KENNUNG_K - SS(S) - IDENT,WERT1,WERTN
000C - KENNUNG_D - WW(WW) - HEXWERT1,HEXWERT2,HEXWERTN1,HEXWERTN2
000D - KENNUNG_X - WW(WW) - HEXWERT1,HEXWERT2,HEXWERTN1,HEXWERTN2
000E - KENNUNG_ALL - SW(W) - KENNUNG,HEXWERT1,HEXWERTN
000F - PARZUWEISUNG_PSW2 - (B) - DATUM
0010 - PARZUWEISUNG_PSW1 - W(B) - PSW,DATUM
0011 - PARZUWEISUNG_DIR - {L}LWW{B}(B)(A)B - BLOCKNR,WORTADR,BYTEADR,FSW,INDEX,MASKE,OPERATION, EINHEIT
0012 - PARZUWEISUNG_FSW - {L}LWW{B}(B){B}{B} - BLOCKNR,WORTADR,BYTEADR,FSW,INDEX,MASKE,EINHEIT,IN DIVID
DATEINAME : "TV2.C02"
SGID_CODIERINDEX : 02 ()
SPEICHERORG : "BYTE" "FREI"
ANLIEFERZUSTAND : (00)
CODIERDATENBLOCK : {} 00000000 0002 "Laender"
PARZUWEISUNG_FSW : {} 00000000 0001 0685 {} (FF) {68} {} // MULTIFUNCTION_1
PARZUWEISUNG_PSW1 : 00CF (1C) // ece
PARZUWEISUNG_PSW1 : 038C (1C) // great_britain
PARZUWEISUNG_PSW1 : 0087 (1C) // us
PARZUWEISUNG_PSW1 : 008D (1C) // kanada
PARZUWEISUNG_PSW1 : 03B2 (9C) // deaktiviert
PARZUWEISUNG_PSW1 : 03B1 (9D) // aktiviert
PARZUWEISUNG_FSW : {} 00000001 0001 0686 {} (FF) {68} {} // MULTIFUNCTION_2
PARZUWEISUNG_PSW1 : 00CF (00) // ece
PARZUWEISUNG_PSW1 : 0087 (20) // us
PARZUWEISUNG_PSW1 : 008D (20) // kanada
PARZUWEISUNG_PSW1 : 038C (10) // great_britain
CODIERDATENBLOCK : {} 00000005 0001 "Widescreen"
PARZUWEISUNG_FSW : {} 00000005 0001 0687 {} (FF) {68} {} // WIDESCREEN_MODI
PARZUWEISUNG_PSW1 : 038D (00) // wert_00
PARZUWEISUNG_PSW1 : 000A (01) // wert_01
PARZUWEISUNG_PSW1 : 0028 (02) // wert_02
PARZUWEISUNG_PSW1 : 0027 (04) // wert_03
PARZUWEISUNG_PSW1 : 005B (08) // wert_04
Revtor...I downloaded the NCS for dummies 5.01 and for the life of me I cannot get to the trace editor! What do I have to do to get the trace editor to work...I was playing around with it and getting ready to code DVD in motion for the CIC module...I just randomly pic the daten file for E89 CIC.C09, made the changes to the FF...Do I physically have to have a trace file read of the CIC.C09 module from the car for the trace editor to magically appear??? Thanks
ARGOS: I'm really sorry, but I don't understand your question...
cn555ic: Yes, the trace editor only appears when you load a FSW/PSW or nettodata trace file. The idea is to read a trace file from the car, load it in NCS Dummy, make changes to it in the trace editor and then export it to a trace manipulation file from which you can recode the module with NCS Expert.
Revtor. Here is the thing. I already have a trace file in my work folder and I tried to view it but it would not allow me to see it. What am I doing wrong here? The trace file was from a NFRM module. Does it have to be actually a live connected connection to the car and then access to trace editor is present? The other version were not like that if that's the case
cn555ic: No connection to the car is required by NCS Dummy. Can you please include a copy of the NCS Dummy log? To do so, launch NCS Dummy and reproduce the error in as few steps as possible (I mean, don't do it after performing other tasks in the application - try to keep the log short), next right click in the log area and choose "Copy Log" from the popup menu, and then paste it here in a reply.
If no error is shown, please send the trace file to and specify the chassis and exact module (not just "NFRM" but something like "FRMFA.C11").
I try to load trace files but the bottom half is grayed out and it won't allow me to even load it. I will take a pic of what I mean. Very strange. It's probably me doing something really silly and dumb that I can't access the trace file but I will take pics of what I am doing that gray area of trace editing is not available.
programtracefilesfor e-sys,similar to NCS Dummy.....
Revtor. I got it to work. I inputed the wrong module number. Everything works as advertised. Great program BTW as for disassembly and assembly of the Ediabas dates files. Thanks. Now I should be able to code CIC DVD in motion. Should I keep an old cic copy of the non edited Speed lock variables for backup in my Ediabas dates files?? What's your opinion on that??
I just converted all my CIC files from NCS daten files to the appropriate values (FF) to enable DVD in motion when I do coding for it! This program works awesome and very efficient. Now all I would need to do now is basically use the NCS to change the values on the trace value, and magically the DVD in motion is ready and avaliable...Revtor...so basically now I code the car like normal and then read module and then basically edit the trace file with NCS to enable DVD in motion and then code the car correct...My edited CIC files will be functional correct?
ARGOS: Currently I have no plans in that direction.
cn555ic: If you modified the CIC file(s) as described in the disassembly chapter then, yes, all you have to do is read the FSW/PWS trace file from the car's module, edit the trace file in NCS Dummy (or manually) to set the parameters that represent value FFh, save as "FSW_PSW.MAN" trace manipulation file and recode the car with it.
In this case you can safely keep the modified CIC file(s) permanently in the NCS Expert DATEN. The default behavior has not been changed, so the modifications do not have any effect unless you explicitly specify the modified parameters in a trace file. You don't have to keep the original files in the NCS Expert DATEN (if you renamed the files, NCS Expert doesn't "see" them anyways) but I recommend to keep backups somewhere.
FF is the correct value to use in the disassembled file.
When mixing numeral systems things can get very confusing rapidly: When someone writes a number like 100 it's not always clear what base is used. Is it decimal 100, is it hexadecimal 100 (= decimal 256) or is it binary 100 (= decimal 4)? To cope with this problem people came up with several notations to indicate the base. Decimal numbers can be represented as 100d, 10010,... (although they are usually written without any base-indication), hexadecimal numbers can be represented as 100h, 0x100, 10016,... and binary numbers as 100b, 0b100, 1002,... It's just a matter of avoiding confusion. It has no effect on the value itself other than indicating the numeral system.
NCS Dummy doesn't specify the base to keep the output clean, but all numbers (address, mask, data,...) are hexadecimal.
Okay cool. Just making sure. Thanks.
