Page 3 of 43 FirstFirst 1234567891011121328 ... LastLast
Results 51 to 75 of 1052
Thread: NCS Dummy - Taking the expert out of NCS Expert
  1. #51
    Nov 2007
    Belgium
    Made in Germany
    Quote Originally Posted by jgold47 View Post
    revtor - does your profile included with the package work with all models or just an e31? Also, what its the difference between yours and fisters (does it matter which one I use?)
    My profile is exactly the same as Fister's and works with all chassis. If you already have Fister's profile, there's no need to use mine.
  2. #52
    Nov 2007
    Belgium
    Made in Germany
    Thread merge notice: If you got to this post directly from a link and expected to find information about NCS Dummy, click here to go to the first post in this topic where the information now is.
  3. #53
    united kingdom
    2006 530d m-sport
    Nice!, did you get all the trace files I emailed to you?
  4. #54
    Philadelphia, PA
    2005 M3 & 2004 330i
    Hey revtor sorry I never got those trace files to you I ended up having to reinstall windows, and then kinda forgot about grabbing the daten files until much later. I'm at my dad's right now - if you still need any E60 LCI info, I'll get it (assuming my dad's car has the appropriate modules).
    I've got a question: How feasible would it be to add a feature to NCS Dummy that shows the default options for a given VO/FA or ZCS? It'd be interesting to see what the effects of changing the VO or ZCS would be without having to always hook up to the car and recode everything. I'd imagine NCS Expert gets the default configurations from somewhere
    edit: I just finished reading through your post in detail - this is fantastic stuff! I've got another question... I understand the interpretation of the nettodata.trc files and how to change a value in there... How would you go about writing the nettodata to the car though? I know how to do it through PASoft, but I didn't think NCS Expert could write data withouth an fsw_psw.man.
    Thanks for your time... the previous iterations of this software have helped me tremendously, and this new version even better
  5. #55
    Nov 2007
    Belgium
    Made in Germany
    BLooD30: I did! Thanks a lot for these. They were extremely useful for testing!
  6. #56
    united kingdom
    2006 530d m-sport
    Revtor? I would be interested in what teraphantom asked as well.
    Any ideas what functions control the microphone?, I have managed to disable mine, feel really silly
  7. #57
    Nov 2007
    Belgium
    Made in Germany
    Quote Originally Posted by TerraPhantm View Post
    Thanks for the suggestion! It's an interesting thought, but I can't say how feasible this would be. At the moment I have no idea where the relations between ZCS/VO are stored and whether or not it would be possible for NCS Dummy to process these files. I'll take a look at this later, but for now I want to concentrate on fine-tuning version 0.4.0.0.
  8. #58
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by revtor View Post
    Understood. I've been doing some digging around in the E46 folder, and it seems that all the "*.000 and *.X00 probably have something to do with it. Some seem to be plain text, and some not. If I had to guess, the ones that aren't plaintext are what NCS some how uses to determine what options to set.
    E46AT.000 for example seems to have a list of all the valid option codes, and has what those codes correspond to in the comments. It also has a list of valid chasis/region codes for each model. E46SGFAM.DAT has a list of the possible modules, and also indicates which ones store ZCS and which ones store VO/FA. I could've sworn I saw that that defined the minimum coding index for a given build date, but I can't find it again... so I probably misread something else.
  9. #59
    Finland
    E38 740iA -99 & 740D -00
    Hi revtor and thanks for great software NCS Dummy!
    But I have problem with your NCS expert profile.
    I'm working right know with my e38 and I can read ZCS information from EWS or IKE but after that I choose to go back to select ecu, ncs expert give error like this: "COAPI-1142: PSW Faulty e60".
    It's interesting that it says e60. It doesn't give this error if I choose Expertmode profile for example but of course I can't do much with that profile.
    NCS Expert have worked before with your profile but I can't remember when it stopped working right. I have tested my installation with other computers and with other interfaces (i have usb k-line and real serial ADS) but no help.
    Could this error relate to my ediabas installation? Does ncs expert use ediabas ecu folder files with coding or is those only used in diagnostics with inpa?
    Hope that you revtor, or someone else could help me.
    Thanks alot!
  10. #60
    Nov 2007
    Belgium
    Made in Germany
    Check "FSW_PSW.MAN" in the "NCSEXPER\WORK\" folder and make sure this file is empty. There may be some left-overs from a previous coding operation in it which are incompatible with your E38. It's recommended to always empty (not delete) the "FSW_PSW.MAN" file after coding.
  11. #61
    Finland
    First line was something about e60. I just remember that I coded different battery (FA number) for my friends 530d
    How stupid problem I had, hope it works now, I have to go to test.
    I though that NCS Expert overwrites that file when it reads car's information, but I was wrong.
    Thanks!
  12. #62
    Nov 2008
    UK
    bmw e60, Cooper s r53
    Does anyone know where i can download the newest version of Dummy from? got the early version but doesnt recon the E60 and the link for new one is down ?cheers
  13. #63
    Nov 2007
    Belgium
    Made in Germany
    oneeyefrail: The opening post of this topic always links to the latest version.
  14. #64
    Nov 2008
    UK
    yea that was the link i was on about ? just opens up,asks u to download then nothing..just s stops ,cheers
  15. #65
    Nov 2007
    Belgium
    Made in Germany
    I'm sorry but the problem is at your end... I know the server experiences some downtime every once in a while, but nothing is wrong with the download at the moment.
  16. #66
    Nov 2008
    UK
    mmm ok i ll try another computer thank you for the reply
  17. #67
    Jun 2010
    germany
    E90
    i love this program very very good work...respect
  18. #68
    Sep 2009
    USA
    any time, any place
    cool project, thanks for sharing with the others!
  19. #69
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    great project - thanks so much for making it available.
  20. #70
    Dec 2010
    Jersey City, NJ
    2000 740ilS
    Hey, revtor,
    Been trying to use you NCS dummy software on my e38, but I get up to the part of hitting the back button, I getting
    COAPI-1020: can not open file for reading
    C:\NCEXPER\WORK\FSW_PSW.MAN
    First I tried your profile and Fisters, I get this message, when I use Expertmode, it goes through.
    One of your replies state to a fellow E38 owner to make sure the FSW_PSW.MAN was clean and it is.
    Any other route I should take to make either one of the profile to work.
    As everybody else posted, thanks for shareing, I feel it will be very helpful software when I get it up and running.
    Thanks,
  21. #71
    Nov 2007
    Belgium
    Made in Germany
    Make sure Windows doesn't fool you by hiding the extension. Perhaps the file you see as "FSW_PSW.MAN" is actually something like "FSW_PSW.MAN.txt".
  22. #72
    Dec 2010
    Jersey City, NJ
    2000 740ilS
    Cool, didn't think about that, I check it out and post back.
    Got it to work but, now there is no translation in NCS Dummy 2, getting the function keyword column, but no translation column.
    I'm working on a E38 production date 12/99
    Oh and it won't read E38-KMBI.C12- "An error ocurred wile reading module functions from "KMBI_E38.C12", Inconsistent date leng... But it will read KMBI_E3.C11
    Steven
  23. #73
    Germany
    93 e30 327i / 95 e34 540
    man, you are my hero!!!
    Thanks for all your work!
  24. #74
    Nov 2007
    Belgium
    Made in Germany
    Quote Originally Posted by myooohmy View Post
    Make sure that "Translations.csv" is in the same folder as "NcsDummy.exe" (if you are running the application directly from the archive, try unpacking to a local folder first) and that the "Translations" checkbox is ticked.
    See "Known isses" in the opening post.
  25. #75
    Germany
    About Nettodata coding... i can't really find anything relating to it, simply do it like the psw with a nettodata.man?
    i have several data to use there, but i haven't figured out how to code it via ncsexpert...
