Page 25 of 43 FirstFirst ... 151617181920212223242526272829303132333435 ... LastLast
Results 601 to 625 of 1052
Thread: NCS Dummy - Taking the expert out of NCS Expert
  1. #601
    The Netherlands
    DE-spec E36 328i/M3 cab
    If it already says 00 is off, 01 is on, you only have to set it to the on value.
    I don't have 2011 335i Daten file. Can you copy-paste the parameter/values here?
    doesn't it say aktiv on either one?
    IG:
  2. #602
    Feb 2013
    san antonio
    2011 335i coupe
    Wert_00 was the only availble option.
    Wert_01 was a parameter that I added because of the function description.
    Adding this parameter resulted in NCSexpert failing to reading this module since.
  3. #603
    Feb 2013
    san antonio
    2011 335i coupe
    the only parameter originally available was Wert_00 value 00
    I added the parameter Wert_01 value 01 it was unsuccessful and NCS EXPERT will no longer read the DSC module.
    I have posted a picture in my profile album since i could not here.
  4. #604
    Nov 2007
    Belgium
    Made in Germany
    vnt: What error message does NCS Expert give when trying to read the DSC module?
  5. #605
    The Netherlands
    Can you upload the file somewhere? I'd like to give it a shot.
    IG:
  6. #606
    Feb 2013
    san antonio
    2011 335i coupe
    The errors recieved when trying to read module DSC_89.C03 after adding parameter are:
    [08:34:53.929] [2015-01-21] [SERIE] 2062 PABD/CABD A_E65.IPS Cod 379
    [08:34:53.929] [2015-01-21] [SERIE] Error on reading coding data DSC_87, C_C_LESEN: ERROR_BIN_BUFFER
    [08:34:54.035] [2015-01-21] [SERIE] 2062 Error COAPI2.CPP coapiRunCabd 6
    [08:34:54.035] [2015-01-21] [SERIE] Error on reading coding data CODIERDATEN_LESEN
    The changes made to the DSC_89.C03 viewed as text are as follows:
    Original DSC_89.CO3 file
    PARZUWEISUNG_FSW : {00003008} 00000010 0001 1C43 {63} (20) {68} {} :
    PARZUWEISUNG_PSW1 : 0066 (00) :
    UNBELEGT1 : {00003008} 00000010 0001 {} (C0)
    UNBELEGT2 : (00)
    Modified DSC_89.CO3 file
    PARZUWEISUNG_PSW1 : 09C2 (01) :
    UNBELEGT2 : (00)
    Original
    Modded
    Thank you for your responses.
  7. #607
    The Netherlands
    Do you have your daten file for me. The DTC_089 file.
    Oh wait you get errors in NCS Expert, thought it already went bad in NCS Dummy.
    IG:
  8. #608
    Feb 2013
    san antonio
    2011 335i coupe
    Attached are the original and modded files.
    change file extension to .C03
    Attached Files Attached Files
  9. #609
    The Netherlands
    Thx. Not behind my pc right now. Will check later.
    Just a brainfart here: what about not adding wert 01, but changing the value of wert 00 to value 00?
    I don't recall exactly not sitting behind my pc, but length is 01, doesn't that mean just one parameter allowed?
    in that case do what I brainfarted.
    IG:
  10. #610
    Feb 2013
    san antonio
    2011 335i coupe
    Not adding another parameter and changing the existing Wert 00 to Value 01 was floating around in my head as one of the next attempts.
    The ony problem is that it does not seem to be as simple as replaceing DSC_89.C03 with the original file. Still unable to read the Module but I can read all other modules.??????
  11. #611
    The Netherlands
    Just so I understand correctly, you can't read the original from the car with NCS Expert?
    Dummy makes a backup so you can recode the module with the original file.
    IG:
  12. #612
    Nov 2007
    Belgium
    Made in Germany
    Quote Originally Posted by MParallel View Post
    The number of permitted different values in a function depends on both the length and (bit)mask. Length 01 means the functions sits within a single byte. A single byte, or 8 bits, is good for a total of 256 different values. However, the function's (bit)mask is 20h (00100000b) which means it spans only a single bit in the byte which is good for only 2 different values: 0 or 1. Anyway, you don't have to calculate the bitmasks - NCS Dummy does that for you. Between brackets in the mask field is the range of values that is valid for the function (00 .. 01).
    Quote Originally Posted by vnt View Post
    At first sight I don't see anything wrong with the changes you made to "DSC_89.C03" so I'm quite sure that has nothing to do with the reason why NCS Expert refuses to read the module. If you make changes that are not permitted (and in theory you can't when using the graphical trace editor) NCS Expert usually gives error messages that clearly hint at a problem with the (modified) module description file. To be honest I have never seen the error you mentioned before. The fact that you restored the original file and NCS Expert is still unable to read the module suggests at another cause (although I don't have any clue at this moment).
    Just to rule out any issue with NCS Expert and its DATEN files, can you remove the contents of NCSEXPER\DATEN\E89 and restore a fresh copy from the SP-Daten. Next remove all files from the NCSEXPER\WORK folder, then launch and close NCS Dummy. The WORK folder should now contain only a single file: "FSW_PSW.MAN". Now try again to read the module...
  13. #613
    The Netherlands
    Just to add information. Sometimes NCS Expert gives me error codes when coding a module, but after I re-read the module, the changes I wanted to make were succesfull.
    IG:
  14. #614
    Jan 2013
    Honolulu
    e70
    After add e53 e39 body with standart operation - have a problem with load files to modify
    dummy say- invalid keyword:
    [E] 18:15:44 An error occurred while reading "C:\NCSEXPER\DATEN\E53\E53_CONF.BAP": Invalid keyword index in chassis configuration file.
    how to fix it?
    other body files loaded good.
  15. #615
    Jan 2013
    Honolulu
    e70
    how to fix it?
  16. #616
    Philadelphia, PA
    2005 M3 & 2004 330i
    If you aren't already, make sure you're on Ediabas 7.x; the newer modules sometimes error out with older versions. Also make sure the latency of your cable is set to 1 msec
  17. #617
    Jan 2013
    Honolulu
    e70
    i run only Dummy sw (no run ediabus,no connect car), and can't see modules in this old body. Other body - no problem.
    may be problem from WIN7 ?
  18. #618
    Nov 2007
    Belgium
    Made in Germany
    Vasilii: My guess is that your DATEN\E39 folder is corrupt/incomplete. You are missing vital files for proper operation. Are the files "SWTASW01.DAT", "SWTFSW01.DAT" and "SWTPSW01.DAT" present in the E39 folder?
  19. #619
    The Netherlands
    In my E89 folder I have the 3 files listed by Revtor, and I can't open your original DSC_89 nor your modded files.
    Since my folder is complete, I would have expected that there would already be a DSC file in there. So I doubt that file is even something that is part of this chassis group.
    Opening either file gives a "[E] 00:14:01 An error occurred while reading "C:\NCSEXPER\DATEN\E89\DSC_89.C03": Unknown function keyword (0C88)." error.
    IG:
  20. #620
    Jan 2013
    Honolulu
    e70
    yes, in ncsexper/daten/e39 - this files not present. I try to here copy this files from sp-daten e39,daten folder - but still don't work. What wrong?
  21. #621
    Nov 2007
    Belgium
    Made in Germany
    MParallel: The "DSC_89.C03" module description file is included with the E89 chassis. Your E89 DATEN might be outdated. Anyway, the modified "DSC_89.C03" will not work on any installation but vnt's unless vnt also distributes the modified "SWTPSW01.DAT". Besides, it is not recommended to use module description files from different DATEN versions than yours. It's a recipe for errors.
    I checked vnt's modified "DSC_89.C03" and it's a perfectly sane file. Whatever is preventing the module from reading, it's not the changes vnt made to the file...
  22. #622
    The Netherlands
    Hmm strange. I was sure these were the latest Daten files. Have to recheck.
    IG:
  23. #623
    Feb 2013
    san antonio
    2011 335i coupe
    NCSEXPERT is now working again due to reverting to my backup folder. Now I have to apologize for waisting y'all's time. I somehow decided to rename the original file MK60_8*.*** to DSC89.C03.
    With all of that said the MK60 file has the same function (DCC_DTC) and contains both parameters for enable and disable no mod needed. When I enable DCC_DTC VALUE 01 nothing happens so it must be linked to something else. Thank you for your responses
  24. #624
    The Netherlands
    No wonder my folder didn't have that file. I do have the MK60 files.
    Somehow Revtor did have a DSC file though?!
    IG:
  25. #625
    Nov 2007
    Belgium
    Made in Germany
    MParallel: See screenshot below. Please note that these aren't the latest E89 SP-Daten either, so it is possible these files got substituted in later revisions. Anyway, the point was that you should not mix module description files from different SP-Daten versions because you will very likely get errors even though the files by themselves might be perfectly sane.
