What OD size are the fronts and rears? The front OD can be 174, 180, or 190mm. Rear is either 114 or 125mm.
when I measured my old 745i it had 180mm front. I measured 735i rears at 114mm. 735i front should be 174mm. Not sure what size the 745i original rears would be. The only way to know for sure is measure your car. You never know what a previous owner swapped on there (on my old car I found the previous owner had swapped 735i rear spring/strut assys on there to delete the load levelling original suspension)
Steve H.
I've gone back and forth with H&R over the last two months trying to get the correct config for my 86 745i. OE front is 180mm and rear is 114mm. H&R does not offer the 180mm front any longer. So I received yesterday a set of 174mm front / 114mm rear and will install them soon to verify that there is not issue with the 174mm vs 180mm for the front application. Based on everything I've measure so far, it looks promising.
Take it from me, be sure to measure your e23 front and rear springs OD before buying any springs.
That is a pretty significant difference in coil spring diameter which is going to affect whether the spring sits in the spring pockets correctly. I replaced struts on my 180mm e23 setup and had them apart, and don't remember there being enough room to fudge a .25" smaller diameter spring in the same housing. Changing to donor 735i housings set up for a 174mm spring should not be a big deal though
Steve H.
We shall see! I'll report back soon.
Well...
31311119707 and 31311119708 front strut housings both cross for US and ECE cars. Borrowed from RealOEM.com when I searched for 11/84 745i strut housing.
Part 31311119707 (LEFT FRONT SPRING STRUT) was found on the following vehicles:
E23: Details on E23
E23 733i Sedan, USA
E23 735i Sedan, USA
E23 728 Sedan, Europe
E23 728i Sedan, Europe
E23 728iS Sedan, Europe
E23 730 Sedan, Europe
E23 732i Sedan, Europe
E23 733i Sedan, Europe
E23 735i Sedan, Europe
E23 745i Sedan, Europe
Details for all
I make E23 parts.
10/1984 745i
11/1984 745i
11/1984 735i (10:1-265/6)
I will be putting up a for sale thread soon they are both the same size springs. FYI i assume we have all read about supposed differences in spring diameters, but i have personally had up to 10 different oem and aftermarket sets and they all have the same diameter. If you guys have different diameters then what year and models are they off of? I posted threads with info a year or two ago when i was doing my suspension.
95 BMW M3 Alpine-
<GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
1986 745i
Front: 180mm
Rear: 114mm
1989 635CSi Alpinewieß
1989 325iC Alpineweiß II
1985 745i Cosmosblau / Pacificblau cloth
1995 525iT S50 / 5 speed Alpineweiß III
1985 635i Cosmosblau
1998.5 M3 Technoviolent
1990 325iC
1999 528i
How do they ride versus Dinans?
I make E23 parts.
10/1984 745i
11/1984 745i
Roughly how much u paid for your whole Coilover set up? If u dnt remeber it's okay.
what other springs have you had to compare them with though? The complete dinan set up is by far the best e23 suspension. The ST springs are pretty darn close to Dinan too. I would love to get my hands on some racing dynamics springs as they are the only progressive ones and i'm curious how they feel. I can't speak for motorsports series or h&r but i know bavauto are on the bottom of the list for springs. The dinan and st springs i have are both about 6" in front and 3.5" in rear, i'll check out a better conversion. Whoops looks like i need OD
95 BMW M3 Alpine-
The H&R are progressive as well.
Yeah i just checked the pics it looks like it. I'm sure the h&r work good but last i checked they were expensive too
95 BMW M3 Alpine-
About $350 including shipping.
Looks like the dinan and st are 180mm and 114mm which seems to be most springs
95 BMW M3 Alpine-
1990 325iC
1999 528i
I'm talkin dinan springs and dinan valved billies combo. I've never ridden the mosport so they might be similar as well. Are they progressive? Got pics? This stuff was gone over last year or two in my threads but other than springs and sways and of course strut bars the only other suspension parts there were was the dinan camber plates. Using fresh billies makes a huge difference when adding springs. Imo just having fresh oem bushings and ball joints with springs and sways and fsb is about all you can do with these cars. I highly recommend it.
95 BMW M3 Alpine-
The springs are paired with custom valved Bilstein sports. They were sold as a package back in the 80's. I have a copy of the catalog somewhere, but I believe Hitman has a PDF of it.
The car also has the Motorsport Series swaybars. 29mm up front.
When I bought the car, it appeared that all of the suspension stuff had been on there for a very long time, but it rode and handled very well on the drive home to Memphis from Phoenix, AZ. I also did a trip over to Vintage in Winston Salem. Last spring, I sent the rear Bilstein Sports back to Bilstein and had them rebuilt. I need to do the fronts, just haven't gotten around to it.
The car handles just as well as the two Dinan sprung cars that I've driven, and the ride is actually better. I know that's subjective, but I have put about 12,000 miles on the car since I bought it a little over two years ago and it is a superior road trip car as far as comfort and handling as any of the 5 cars that I currently own.
I'll try to dig up the catalog if Eric doesn't beat me to it and see if it has the spring rates.
1990 325iC
1999 528i
I have it. If anyone wants it, drop me a note. I even have a sticker from them
Also have factory ECE prospective brochure showing the price (in DM) and code of all options. Keith (with the Hartge E23) sent it to me.
I make E23 parts.
10/1984 745i
11/1984 745i
For suspension in general having fresh joints and bushings as well as good wheels makes huge handling improvements. The sways, springs and billies are the icing on the cake. Has anybody searched somehow all the old car magazines for mention of motorsport series from back in the day? So Flint you're saying your stuff was on the car years ago? That's interesting cuz that meand it wasn't part of that nos lot. I didn't realize they had matching billies too. Does it have the adjustable endlinks too?
95 BMW M3 Alpine-
Yes, three way front and rear.
I make E23 parts.
10/1984 745i
11/1984 745i
Not holes i meant adjustable length heim ball joints type links?
95 BMW M3 Alpine-
