Page 7 of 8 FirstFirst 12345678 LastLast
Results 151 to 175 of 191
Thread: E36 M3 Control Arm Ball Joint Replacement with E30
  1. #151
    NY
    M3
    I need to replace my ball joint on my 1998 e36 m3 coupe. I can literally shake the wheel back and forth and see the ball joint moving left and right.
    I ordered the e30 m3 lemforder inner and outer ball joint. I just need to press old ones and press new ones in. Does the Autozone Loan-A-Tool Ball Joint press sufficient enough to do the job?
  2. #152
    Marietta, GA
    95 M3, 87 535is
    Quote Originally Posted by e46tknv View Post
    No. You are going to need a 12-ton press to do the job.
  3. #153
    greenwood sc
    1999 m3 convertible 5spd
    12 ton wasnt enough to get mine out, but seems to work for most people. Sounds like you are just doing one side. I would do both. Remove the control arms and take them to a machine shop and have them pressed in, they shouldn't charge much.
  4. #154
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Nope, you need at least a 12, 20 is better.
  5. #155
    South Carolina
    2004 330 vert 2004 X5
    Yea I just did this with my 20 ton. 12 ton would be a struggle.
  6. #156
    Jul 2010
    South Florida
    86 ETA Sport 2.7i
    I have a 12ton press in my shop and have pressed hundreds of e30/36 ball joints over the past several years. It hasn't broken a sweat.
    Wide Open Throttle Technologies, FL
    -John
    Instagram
  7. #157
    Huntsville, AL
    E36 M3 vert | E39 M5
    For the record I just bought the HF 20T press for a hair over $160 just the other day with that 20% coupon. I think It's good till the end of the month.
    I literally just came in from pressing in the second set of bushings, the hardest thing for me was choosing how to arrange the arbor plates to press the new bearings in.
    I'd say the first side took about 30 minutes to press out and get the new ones in. The second took about 15 minutes to press out and in.
    And it just paid for itself.
    That's exactly how I explained it to my wife. :p
  8. #158
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I just found dimensions, thread, pitch etc on a German website, just for info:
    31121126254 outer ball joints
    Konussteigung/cone pitch: 1/10
    Konusmaß/cone size [mm]: 14,4
    Aussendurchmesser/outer diameter [mm]: 41,4
    Gewindemaß/thread size MM12x1.5R
    Höhe/height [mm]: 80
    31121126253 inner ball joints
    Aussengewinde/outer thread [mm]: M14 x 1,5
    Konussteigung/cone pitch: 1/5
    Konusmaß/cone size [mm]: 14,8
    Aussendurchmesser [mm]: 41,4
    Durchmesser/diameter [mm]: 14,8
    Höhe/height [mm]: 135
  9. #159
    Kirkland, WA
    2006 Toyota Tundra
    I’m having trouble finding a shop to press these bushings in. My local Indy BMW shop wanted $285 which almost makes it not worth it. What kinda shops did you guys find that would be willing to do this. Thanks.
  10. #160
    greenwood sc
    Quote Originally Posted by Alpine 318is View Post
    For that money I would get a Harbor freight press and do it yourself.
    I would think most any legit auto repair shop has a press.
    I have used these types of bushing tools many times with good results:
    https://www.ebay.com/itm/27PC-Univer...72.m2749.l2649
  11. #161
    Jan 2005
    Japan
    get a c-clamp ball joint press, might work , HF has that too, here someone used them for trailing arm bushings, based on that result I also bought such a solid c-clamp http://www.bimmerboard.com/forums/posts/507089
  12. #162
    Oct 2003
    Seattle
    99 M3
  13. #163
    Jun 2004
    SB / LA
    e36M3/4, e60 525, e39
    Picked up a 20ton press from Harbor Freight this weekend for $140 after a coupon. I am going to remove the arms and press out the old ball joints. What size socket is everyone using to press them out / press new ball joints in? Ive see 3/4 socket mentioned once on this thread.
    Did anyone cut the flange on the back of the existing ball joints to press them out from the bottom OR did you press the out from the top side (with the threaded part)?
    https://www.eeuroparts.com/blog/5319...n-ball-joints/
    [SIZE="1"]1997 M3/4/5 18x8.5 Hartge Classics, F1 Stage 2 Clutch Kit
    :one This Year :: Koni inserts, HR Sport, Rogue RSM, Ball Joints, Powerflex LCAB, Adjustable Sway Links (DIY), Headliner, MM Underpanel, 3 spoke wheel swap, BavSound Speakers, Bluetooth radio adapter
  14. #164
    Oct 2003
    Seattle
    99 M3
    Reading ALL of the related threads, the long shaft of the BJ is cut off and pressed out from upper side.
  15. #165
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Watch your feet and shins when they are about to come out. They can come out fast and hard.
  16. #166
    Phoenix, AZ
    97 M3
    I went and checked the socket, it was a 27mm deep impact socket from HF. Got a threaded coupling thing from Ace for a few bucks. You may need something stronger but Sprayed my ball joints with quite a bit of penetrating oil which did penetrate the rust from what I saw so the balljoint didn't explode out like crazy.
  17. #167
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    I'm going to attempt this soon...my 24mm deep impact sock seemed perfect too....i read 30mm in another thread, but the outside diameter is too big. I figure 24 - 27mm would all work since they all apply uniform pressure on the interior of the joint
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  18. #168
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by BMWManiac View Post
    Simply applying pressure to inner surface of BJ is not going to guarantee success. Need to be sure your applying outside column of the BJ.
  19. #169
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Don't forget to mark the orientation. BJs are directional (that sounds kind of funny).
  20. #170
    Feb 2002
    Orlando, FL
    Quote Originally Posted by bluptgm3 View Post
    I guess I'm not tracking....as long as the socket covers the metal part of the ball joint, then that sucker should have sufficient area to apply force....are you saying that the metal column will break in half?
  21. #171
    Oct 2003
    Seattle
    99 M3
    You can push the BJ shaft thru the BJ case if you are not applying force to the case side walls.
  22. #172
    Jun 2004
    SB / LA
    It was a major major pain in the ass to get the passenger side outer ball joint out of the knuckle. I am going to cut off the threaded shaft and then try press out - picked up 24mm, 27mm and 32mm deep sockets.
    I had to order some crowfoot wrenchs because that seems like the only way to torque the inner ball joint with that tiny area of clearance. Hopefully they work
  23. #173
    Jun 2004
    SB / LA
    What do you all recommend to put under ball joint on the arm to allow it to sit perpendicular to the arbor press?
    Marked the ball joint locations with a metal punch on the backside
  24. #174
    Jan 2019
    MI
    1997 BMW M3 Sedan
    Not to deter anyone from getting their hands dirty, but what is the advantage of replacing the ball joints when I can (and just did) order a pair of new arms for less than $120?
  25. #175
    Jan 2005
    Japan
    A pair for $120 or less, original? Show us...
    for example for my 02/98 p/n is 31122228461 left side, 31122228462 right side.
    One MTC Control Arm 31122228461 per piece discounted online price $150/piece x 2 = $300
