Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: VMWare with DIS/SSS
  1. #26
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Sorry, I assumed that INPA/EDIABAS was already working.
  2. #27
    Feb 2012
    London
    2003 BMW E66 735Li
    Question Problem configuring VMWare network settings for DIS v57
    Hi - I am partway through setting up DIS v57 & SSS v32 on a Dell / Windows XP Pro laptop with the usual China made Ediabas interface cable with serial connector. I have the Ediabas and INPA installed and have tested it connected to my 2003 E66 735Li and it all works great (even though the INPA interface shows battery and ignition off), I can communicate with all ECUs and control modules.
    I am now trying to get the setup to work with the VMWare DIS v57 & SSS v32 Progman installation. Diaghead Emulatohas been installed and setup too.
    I am having trouble configuring the VMWare network settings.
    Following the instructions that came with the software I have done the following in the Virtual Network Editor:-
    Set automatic bridge to VMnet0
    Enabled VMNet1 (Local Area Connection 2)
    VMnet2 thru VMnet9 are disabled and not bridged
    On VMnet1 the Subnet IP Address is set to 192.168.68.0
    and the Subnet Mask to 255.255.255.0
    The DHCP settings are given as follows:- Start IP Address 192.168.68.1
    End IP Address 192.168.68.254
    When I try to apply these settings I get the message 'Error - the end IP address must be greater than the subnet IP address'
    Any ideas?
  3. #28
    Nov 2010
    NE UK
    E28 M5 #31
    Yes,
    once you change the subnet on vmnet1 to 192.168.68.0 you must then apply the changes before editing dhcp settings.
  4. #29
    Nov 2010
    NE UK
    E28 M5 #31
    gtemco,
    did it work?
  5. #30
    London
    X5
    SSS vwmare with GT1
    Hi to all, please I want to use coding with my GT1 on SSV30 on vmware can someone tell me what configuration to make my virtual machine, I have an image 57 virtual DIS is working well, Thank you advance
    Best regards
  6. #31
    Jun 2006
    nyc
    BMW 6spd 550i w Sport Pk
    Quote Originally Posted by jimmy1022 View Post
    Yes,
    I edited my vm settings and was able to change them running vm as admin...I still get net error 0009 timeout. Do I have to go back to edit adapters inside of dis as per davids instructions?
