Page 4 of 9 FirstFirst 123456789 LastLast
Results 76 to 100 of 210
Thread: The files to an EasyDIS\GT1 machine!
  1. #76
    Portland, Oregon
    2009 BMW 750i
    Hay Maikelk can you help me with a 2010 BMW 750i pleas.
  2. #77
    Dec 2009
    Portland, OR
    2004 X3
    ERD Commander part4
    This is a great collection! The carsoft 6.5 win 7 reports that the installation is not complete. As well can you repost the ERD commander part 4, seems to be corrupt.
    Also, does anyone know how to get the different chassis options to show in INPA? It shows ignition and battery on but no chassis options below.
    Thanks again! Looking forward to updates...
  3. #78
    Jun 2010
    United Kingdom
    E87 120d M-Sport
    Quote Originally Posted by rlansing View Post
    Check your INPA config' settings file in C:\EC-APPS\INPA\CFGDAT - sounds like it's empty. Should look similar to this:
    Code:
    //* Nacharbeitsauswahl INPA
    //* Datei INPA.INI
    //* Weber EA-803
    [INFO]
    VERSION               = 5.04
    DATUM                 = 27.04.2010
    VARIANTE              = DEUTSCH
    [ENVIRON]
    DRUCKER               = WIN
    PEM                   = JA
    LANGUAGE              = ENGLISCH
    [SCRIPT]
    EDITOR                = WIN
    SCRIPTSELECT          = LIST
    DEFINI                =
    [CONFIG]
    TITEL                 = BMW - INPA EA-90X
    F2                    = F01
    F2_Text               = F01
    F2_ARCHIV             = SGBD_F01
    F3                    = Engine
    F3_Text               = Engine
    F3_ARCHIV             = motor
    F4                    = E60
    F4_Text               = E60/E63/E64
    F4_ARCHIV             = SGBD_E60
    F5                    = E65
    F5_Text               = E65/E66/E67
    F5_ARCHIV             = SGBD_E65
    F6                    = E70
    F6_Text               = E70/E71/E72
    F6_ARCHIV             = SGBD_E70
    F7                    = E83
    F7_Text               = E83
    F7_ARCHIV             = SGBD_E83
    F8                    = E85
    F8_Text               = E85/E86/E89
    F8_ARCHIV             = SGBD_E85
    F9                    = Sonder
    F9_KNOPF              = Especial
    F9_TEXT               = Special Tests
    F12                   = R50
    F12_Text              = R50/R52/R53
    F12_ARCHIV            = SGBD_R50
    F13                   = R56
    F13_Text              = R56/R55/R57
    F13_ARCHIV            = SGBD_R56
    F14                   = K40
    F14_Text              = K40
    F14_ARCHIV            = SGBD_K40
    F15                   = E46
    F15_Text              = E46
    F15_ARCHIV            = SGBD_E46
    F16                   = E53
    F16_Text              = E53
    F16_ARCHIV            = SGBD_E53
    F17                   = E87
    F17_Text              = E81/E82/E87/E88
    F17_ARCHIV            = SGBD_E87
    F18                   = E90
    F18_Text              = E90/E91/E92/E93
    F18_ARCHIV            = SGBD_E90
    F19                   = BMW_ALT
    F19_KNOPF             = Old
    F19_TEXT              = Old Models
    F19_ARCHIV            = SGBD_BMW
    [EXTRA]
    SCRIPTS               = *
  4. #79
    Mar 2011
    roma
    x3 2L 177hp diesel
  5. #80
    Feb 2010
    san antonio, tx
    2001 bmw 325ci
    when i try to get the gt base running it says disk partitioning failed
    , any ideas?
  6. #81
    USA
    (OO=[][]=OO)
    Hey, so I've been wanting to get this software working for a while, and someone wanted a torrent, so why not.
    http://thepiratebay.org/torrent/6308103
    I have some seeding sources going on, anyone else can help?
  7. #82
    Feb 2010
    san antonio, tx
    2001 bmw 325ci
    ^ thanks for that man, im going to dl that and see if i can get the gt base to work again.
  8. #83
    Sep 2009
    Czech Republic
    E46 BMW 320D
    can somebody reupload it to the rapidshare or megaupload please... ? Thank you
    //edit:
    well, i have payed that 9 usd :-) , if anyone would like to post it on rapidshare - let me know
    one question:
    - what cabel should i get to let all this diagnostic work on bmw 325d e92 2008 or 2007? Thx
    - will be this fine:
    http://cgi.ebay.com/ebaymotors/NEW-B...motiveQ5fTools
    or i need HEX?
  9. #84
    Jul 2010
    Ontario, Canada
    2003 BMW 530i
    Quote Originally Posted by Gene Poole View Post
    It took me about 4 or 5 tries with each disk to get it to finally install. I just selected "Use iso image" in vmware CDROM settings.
    One thing I noticed and mentioned a few times before is that mucking with the registry to get a normal shell, as referenced in various guides, results (on my machine anyway) in two instances of whatever shell is set being run. You can see this if you grab the title bar of the "Installing" dialog and drag it to the side. There's another one under it.
    I tried it instead by mounting the VMWARE disk image as described, but instead of mucking with the registry, I copied c:\windows\explorer.exe to the directory where the shell is (c:\windows\system32\ifs\install\ ) and renaming instprg.exe to something else, then renaming explorer.exe to instprg.exe. This has the same basic effect in that explorer.exe is run and all the changes can be made, then just rename them back while still running as admin, then when you reboot, it's back to the way it was. This prevents the second instance of whatever shell value is set (I've researched this registry "bug" but I came up with nothing).
    I don't have any proof, but I think this may be the reason for some of the problems during installation as I believe that two separate installations are going on at the same time and overwriting each other.
    This looks like a clever idea. I'd like to try it.
    You mention copying c:\windows\explorer.exe to c:\windows\system32\ifs\install\
    But don't you mean Z rather than C? Z becoming C in the virtual machine after the changes when you restart the VM. Or am I out to lunch?
    But ---- I need some help. I am being denied access to Z/windows/system32/config directory & also to Z\windows\system32\ifs\install directory
    I'm trying to access the mapped Z from the host Vista machine; I assume this is correct?
    I'm signed on as admistrator, but get pops up on the copy or file name change for "need confirmation", then "user account control OK". I then get a "red X" box and action cancelled.
    I can change & copy in many other directories on Z; just not the only ones I need to #$%^&*.
    I've tried changing permissions (groping my way - new to me) but without any luck. FWIW, these directories show full permission for administrators
    Running Vista Business. Already have VM's for EasyDIS v44 & EasyDIS upgraded to v57 working on car. But I simply followed instructions, & didn't need to mess with this shell change procedure.
    To be clear, I'm at point the the base install that it wants the progman disc but instructions say "DO NOT PUT IN THE PROGMAN DISC!!"
    Any suggestions would be appreciated.
    Regards
    RDL
  10. #85
    Jul 2010
    Ontario, Canada
    2003 BMW 530i
    I found a solution.
    I used ERDcommander2008 to get access to the VM registry and changed the shell to explorer.exe as described in "How to install SSS Progman on Windows 7 64bit.pdf" Although it says 64 bit, it worked on my Vista Business. I could then open the VM with access to files, directories and registry. Files available here:
    http://www.4shared.com/dir/LfFoCBq2/...s_Machine.html
    password is bimmerforums
    Once at the explorer.exe shell, I could find progman.exe inside the VM, made a shortcut and copy it to My Computer inside the VM. I modified the shortcut command line to
    D:\\Programme\IFS\Shell\Progman.exe 80 /cipb/ProgmanAdmin/start.php?mode=init
    which is the normal shell command for a Progman system installation.
    Still Progman would not run properly. The issue turned out to be screen resolutions. Between resolutions picked by VMware and screen resolutions in XP inside the VM I had no end of trouble. But, with explorer.exe as the VM shell I could go to Control Panel and fix the problem.
    I now have a working Progman, run from a shortcut identical the the shell command in the intallation packages. And the converience of access to the underlying file system, registry etc.
    BTW, I'm running this on Vista Business with VM Player, not VMware 6, 7 etc.
    An added bonus: I can copy files from Vista to the VM XP. I don't need to bother with mapping or shared folders.
    Regards
    RDL
  11. #86
    nyc
    2007 e92 335i
    Do you want me to upload Daten v41 files in therE?
  12. #87
    nyc
    2007 e92 335i
    By the way, ProgmanV32 disc 2.part09.rar and ProgmanV32 disc 2.part14.rar are no good
  13. #88
    Dallas
    2005 Z4 3.0s sport
    Quote Originally Posted by MaikelK View Post
    Hello all!
    I took the liberty of creating an 4shared site with al the files that i used for an EasyDis\GT1 machine.
    These files are all the files pointed to in Randomy's and David Mc's how to's that i followed to created a running EasyDis\GT1 machine.
    I combined a few how to's from this website into some PDF's that is inside every folder corosponding the software.
    http://www.4shared.com/dir/LfFoCBq2/...s_Machine.html now password protected. This is "bimmerforums"
    I hope this will help some people who are in struggle to find the files or right how to's!
    Please reply if files or how-to are not working or not clear enough. I would like the feedback to get every thing proper!
    Screenshot of the servercontent:
    Well all went well but disk 2 of SSS files 9 and 14 are corupted and will not download...Could you please re uploaded them thanks [ Note I got the files from the posted torrent....all is well now.....]
  14. #89
    nyc
    2007 e92 335i
    Quote Originally Posted by tlrominger View Post
    Can you reupload them somewhere? I need those 2 myself
    Thanks!
  15. #90
    Dec 2007
    Vancouver
    X5, XJR
    Hey Maikel, I wanted to say thank you! I downloaded everything fine EXCEPT for 2 files for disc 2 off sss v32.
    Can you please send me part 9 and part 14 of disk two or fix them on the 4share website, they are not working, when you click and try to download them they say the link is no longer valid.
    I would appreciate the help!
    Thanks again Maikel!
  16. #91
    Feb 2010
    UK
    E39,E53
    Quote Originally Posted by swissfrank View Post
    +1 for part 14 please
  17. #92
    IL
    2000 740i sport
    seems that disc 2 for sssv32 is missing files i only see part 45. can you update these??? how do i download off the torrent? never used torrents before...
    update:
    got it to download. but im trying to install inpa but theres no install program just a .nrg file of some sort what is this? what do i do?
  18. #93
    USA
    (OO=[][]=OO)
    .nrg is a Nero disk image. Might need to use Nero Burning ROM software to burn it to a CD.
  19. #94
    USA
    (OO=[][]=OO)
    Also, are any of you having problems with the files in the torrent. I haven't had a chance to try it out.
  20. #95
    The Netherlands
    E46 320i, E30 325e
    Hello,
    After a while i now looked into the folders an the 4shared site and found dat after reuploading all the files, only part 45 got on, now at the moment i'm reuploading those files again!
    Hope this helpes!!!!
  21. #96
    Atlanta
    2002 325I
    MaikelK,
    Thanks for uploading the files again but it looks like it is missing the last part. Getting this error: Cannot find volume ProgmanV32 disc 2.part36.rar.
  22. #97
    Palmyra, PA
    05 330cic ZHP,2000 323iT
    Quote Originally Posted by 2002e46 View Post
    MaikelK,
    +1
    2005 330ci ZHP 6 spd manual Vert
    2000 5 spd manual 323iT
    Past rides:
    1994 325is M-Technic (sold, but not forgotten)
    1989 325i (you never forget your first)
    Please see my parts and accessories (non-commercial) for sale here: http://home.comcast.net/~bmwmtech/Parts/
  23. #98
    Aug 2011
    Oakland, CA
    2000 323CI
    Anyone manage to install EASY DIS in english because everytime i install it, it turns out to be some other language, Btw - Progman Disc 2 part 36 is missing
  24. #99
    Dec 2009
    Norway
    BMW 740I e38
    Downloaded the files from the server which also contained a guide "How to install INPA 5.02 and EDIABAS 6.4.7". The images contained in the PDF is from another program and is not similar to the one which it is supplied with.
    I also get a empty screen with no scripts, I tried editing them in. But it didn't work, it just couldn't find the files for the scripts added. Someone should upload a working piece, I've been going through 5-6 different installls now and all of them are different and doesn't work in one or another way. It's driving me nuts.
    I think I'm going to install all of them again one by one and copy their files into seperate folders and compare what files comes where, and what actually works.
    Quote Originally Posted by FAL View Post
    Code:
    //* Datei INPA.INI
    //* Weber EA-803
    [INFO]
    VERSION               = 5.04
    DATUM                 = 27.04.2010
    VARIANTE              = DEUTSCH
    [ENVIRON]
    DRUCKER               = WIN
    PEM                   = JA
    LANGUAGE              = ENGLISCH
    [SCRIPT]
    EDITOR                = WIN
    SCRIPTSELECT          = LIST
    DEFINI                =
    [CONFIG]
    F2                    = F01
    F2_Text               = F01
    F3                    = Engine
    F3_Text               = Engine
    F3_ARCHIV             = motor
    F4                    = E60
    F5                    = E65
    F6                    = E70
    F7                    = E83
    F7_Text               = E83
    F8                    = E85
    F9                    = Sonder
    F9_KNOPF              = Especial
    F12                   = R50
    F13                   = R56
    F14                   = K40
    F14_Text              = K40
    F15                   = E46
    F15_Text              = E46
    F16                   = E53
    F16_Text              = E53
    F17                   = E87
    F18                   = E90
    F19                   = BMW_ALT
    F19_KNOPF             = Old
    [EXTRA]
    SCRIPTS               = *
  25. #100
    Aug 2011
    Oakland, CA
    2000 323CI
    Quote Originally Posted by MrEmo
    That happens to me also only 6.4.3 works, for me atleast
