The Ediabas 6.4.3 and INPA 4.4.7 files will not download from the zip folder. Has anyone else had this issue?
________________________________
Nik
91' M5 3.9L Stroker
92' M5 3.8L
95' 540i6 Supercharged
95' 540i6 4.7 Stroker
95' 550i6 M70 Conversion
I'm having it too, i got through part 3 but i can't get any of the other files
Im now still in China, when im home i will check!
Edit:
I forgot, i already downloaded the files, just extracted them and no problems what so ever!
Please try again!
|For all your EasyDis and GT1 Carsoft and INPA software click here, now also for Windows 7 64bit!|
maybe its because i'm not a paid member? I've tried 5 different browsers, cleared cookies/cache, cleaned registry....i'm not sure what to try
After a long time, im back and now uploading the Disc 2 of Progman and the SSS-Base 3.1 and hack!
Screenshots of servercontents
Sticky please?
ZetaTre
2003 BMW Z4 2.5i
2009 BMW X5 xDrive35d
2006 Ducati 999S
2012 Ram 2500 Laramie Longhorn 6.7 Cummins
Part 22 of Progman disc 2 is corrupt. Can you re-upload?
Yeah i noticed yesterday before i went to bed that the files didnt upload, server is full.. 10 gb of stuff uploaded already...
Now i already removed the Carsoft for XP. So need to have another look.
Will reload part 22 of Progman Disc 2
Thanks man!!!! Will look forward for updates so I can give this a try...
ZetaTre
2003 BMW Z4 2.5i
2006 Ducati 999S
Everything should now be complete! Please test and report!
Sticky maybe? Any mods reading this? If stickeyed, please change title to All software for DIS\GT1, INPA, Carsoft and SSS-Progman (also Windows 7 64bit)
Trying it as we speek... I was able to successfully recombine disk #1 and the EDR Commander (which I suspect I don't need) last night. Should be done with the other files in an hr or so. I'll let you know...
Everything worked great!!! I've got SSS up and running...
ZetaTre
2003 BMW Z4 2.5i
2006 Ducati 999S
Thanks for testing! Now everything is up and the server is full, if i had more space i also would have uploaded TIS 2007 and if i could download it version V57 of DIS and so on!
Just a quick feedback: the ERD Commander is not in English...
ZetaTre
2003 BMW Z4 2.5i
2006 Ducati 999S
whats the pasword?
I'm confused by the "now also for Windows 7 64bit" part. I downloaded the PDF, but I didn't see anything about NCS, which is the only one that was a problem in the first place. Is it something that the .reg file changes?
I don't know why ERD Commander is required in th e"official" procedure to install SSS: I didn't use it for that.
I was actually trying to use it to fix the resolution that was incorrect and Progman was not starting. Also I've updated VMware and couldn't install the new VM tools.
However since Windows XP/Progman runs on a virtual machine, there's a easier way to do it than using ERD Commander.
Just mount the hard drive and enter the Registry just like it is mentioned in the procedure. Copy and paste the vale for Shell under Winlogon and replace it with explorer.exe. This way when you fire up the VM Progman doesn't auto start and you can access the Control Panel and do whatever tweak you like.
Once you're done remount the HD, readit the Registry and paste back in Shell what was originally there.
That is unless ERD Commander has some other reason to be part of the package... I see it necessary if you run Progman on a physical machine, but on a virtual machine I don't see the need... Just my 2cents
ZetaTre
2003 BMW Z4 2.5i
2006 Ducati 999S
You're not able to load the registry hive like the original tutorial says in Windows 7, that's why we need to use the ERDCommander.
Yes you are: I have Windows 7 and that's how I've done it.
ZetaTre
2003 BMW Z4 2.5i
2006 Ducati 999S
mmmm, i tried a few things, can you write an simple how to with pics? Im intrested.
Well, the only thing I had to do was to select HKEY_LOCAL_MACHINE: basically collapse all the key until HKEY_LOCAL_MACHINE. Once you're there the "Load hive" command under File will become available. If you select any other key it will be greyed out.
Whenever I need to make any change to the virtual machine I:
1) Go in the virtual machine and mount the drive as described in the procedure
2) Load the hive as described making sure that HKEY_LOCAL_MACHINE is selected
3) Go to the Shell in Winlogon
4) Take the original string and copy & paste it in a notepad
5) Replace the string with explorer.exe
6) Collapse everything until I'm back at BASE31
7) Select File -> Unload hive
8) Close Regedit and all Folders that are open (this is necessary to unmount the drive in the VM)
9) Unmount the drive
10) Load the machine and do whatever change (e.g. update the VM tools or whatnot) then once I'm done I turn it off.
11) Repeat steps 1 though 9 to restore Winlogon -> Shell to the original string
ZetaTre
2003 BMW Z4 2.5i
2006 Ducati 999S
Will have a try some time, now headaches about my Bimmer..... Rearbrakes are jammed...
Thanks MaikelK for taking the time to upload those files.
I have a little problem though. I downloaded some files, and then I got this message:
Server downloading session limit is reached. Please try again in a few minutes
Assuming I reached a daily maximum, I tried the day after, but same thing. Today I try at work on a different computer (thinking they were recording my ip address), and the same message appears.
So I don't know if it's me or the 4shared site. Any idea??
Thanks.
Edit: I just tried another directory, and I'm able to download files. I will try again the other one later and if it works, I'll report back.
Edit2:: It's the file itself that causes the error. I don't know why. This is the file:
http://www.4shared.com/document/5rIw...or_DIS_Pr.html
All the others I downloaded were ok (Inpa 5.02 + EasyDIS) ;-)
Can not get progman to install, Tried with daemon tools and burned it on dvd's.
