Results 1 to 9 of 9
Thread: Gear oil bottle, plastic cap fell in diff, help please.
    Sep 2010
    Louisville, Ky
    2000 540i
    This is my first post and it's pretty sad to say the least. The attack of the 7yr stupid happened today to me. I have a lot of experience working on cars, I am kicking myself pretty hard over this so no flaming please... Replaced the fuel filter today on my 2000 540i, which I purchased about a month ago, and after no hitches I thought while I have it jacked up I'll change the diff fluid. I was checking with the new bottle to see if I needed a hose to fill it with and the cone shaped plastic cap came off and fell in the fill hole. I tried flushing it out with a quart of fluid, I put the hose of my shop vac up to the drain hole and partially restricted the fill hole to try to get enough velocity to suck it out. I taped a piece of gas line inside the shop vac hose & fished it around trying to pick it up. I fished around with a piece of wire bent in a hook on the end trying to drag it over to the drain hole. Nothing worked, I was not able to get the cap in a position where I could feel or see it so I need some help.
    I did some searching on here and it looks like it might be possible to remove the driveshaft flange and the diff mounting bolts and scoot it forward a few inches to remove the cover. I don't have the manual for the car so some info on the simplest procedure anyone knows to replace a cover gasket that would allow me to get the cover open enough to get this out would be greatly appreciated. Thanks in advance, sorry for the long post.
    Amsterdam, NY
    97 528i 87 528e 65/74MG
    As bizarre as this sounds it may be fine to just leave it in there. The old school method of changing diff fluid before they thought to include filler plugs was to fill a plastic bag with the correct amount of fluid and then set it in the diff and install the cover. The plastic was not an issue as it would get chewed up by the gears almost immediately its not hard enough to damage the gears and there is enough lash in the gears that it will not damage them or lock them up. You might try simply driving the car for a few miles and then drain the fluid, if you see bits of plastic then repeat till no more plastic, otherwise, try drain and refill cycles until it shows up at the drain.
    >'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
    HOT! HOT! ARIZONA!!!
    98 528i 00 ML430
    Is it possible to open the diff?
    98 528i 00 ML430
    May 2009
    Austin
    E39, E46M
    Yes, and if the diff takes a crap in the future, M5 diff time.
    May 2009
    Austin
    E39, E46M
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    It may have hung in/on the carrier. Try putting the trans in neutral and turning both rear wheels backwards evenly one quarter turn. A little compress air, maybe. If all fails, go with NNY528i; grind it up good and call the diff teflon fortified.
    /.randy
    Sep 2010
    Louisville, Ky
    2000 540i
    Thanks for the replies.
    Dec 2007
    South Florida
    645i; X5 4.8i; 525iT 5sp
    I think it will be fine.
    I love to flap my paddle..
