Hey guys,I have a 2003 540i, my coolant temperture light came on. any ideas? I noticed that my coolant fan did sound a little odd also. I checked for any coolant leaks and there were none. My coolant level is fine because I checked it. I cant figure this one out.....It only happened when I was parked, if anyone know what it could be let me know.
I was told it could be my Coolant fan but I need a second opinion.
Thanks guys,
Richardsoner
What did your coolant temperature light look like?
There is a Coolant Temperature and Check Coolant Level Warning. It's not a light, the words show on the display. The coolant level /temperature sensor sensor sticks up from the bottom of the coolant overflow tank. I'd consider replacing it, although your coolant temperature gauge should also be pegging.
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
Is your radiator fan spinning at idle? Fan clutch could be toast if not.
yes it is spinning idle, it is not as loud as is use to be. i am in Jacksonville NC, near Camp Lejeune on business. is there any well respected BMW shop around here that anyone knows of. I only have a week here so I have take care of this ASAP.
Thanks again
Richardsoner
There was a Coolant Temperature and Check Coolant Level Warning. my mistake. what appeared was a warning. the fan is running kind of crazy, i checked it this morning. how far can i drive to get it fix if I got to drive it to the shop
Last edited by Richardsoner; 09-26-2010 at 10:33 AM. Reason: Automerged Doublepost
Two other things:
You might need:
New Bleeder screw
or
New Expansion tank cap
Both of these should be checked.
best,
Jeff
