Page 4 of 8 FirstFirst 12345678 LastLast
Results 76 to 100 of 183
Thread: ORings - The consolidated thread
  1. #76
    Apr 2002
    Shelby Twp, MI
    TurboVert, MCoupe, 335xi
    Quote Originally Posted by bigugly View Post
    what sorta problems?
    I've seen the wire push over in the groove because the cylinder head is softer than the block. This was on a 418 cubic inch LS motor with a 250 shot of nitrous...so it's not really a fair comparison to the BMW. It was diagnosed as the head lifting just enough to put the force on the wire...which push over the ledge on the groove. The damage was repaired by welding in a harder aluminum and re-machining everything back to the way it was before. So far...no issues after lots of 9 second passes in a 4,000 lb vehicle!
  2. #77
    houston
    m3
    that doesnt make sense. how far was the wire pressed into the head? was it sitting on the headgasket, or not covered up? hey - at least you got it solved, but still doesnt make sense why it would do that.
    This space for rent.
  3. #78
    Apr 2002
    Shelby Twp, MI
    The o-ring was stuck to the gasket as well and when the combustion was trying to push past the o-ring, it pushed it over in the groove. The aluminum of the cylinder head is softer than the cast iron block or cylinder liner.
    When the head lifts, o-rings fail in the block too...just not in the same manner. I was just giving an example of what I've seen personally. The engine builder that had the o-ring failure on his cylinder head was making at least 1,000 hp when it happened.
    biglou911 probably has completely different stories.
  4. #79
    houston
    m3
    how deep and what size wire?
  5. #80
    Apr 2002
    Shelby Twp, MI
    Not sure off hand, but I'll ask tomorrow since I'm probably headed there in the evening.
  6. #81
    Feb 2008
    DETROIT
    E36 GOODNESSSS
    That would have to be really deep and really thick wire.
    Sent from my iPhone using BF.com
    i got these parts for sale
    front corner light for a 4 door E36 $20plus shipping
    headlight eyebrows $20 plud shpping
    M3 OEM radiator $100 plus shipping
    M52 cams with trays high miles $150 shipped
    M3 front calipers $150 plus shipping
    18x8 offsed 35, front 18x10 offset 40 rear bsa motorsports wheels $400 plus shipping
    obd2 valve covers $50 plus shipping
    intake manifolds $50 plus shipping
    estoril blue doors of a 96 M3 2door $200 plus shipping each
    rear glass $50 plus shipping
    rear trunk lid $150 plus shipping
    new 1/4 is 800 ft away ))
  7. #82
    houston
    m3
    FYI- the BMW OEM gasket is an elring, and is available seperately.
  8. #83
    Oct 2008
    Albuquerque
    a m3 on a 7675
    80 $ and free shipping from pelican ftw
  9. #84
    houston
    m3
    yup- cheaper than CCA cost at the dealership (130 bucks )
  10. #85
    Dec 2008
    Earth
    none
    got the link handy? I'm going to need to slap a new one in!
  11. #86
    Oct 2008
    Albuquerque
    a m3 on a 7675
  12. #87
    Pearl
    97' 3.__?
    This is the one I've been talking about. 87mm bore for the m. No 85 for the non m.
    In soviet Russia, car forks you!
  13. #88
    So'cal
    Turbo s52 e34 touring
    Are the Elring stock style gaskets bore opening perfectly round like the cometic 87mm gaskets? I have hear that they are somewhat oval and are not the best for using with o'rings.
    Supercharged 332is - sold
    Gt35r Turbo E36 M3 - sold
    Supercharged e46 M3 - sold
    Built s52, 6466 Turbo E34 Touring
  14. #89
    houston
    m3
    welp- i just set my elring gasket on top of my head, and it looks good to go if you ask me
  15. #90
    Pearl
    97' 3.__?
    Nice. Now get it back together and put some boost and miles on it.
  16. #91
    houston
    m3
    im trying!! lol
  17. #92
    Pearl
    97' 3.__?
    I'm in the process of rebuilding an m20 motor for someone out here in Hawaii. We are going to do an experiment. For the sake of longevity, we are going to run a groove in the block with stainless wire with .010 hanging out. I've been researching a while with no real answer to how long copper will hold up. It seems like most people running copper are either running drag cars or getting 5-6k street before something hg related let's go. So, I'm just getting the block torn down tonight and I'll get the cylinders prepped tomorrow. Head is at the machine shop right now. I'll snap some pictures when I get to those steps.
  18. #93
    So'cal
    "Bigugly". What size bore are you running s52 0.20 over ?
  19. #94
    houston
    m3
    standard bore S52. i took a S50 block and bored it to S52 specs.
  20. #95
    Australia
    1994 M3
    2.7 M20 turbo, .041 copper, .030 groove
    cheers, Alan
    1/4 mile-12.92 @ 108.64mph-NA 3.0L m3 daily driver
  21. #96
    Pearl
    97' 3.__?
    Quote Originally Posted by morerevsm3
    Looks exactly like the 2.5 m20 I just did. Looks good.
  22. #97
    houston
    m3
    Quote Originally Posted by tciambotti1 View Post
    oh yea- update.
    its neat works great!
  23. #98
    Luxembourg
    1995 M3 GTtt
    Anyone selling their O-ringing tool?
    1995 E36 M3 GT #111
    3.0L S50B32 EURO Single Vanos with ITB's and Twin Garret GT2252 Turbo
    VEMS Standalone (www.vems.hu) most features enabled.
    Brakes, suspention, rollcage, seats, harness, wheels and tires.
  24. #99
    mach 2 with my hair on fi
    many
    Yes isky racing camshafts makes and sells them.
    1991 bmw 325I <e30>
    First 8 second full body BMW with BMW independent rear suspension in the USA
    8.69 @160mph in a 1/4mile on slicks.
    drag radial tires record holder9.53@148. Also a world record holder for bmw overall 60-130mph 4.2 seconds.
    Bistein sport susp,turner sway bars,3:25lsd,m52 AEM INFINITY stand alone. MORAN 2500cc injectors E85 ,front mount 33x12x4 intercooler, 5lug conversion M3 front,Mcoupe rear Dss axles/driveshaft ATI Proglide.
    2003 Ford Expedition
    1998 M3
    1986 Mercedes Cosworth 190e 2.3 16v 5speed (sold)
  25. #100
    Luxembourg
    1995 M3 GTtt
    Quote Originally Posted by djborya View Post
    Pretty expensive, I was fishing for a used one. There is on ebay but its for the bigger bore motors.
    1995 E36 M3 GT #111
