1991 bmw 325I <e30>
First 8 second full body BMW with BMW independent rear suspension in the USA
8.69 @160mph in a 1/4mile on slicks.
drag radial tires record holder9.53@148. Also a world record holder for bmw overall 60-130mph 4.2 seconds.
Bistein sport susp,turner sway bars,3:25lsd,m52 AEM INFINITY stand alone. MORAN 2500cc injectors E85 ,front mount 33x12x4 intercooler, 5lug conversion M3 front,Mcoupe rear Dss axles/driveshaft ATI Proglide.
2003 Ford Expedition
1998 M3
1986 Mercedes Cosworth 190e 2.3 16v 5speed (sold)
gotta get the head off first.......
gotta get one of those fancy elring headgaskets as well, to make this work
i was gonna make some .030 rings, cut .020 grooves, and leave .010 out of the head to clamp... my problem was the headgasket to stick them on. i was looking at a pure copper gasket, or like a SCE titan gasket, but their website doesnt show one for an S52...... but have seen posts of people claiming SCE does make them. i guess ill have to call them.
anyone running the SCE titan S52 built-in wire gaskets??
This space for rent.
1991 bmw 325I <e30>
1998 M3
We recently had SCE Gaskets redesign their Titan and ICS Titan head gaskets for the E36 motors. They feature a one piece copper design with silicone seals around the coolant and oil passages. The ICS titan gasket has integral stainless o-rings that are sandwiched in the fire ring of the gaskets. Pictures and more info on the ICS Titan design can be found here: http://www.scegasketsonline.com/products/ics.html
Currently the ICS Titan gaskets are only available in 85mm for the M50 and M52 bores. We have Titan gaskets in 87mm for S50 and S52 motors. There isn't enough material between the bores for the ICS titan gaskets in 87mm. You can use stainless o-rings in the block with the S50/S52 in conjunction with these gaskets.
Pricing is $250 for the .080" ICS and $230 for the .080" Titan
Pictures can be found on our photobucket page: http://s291.photobucket.com/albums/l...SCE%20gaskets/
Gaskets can also be custom ordered in thicknesses from .040" to .093" with the ICS design and the regular Titan gaskets are available in a slightly larger range of thicknesses. Pricing varies with thickness and quantity.
Donovan and I have the 85mm ICS titan gaskets in our cars. I have a few thousand miles on mine with lots of 600+whp pulls and 800+ dyno runs so far. Donovan made a bunch of 10 second passes and 700+whp dyno pulls. Donovan also o-ringed his block with backup rings. We have seen no issues with coolant system pressurization so far. We haven't tested the 87mm ones yet. I will give a significant "test pilot" discount to the first person to field test one with the new 10mm ARP studs. Email us at sales@maximumpsi.com if you are interested.
Thanks,
Mike
1991 bmw 325I <e30>
1998 M3
:doh: :kicksdirt: sorry- just read over that.
well, i wonder if the all-copper gasket would like to dance with those stainless rings?
and lots of talk about just using a stock headgasket with orings/rings as well
man, of all the engines i have built, the stock BMW headgasket sure is the nicest thing i have found when it comes to sealing. (besides boosting- you know what i mean )
I use stock head gaskets.For me they work well even at 40+psi of boost.no problem with stock gaskets and boost here.
B.
1991 bmw 325I <e30>
1998 M3
*just* stock head gaskets? no modding or rings/wire/magic?
im tickling 30, and dont wanna have to A) dump money into this headgasket issue again B) want to solve it CORRECTLY and ONCE C) yank the head again lol
this has been gone over a bunch of times by me and others.search and read threads. start from the beginning. This here below is from the beginning of this thread. I am djborya (9th on the list)
and i use .041 copper .012 thou protrusion.stock gaskets.
Who's doing what:
BMWSOB: Stainless wire w/ Titan gasket. Figure 8 style.
Mike R: Copper wire, grooves in head , no receiver groove in block, [COLOR=blue !important][COLOR=blue !important]stock[/COLOR][/COLOR] gasket
m3_madbimmer: .030" Copper (.022" groove depth), block only
Sniz: .041 Copper, groove depth of .033 (.008 above deck), .140 MLS gasket
thespeedfactory: stainless .041
jfdmas: ? receiver groove, copper headgasket, stainless wire
highboostingm3: (M52) copper wire, block only w/ MLS
highboostingm3: M50NV (old setup), dual offset o'ring w/ MLS
djborya: .041 copper
MrBlonde: block and head, unknown specs
DC47A - ? , s52 w/ 'non-figure 8'
M3Jasper: copper wire, head only
bim553er: s52, figure8
GT35Rm3: block, steel rings, stock head gasket
multiplex: block, copper rings, stock headgasket
DIY Threads:
http://www.e30tech.com/forum/showthr...ht=isky&page=7
Sniz: http://forums.bimmerforums.com/forum...ht=isky&page=6
after: http://forums.bimmerforums.com/forum....php?t=1444191
multiplex: http://forums.bimmerforums.com/forum...t=oring&page=2
e30tech: http://www.e30tech.com/forum/showthr...highlight=isky
Suburu poo: http://forums.nasioc.com/forums/show....php?t=1812470
HotRod Magazine: http://www.hotrod.com/techarticles/e...ild/index.html
http://www.enginebuildermag.com/Arti...er_blocks.aspx
http://www.popularhotrodding.com/eng...ing/index.html
SCE instructions: http://i49.photobucket.com/albums/f2...truc-oring.gif
1991 bmw 325I <e30>
1998 M3
Great work gentlemen.
So what is the thought on which stock gasket to use? victor or elring?
In soviet Russia, car forks you!
Where can these be had without buying the whole top end kit? Not having any luck.Originally Posted by GG///M3
Look at auto parts warehouse . I have different store were I'm buying my stuff but the don't do shipping
i got these parts for sale
front corner light for a 4 door E36 $20plus shipping
headlight eyebrows $20 plud shpping
M3 OEM radiator $100 plus shipping
M52 cams with trays high miles $150 shipped
M3 front calipers $150 plus shipping
18x8 offsed 35, front 18x10 offset 40 rear bsa motorsports wheels $400 plus shipping
obd2 valve covers $50 plus shipping
intake manifolds $50 plus shipping
estoril blue doors of a 96 M3 2door $200 plus shipping each
rear glass $50 plus shipping
rear trunk lid $150 plus shipping
new 1/4 is 800 ft away ))
why not just buy a factory gasket?? they seal coolant fantastic...... ill see how the orings work on it
Matt Nucci
6/94 E36 M3 Cosmos CP
Guess I should have been more specific. A gasket for an m52 is what I'm looking for.Originally Posted by nucci
Now what I wanna know is, with the Oring tool can we make the groves for the o ring in the head? Would this tool work for it ??
Sent from my iPhone using BF.com
for the head- you should use a bridgeport.
reason people do it in the block, is not because that tool does a good job, but because no real special equipment (besides the cutter) is needed. the cylinders space it accordingly. im doing my head, that way i dont have to pull my block (my machinist said he would disown me if i used that isky tool lol)
so there is no way we can use the tool to do the head with it ?
