s54 plug and play harness for e36 chassis install with DTA S100 standalone - DTA box not included. full Dual vanos control!!
This harness will allow you to plug and play install a S54b32 engine into your e36. You will need to supply your own DTA s100.
harness build cost = $1250, options include Wideband 02 wiring, narrow band wiring, your choice map / barometer sensor wiring, etc.
Wanganstyle Alpha N only basemap for 280 rwhp on pump 91 gas avail also upon request seperately, per case senario.
you will need to supply your own current harness and the harness from S54 as well as all desired sensors (02 sensors etc)
Wanganstyle Powertrain
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
