Ebay spa > Ebay treadstone
Real spa > Ebay spa
I have an Ebay spa, and trust me when I say the fitment sucks....you have to cut reliefs in the flange to allow for thermal exspansion and not crack, you have to grind some of the flange nuts flange off because they hit.the runners, then you have to get every single nut started before tightening any of them, took hours instead of minutes...then the wastegate placement...if your bottom mount it sucks, it leaves 1mm between the frame rail and wastegate pipe..but if your going to flip it, it might actually be better and clear the turbo, dunno.
Whatever ebay manifold I had was terrible, spool was horrid and flow up top was tragic compared to my setup now, many will argue thay the hostide change was what made the real difference, jordan has seen hotside changes and a pickup of 200 rpm max with a drop in flow up top and my car now is pulling harder up top at lower boost and spooling much much earlier.
I did groups of 2, real spa is cut every 1
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
Is this the manifold in question? Is the wastegate placement really that bad?
fyi, I received my spa knock off, if that's what it is, its labeled as a EMUSA manifold when I opened the box, which when I went to the website I found it for $117 + free shipping LOL dammit. it looks fine, I think the "collector" could have been designed a little better without the weird boxed empty area inside.
I'm currently running that mani in my car. Don't have any issues with it but spool isn't the best. I see full boost at about 3800 rpm with a gt35r .82 hot side but it works I ran 11.2 @ 120 shutting down at the 1000'. Be prepared to do ALLOT of cursing as fitment really blows with this mani. I had to fab a custom Wastegate pipe as theres hardly any clearance for the wg
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Sure which part?
To me it just looks like a cast version of the basic ebay tubular cheap manifold. I knew looking at it the wg placment would suck without making a sharp bend off it first. Id guessif anything hurts spool its that big hallow collector area. Also the head bolt holes seem kinda large like 3/8 or 10mm
Hi guys i have e36 m50b25 single vanos..can i flipped stock manifolds upside down and welding extensions adapters for turbo? How i can do it? How i can welding two different metals(manifolds and extensions) thank you
